Focus mk2 1.8TDCI - Electrical diagram of the air conditioning relay
byq 23142 8
  • #1 16442068
    byq
    Good morning,
    Patient Ford focus mk2 2007 1.8 TDCI
    I need a wiring diagram for the connection between the engine controller and the AC compressor relay.
    I found one pin scheme but only one plug is described.
    Thank you for your help and best regards :D
  • #2 16442101
    panczapka
    manual:
    auto:
  • #3 16442147
    byq
    Hello, can you ask for the designation of the stressor relay or the whole description of the elements from the diagram.
    Thank.
    Manual air conditioning.
  • #4 16442196
    andrzej20001
    Help: 1578
    Rate: 6669
    K25 fuse F27 can be seen.
  • #5 16442218
    byq
    So A35 is a motor controller and I just need the plug designation and pin number of this cable.
  • #6 16442269
    mirekfm
    Level 19  
    Help: 41
    Rate: 291
    I have a slightly different pattern
    • Report2.pdf (18.43 KB) You must be logged in to download this attachment.
    • Report1.pdf (460.48 KB) You must be logged in to download this attachment.
    • Report.pdf (558.26 KB) You must be logged in to download this attachment.
  • #7 16442284
    panczapka
    black yellow
  • #8 17273153
    grzadzielski
    Can you ask for a list of explanations for the schematic?
    Thanks in advance
  • #9 17277032
    byq
    Thanks in advance
    Provide accurate car data, it will send a good diagram because they differ.
The discussion revolves around obtaining a wiring diagram for the air conditioning relay connection in a 2007 Ford Focus MK2 1.8 TDCI. The original poster seeks detailed information on the pin connections between the engine controller and the AC compressor relay, having found only partial diagrams. Various users provide links to diagrams and request further clarification on relay designations and schematic explanations. The conversation highlights the need for accurate vehicle data to ensure the correct wiring diagram is provided, as variations exist between different models.
