Parkside PHD 150 E4: Pressure Washer Foam Cleaning with Washer, Micropowder, and Chemistry
DalamarPL 5217 2
  • #1 16414887
    DalamarPL
    Is it possible to wash under pressure with the use of a washer with foam or micropowder?
    The point is that the chemistry should go together with water under pressure (as in car washes, e.g. at BP), not first foam (low pressure), and then clean water under high pressure.
    I am able to buy something if necessary to achieve the above. effect.
  • #2 16424738
    DalamarPL
    Really nobody knows the answer?
  • #3 16424840
    płetwa
    Help: 165
    Rate: 556
    It is not possible.
