Seeking Ford Mondeo MK3 (2002) Cabin and Footwell Lighting Wiring Diagram - Fuse F99 7.5A
demsy 8232 4
  • #1 16698149
    demsy
    Help: 17
    Rate: 178
    I am looking for a wiring diagram of the cabin lighting inside the car and under my feet for a Ford mondeo mk3 (2002), I know that F99 7.5A is a fuse from this lighting, there is no voltage on the anim, they connect the power supply for this fuse for lighting shines. It seems to me that some relay gives voltage to this fuse, but nowhere in the description there is no such relay.
  • #2 16698287
    ladamaniac
    Help: 724
    Rate: 2077
    The relay is timed. Delays turning off the light inside for a few seconds after closing the door. I don't know if they all had or only richer versions. I think it's separate, above the driver's legs, closer to the bulkhead wall.
  • #3 16698315
    demsy
    Help: 17
    Rate: 178
    This F99 fuse is in front of the relay, because when I connected the voltage to it for a moment, the lighting under my feet and above worked normally. Now the question is where the voltage is supplied to F99?
    Added after 14 [hours] 50 [minutes]:
    Nobody has information about the wiring diagram of the lighting inside?
  • #4 16700778
    ladamaniac
    Help: 724
    Rate: 2077
    See, I write nonsense and nobody corrects me. What I wrote about the old man Mk2. Sorry, something caught my eye. Better message, diagram for Mk3 is on instruction.pl to download you need to register, but you can view online without registration. There is also a power saver, battery saver relay, which is in Polish here on the power electrode.
  • #5 16701962
    demsy
    Help: 17
    Rate: 178
    The cause was found without a schematic. I close the topic
