Unobtainable Power Transistor Fja4313 In The Sc2oo Amplifier Circuit
270 7
  • Correcting SC200 supply voltage and LED specs
    #1 21678617
    huddslad huddslad
  • FJA4313 equivalent to 2SC5242, transformer voltage advice
    #2 21678618
    David Ashton
  • Transformer regulation yields 44-0-44 V no-load output
    #3 21678619
    huddslad huddslad
  • #4 21678620
    Alan Winstanley
  • #5 21678621
    huddslad huddslad
  • FJA4313OTU source, transformer correction, and LED guidance
    #6 21678622
    Alan Winstanley
  • #7 21678623
    huddslad huddslad
  • Questioning the low 4.4 mV emitter resistor bias
    #8 21678624
    huddslad huddslad
The SC200 amplifier design uses the power transistor FJA4313, which is difficult to source but has equivalents such as the 2SC5242. The FJA4313OTA is available from Digi-Key and the Silicon Chip Online Shop. The transformer specification in the original article is corrected to a 40-0-40 VAC secondary rather than 45-0-45 VAC, resulting in a ±56.6V supply after full-wave rectification, with voltage dropping under load as expected due to transformer regulation. The blue LED specified as SMD 3216/1206 with forward current ratings of 20mA or 30mA and forward voltages between 3.2V and 3.6V is not critical, as it is driven by a constant current source at about 2mA, allowing flexibility in LED choice. Additional queries addressed include the use of BC546B or BC546C transistors and BC556B in the amplifier, noting gain differences, and discussion on emitter resistor voltage drops in output stages, where the SC200 design uses a lower 4.4mV drop compared to higher values recommended in other amplifier design references.
