The power end of the EEC-V. What is this transistor 5401DM? How to replace it?
lukin 8249 17
What is the 5401DM device in the EEC-V power stage, and how can it be replaced?
5401DM is a MOSFET, not an ordinary transistor, and a reported replacement is IRF840, but it is not a drop-in substitute [#4684630] The IRF840 needs an added driver/amplifier transistor because the original part is driven from about 5 V, while the IRF840 needs roughly 7 V to switch correctly [#4684630] Another user also reported that a substitute could be made to work only after adding three passive components [#4682733]
  • #1 1148503
    lukin
    Rate: 11
    5401DM what a transistor. what it can be replaced is controlled by the ignition coil
  • #2 4682733
    berti1985
    Level 19  
    Rate: 20
    I was able to match interchangeably, but I had to put in another three passive electronic components.
    Bartek
  • #3 4683059
    goldwinger
    Help: 535
    Rate: 2102
    This is not a transistor
  • #4 4683311
    eleom
    Rate: 18
    proposes to buy a computer on the back of a notebook and desolder such a tip on the occasion you will have one more on stock :D
    I did it.
    Greetings
  • #5 4684630
    berti1985
    Level 19  
    Rate: 20
    This is mosfet. I used irf840 but to trigger you had to add an amplifier from the transistor because the original is triggered with 5 va irf needs probably 7. After this operation everything is ok. But you have to choose a good transistor for the amplifier as far as I remember pnp. Bartek
  • #7 4687538
  • #8 4689218
    bohun555
    User under supervision
    Help: 26
    Rate: 124
    Jureczku must come because they did a few kilometers and nothing happens to them. I have substitutes at a good price but I have to test them and some time is missing. The table works but I have to let it in the car ...
  • #9 4689229
  • #10 4690647
    bohun555
    Help: 26
    Rate: 124
    In fact, the abundance of us with us abundance .... what endings I tested on the table for several hours and was ok. Temperature in the norm only that in the engine compartment there is no such working conditions ....
  • #11 4716597
    berti1985
    Level 19  
    Rate: 20
    Hello all.
    Let some of you tell me how to get this original driverrek from the switchboard.
    It looks like soldered entirely on tin to the main board.
    Bartek
  • #12 4716694
  • #13 4716736
    berti1985
    Level 19  
    Rate: 20
    And such a large resistance solder that I use to solder the stator wires from alternators. He has something like 150 watts.
    Bartek
  • #14 4716767
  • #15 4716858
    berti1985
    Level 19  
    Rate: 20
    I soldered the feet long ago with an ordinary small soldering iron. Only the radiator from the tile has left me.
    Bartek
  • #16 4719460
    berti1985
    Level 19  
    Rate: 20
    I bought a different version of the eecV central unit, but that's where the driver is called 5401 But the tip of GE was probably tomorrow I will check more carefully. And it had covers as long as I well mark TO-132 with a badge with a hole. I mounted on cables and the car was a guitar. Drivrek screwed through a silicone pad and pressed it with a clip screwed on by a screw.
    Bartek
  • #17 4720699
    bohun555
    Help: 26
    Rate: 124
    This is called PROFI repair .....
  • #18 6617823
    yarecky3
    Help: 5
    Rate: 48
    bohun555 can you write like the tests of your replacements?
    Greetings
The discussion revolves around the 5401DM transistor, which is identified as a MOSFET rather than a traditional transistor. Users share experiences with replacing the 5401DM, suggesting alternatives like the IRF840, while noting the need for additional components such as an amplifier to ensure proper triggering. Various users mention successful replacements from other drivers, including those from Sirius 32, and discuss the challenges of desoldering the original component from the circuit board. The conversation highlights the importance of testing substitutes under real working conditions, as well as techniques for soldering and desoldering components safely.
