Thyristors Explained: Function, Applications, and How They Work in Electronics
Piotrek15 27420 4
  • #1 1144061
    Piotrek15
    Help: 14
    Rate: 32
    Hello!
    I am a beginner.
    I have a question: What are thyristors and what are they for !!!
    Thank you in advance for your answer!!!
    Regards!!!
    Piotrek15
    Paweł Es.
    Help: 1236
    Rate: 693
    4-layer switching elements. They are normally turned off and you can turn them on by impulse on the gate or by increasing the voltage on the thyristor electrodes above the breakdown voltage. The thyristor switches off when the current flowing through it drops below the threshold value.
    It is mainly used in AC systems as a two-state actuator, e.g. in regulators (lighting, rotational speed), in converters. The regulation is based on switching on the thyristor with a delay in relation to the zero crossing of the sinusoid. The waveform of the undercut sine wave has a lower RMS value, which is reflected e.g. in the brightness of a light bulb. The thyristor turns off at the next zero crossing.
    In DC circuits, it is used, for example, in security systems (as a key that short-circuits and burns fuses if the voltage on the system exceeds the permissible value.
    A thyristor with a reduced breakdown voltage without a gate is called a Diac (and is used in thyristor control circuits)
    Two thyristors connected in parallel (A1 with K1 and A2 with K2) placed in one housing and having a similar gate are called Triac.
    MarQs11
    Level 19  
    Help: 26
    Rate: 15
    Thyristors are electronic, semiconductor systems. They have three electrodes: Anode (A), Katode (K) and Gate (G). Normally it is in blocking state, but when the gate is energized it goes into conductive state.
    They are used in power control systems, switches, as "electronic relays" and generally wherever current (variable) needs to be switched.
    If you want to know even more, read this for example:
    http://elektro.w.interia.pl/energoel/tyrystory.html
    karlos79
    Help: 254
    Rate: 76
    Please here are some links about thyristors:
    http://www.skrypt.pl/index.php?d=prace&p=681
    http://elektro.w.interia.pl/energoel/sterow/
    http://www.zsee.bytom.pl/energo/dane/kl3inst004.html
    http://www.zsee.bytom.pl/energo/dane/kl5energo001.html
    www.eti.pg.gda.pl/katedry/ksmi/dydaktyka/ Przyrzady_polpwiedznikowe / Temat_11_Tyrystory.ppt
  • #5 1144394
    Piotrek15
    Help: 14
    Rate: 32
    Thanks a lot for all your help!
    Regards!
    Piotrek15
