Thomson TV Backlight Issue with OZ9976GN LED Driver: No Success after Protection Disable
andrebdnw 8349 2
  • #1 20050712
    andrebdnw
    I received a TV in which the backlight did not work. After that I disabled the protection (pin 11 with 10k ohm to ground), the TV worked for 2 weeks, now it has the same error. I have redone the solder joints and replaced the 10k ohm resistor with another 10k ohm. Unfortunately it does not work. Does anyone have any ideas? LED driver: OZ9976GN
  • #2 20107476
    alattaouia
    check LEDs or change the inverter
  • #3 21264087
    Mario19593007
    Questa Tv non fa uso di led per la backlight ma delle lampade CCFL. Togliere la protezione e lasciarla permanentemente non è una buona idea in quanto al deteriorarsi le CCFL si rischia di distruggere i trasformatori. Di sicuro andavano cambiate le lampade CCFL ormai esauste.
