Ariston Class 24FF Boiler: Fixing Error 108, Pressure Gauge Issues, and Heating Solutions
XHOMIC 58878 2
  • #1 11212066
    XHOMIC
    Rate: 9
    Hello, I have a problem with the Class 24FF boiler. After turning on the boiler, err108 appears to me. How to fix it. The pressure gauge is standing still. It is audible as if something was preparing for heating, but after a few seconds error 108 appears.
    Before that, it was ok when I turned the boiler off and on without turning it OFF.
    Please help.
    Thank you.
    Andrzej Justek
    Help: 14
    Rate: 32
    Error 108 is a lack of water in the heating circuit or a damaged water pressure sensor.
    You need to supply water to the installation with a value of 1.2 bar.
    If this does not help, you need a service.
    AJ
  • #3 11214920
    XHOMIC
    Rate: 9
    Thank you very much and best regards.
