THOMSON CHASSIS ETC210 TV: LED Diode Flashing 4-8 Times, Cooling Solution with Fan Installed
fahrudin.b 4680 0
  • THOMSON CHASSIS ETC210 ... Hello, I had a problem with the TV when turned on for the occasion of 15 min. to 30 min .. and there is a problem! Extinguishes TVLED DIODE flasher THAN 4 TIMES TIMES Until8 all possible I reviewed everything that can inspect the problem was katonoj tube I put the fan (coolers) with otlonske from top to bottom to fura tv can to work 24 hours the problem is solved! :D:D
    fahrudin.b
    fahrudin.b wrote 30 posts with rating 16. Live in city bosnia and herzegovina. Been with us since 2011 year.
