Hello to everyone,I'm going to use thyristor power supplies to control the power delivered to kapton heaters which will be located in vacuum environment (big vacuum tube). What kind of firing mode of power supply is best suited for such application? I already know that the main disadvantage of phase angled firing mode is its vulnerability to RFI and harmonic distortions, however I'm still confused is it essential factor in our application or not. I've already adviced to use Burst firing mode as Kapton heaters (Polyimide) are probably not inductive or very low resistance on start up while I still don't understand what's the best firing mode for sure.Thank you very much in advance.
Ruslan Tazhkenov
Ruslan Tazhkenov
