Ford Focus Mk2 2005 Fuse Box Diagram & Description for Large Navigation - Passenger Side
bogdan_plock 92868 10
How can I get the fuse box diagram and fuse/relay description for a 2005 Ford Focus Mk2 with the large navigation unit on the passenger-side interior fuse box?
An attached description for that fuse box was posted in the thread, but the visible replies show that the layout varies by version and is not identical across all Mk2/related boxes [#12647728][#17130731][#17262795] One reply says the standard Mk2/C-Max fuse description does not match 100%, and in one Mk2 description fuse F39 is not used, while in another it is listed as a 20A cigarette lighter socket fuse [#17130731] Another note says the Polish version of this box has no ABS fuse [#17262795]
  • #1 11003343
    bogdan_plock
    Rate: 29
    Hello, I need a diagram and description of the fuse box for the Ford Focus Mk2 2005 with large navigation (box inside the car on the passenger side)
  • #2 11003437
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2345
    You have one like this ?:
  • #3 11005526
    bogdan_plock
    Rate: 29
    Hello - this is what I have in my Focus
    description please
  • #4 11018139
    bogdan_plock
    Rate: 29
    Hello again and please provide a description for the fuse box provided in the photo
  • #5 12647728
    aramis1979
    Rate: 9
    attached description to the above box
    • bezpieczniki_cmax.pdf (18.45 KB) You must be logged in to download this attachment.
  • #6 17130267
    r0xify
    Rate: 13
    From the rummage of the subject. What the relay in position 5 is responsible for.
    I have a cmax 2.0tdci from 2005 and the same box.
    I am asking for an urgent reply. Thank you!
  • #7 17130731
    swirus71
    Rate: 27
    Unfortunately, the linked description of the CMAX fuses does not match 100% with the box of the "regular" mk2 seal
    F39 in the description - not used
    F39 in my mk2 - 20A cigarette lighter socket
    There may also be "turnouts" on the remaining ones
  • #8 17130746
    r0xify
    Rate: 13
    I have an identical one.
    I mean POZ 5 there is a relay. It is ? in the figure, but what functions does it have?
  • #9 17130933
    swirus71
    Rate: 27
  • #10 17130939
    r0xify
    Rate: 13
    There is still no information about the functions of the relays ...
  • #11 17262795
    Pieczarkarnia
    Rate: 9
    The strange thing is that there is no ABS fuse in this Polish version.
The discussion centers around the fuse box diagram and description for the Ford Focus Mk2 2005, specifically for models equipped with large navigation systems located on the passenger side. Users share a link to a diagram and request further details about the fuse box's functions, particularly regarding the relays and fuses. There are mentions of discrepancies between the fuse descriptions for the Focus and the C-Max models, with specific inquiries about the relay in position 5 and the absence of an ABS fuse in the Polish version of the vehicle.
