Swapping Primary and Secondary Monitor Designations: PanasonicTV and Asus MW221
RsNeo 101007 9
How can I make the Asus MW221 the primary monitor in Windows instead of the Panasonic TV, even though the BIOS appears on the Asus screen first?
To force Windows to renumber the displays, disconnect all monitors/TVs except the one that should become first, log in as an administrator, delete the registry keys `HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers\Configuration` and `HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers\Connectivity`, then reboot before detecting the second monitor again. After that, reconnect the other display and let Windows detect it; the first screen should stay #1 and you can set the primary monitor where you want it [#16573079] If that still fails, another reported workaround is to boot the PC with only one monitor attached, or change the monitor order in the graphics card driver control panel instead of Windows display settings [#12227808]
  • #1 11007577
    RsNeo
    Level 19  
    Help: 27
    Rate: 108
    Hello colleagues.
    I have a problem with a rather stupid thing, but unfortunately I can not cope on my own.
    I have two monitors, one Panasonic TV and the other is MW221 (Asus).
    The problem is that windows does not identify the main monitor correctly.
    This is illustrated in this screen:
    MW221 is marked as the main screen and super but it has the mark as 2, i.e. logging into the system is carried out on monitor 1 (PanasonicTV). Only after entering the password and starting the MW221 system, it becomes the master monitor and the desktop is displayed on it.
    I cannot cope with the MW221 being identified as 1, i.e. master monitor and PanasonicTV as 2, i.e. slave. I will add that monitors are recognized correctly in bios, Bios is displayed on MW221.
    How do I replace it?
    MW221 - connected via DVI.
    PanasonicTV - connected via HDMI.
    Best regards.
  • #2 11008113
  • #3 11008275
    RsNeo
    Level 19  
    Help: 27
    Rate: 108
    Unfortunately not.
  • #4 11008293
    mefistofilos
    Help: 110
    Rate: 87
    Right click on the monitor you want to set as primary and option - primary? ;)
  • #5 11020578
    RsNeo
    Level 19  
    Help: 27
    Rate: 108
    It sets it as primary, but it doesn't change anything except that it's ... basic.
    Maybe some more ideas?
  • #6 11020912
    Matuzalem
    Help: 1653
    Rate: 1101
    And the prosaic change of sockets to which the monitors are connected, have you tried?
    PS.
    Maybe you should provide information about the card and the connectors used?
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #7 11105813
    RsNeo
    Level 19  
    Help: 27
    Rate: 108
    Hello, I am sorry for such a long delay but I had family problems.
    Swapping the sockets is out of the question because the TV is connected to HDMI.
    The photo will show it best.
  • #8 12227808
    optymalizator
    Old topic, but a universal solution - but maybe someone will need it in the future ...
    1. first start the computer with only one monitor, then connect the second one
    2.if the first point does not work, change the order of the monitors not in the windows settings, but in the additional application loaded by the driver
    graphics card - e.g. in the NVIDIA control panel (green icon next to the clock)
  • #9 16573079
    SledgehammerPL
    Rate: 18
    The right solution is different.
    solution found here: http://support.displaylink.com/knowledgebase/...ndows-display-properties-identify-numbers-are
    We disconnect all monitors / TV except the one that is to be first.
    We log in as an administrator (ordinary user is not enough)
    we remove two keys from the registry (with subkeys)
    HKEY_LOCAL_MACHINE \ Systems \ CurrentControlSet \ Control \ GraphicsDrivers \ Configuration
    HKEY_LOCAL_MACHINE \ Systems \ CurrentControlSet \ Control \ GraphicsDrivers \ Connectivity
    WE RESTART THE COMPUTER (a very important step, it didn't work without it)
    we enter the monitor settings and try to detect another monitor (which cannot be successful because only one is connected)
    We attach the second monitor and try to detect it.
    Hallelujah, the first is the first and the second is the second!
    We set the basic one where we want.
  • #10 16771143
    Robert de Clair
    Rate: 89
    @SledgehammerPL Unfortunately it did not work: /
    after disconnecting tv and removing registers everything is correct.
    I have no numbering in the properties then
    after connecting the tv immediately (without detection) the monitor gets no2 and tv no1
    although the monitor is considered the primary screen, with WIN + P it is treated as the second screen, and the TV as the computer screen, which irritates me terribly.
    I will add that the system is win10x64, the card is gf1060
The discussion revolves around a user experiencing issues with monitor designation in Windows, specifically with a Panasonic TV and an Asus MW221 monitor. The user reports that Windows incorrectly identifies the MW221 as the secondary monitor, causing login to occur on the Panasonic TV instead. Various suggestions are provided, including changing monitor settings through Windows, swapping connection ports, and using graphics card control panels. A more technical solution involves modifying registry keys and ensuring only the desired primary monitor is connected during setup. However, some users report that these solutions do not resolve the issue, particularly in Windows 10 with a GeForce GTX 1060 graphics card.
