Whirlpool ARC 7558/IX Fridge: Identify Burnt Transistor Parameters & Replacement Options
Duch80 12645 14
What are the specifications and replacement options for the burnt transistor on a Whirlpool ARC 7558/IX fridge control module?
The burnt part is a TNY268PN power-supply converter, and the usual repair is to replace it together with the nearby failed power-supply parts [#11251923] [#14120006] Commonly mentioned companion parts are 2 × 22 µF / 400 V capacitors, a 1N4007 SMD diode, and a 10 Ω / 5 W resistor [#14120006] Another repair report for the same board found C13 and C32 as 15 µF / 400 V capacitors, with R42 burned and needing replacement before the fridge would start again [#16936257] The thread also notes that dried or incorrectly specified electrolytic capacitors can damage the converter, so the surrounding capacitors should be checked carefully [#13942583]
  • #1 11251370
    Duch80
    Hello all.
    This is my first post, so I apologize for any irregularities.
    So, as in the title, the problem is that the refrigerator stopped working, a professional came and told me that the control module had fallen, I took it out and see that one of the chips is burnt, unfortunately so unfortunate that you can not see its numbers, I was at three "professionals", but everyone spreads their hands and says that without a number they can do nothing. My request is that if anyone knows what are the parameters of this transistor, I would ask and info (possibly a picture or circuit diagram), my gratitude will be huge. Burnt scaler marked in the picture. Whirlpool ARC 7558/IX Fridge: Identify Burnt Transistor Parameters & Replacement Options
    Arcus1977
    Help: 66
    Rate: 203
    TNY268PN-converter
  • #3 11642063
    Barney13
    Hello, I managed to fix it, I have the same problem, repair cost estimated at about 650 PLN
  • #4 11645358
    Duch80
    Yes, the module worked, but it burned at every voltage stroke I exchanged it already 3 times (cost 3 zlotys), so I suggest to immediately connect the refrigerator to the surge suppressor (strip, filter). I did it and so far everything works.
    And so it is BAAAARDZOY THANK YOU for giving the number of this baby because I really pity to throw away a new and efficient refrigerator, and none of the few "professionals in which I was unable to help me and for them the only solution was replacement of the module.
  • #5 13935471
    wiosnar
    Do you have a photo of this tile from the 2nd page? I have a damaged item as an attachment ...
    iskrownik
    Home appliances specialist
    Help: 378
    Rate: 733
    This is a smd jumper.
  • #7 13935558
    wiosnar
    so I can replace it with an ordinary piece of wire ??
  • #8 13937773
    iskrownik
    Help: 378
    Rate: 733
    You can, just look first for the reason why this jumper has evaporated you.
  • #9 13938025
    wiosnar
    the reason was prosaic I made a conclusion.
    unfortunately, after soldering the jumpers, one must look for further damage.
    But thank you very much for your help.
  • #10 13942583
    Trull
    Help: 138
    Rate: 600
    Electrolytic capacitors with incorrect parameters (dry) can damage the inverter. TNY268 can work up to 265 V, and I do not think that such large voltage spikes will appear on your network.
  • #11 14120006
    MARCIN.SLASK
    Help: 1037
    Rate: 2658
    Usually Koshiny are falling. Either a short circuit or a total loss of capacity. What causes the burning of the next elements of the power supply.
    Generally, the most common repairs are: TNY268PN, 2 * 22 µ / 400 (better give slightly more capacity than not too small), 1N4007 SMD, 10 Ω / 5W.
  • #12 14334122
    Vinncent
    Rate: 17
    I have a question, in which place this module is, in the aforementioned description should be fixed in the upper beam over the part of the refrigerator but it is not there.
  • #13 14339617
    Vinncent
    Rate: 17
    And he found himself, he is at the bottom right on the back.
  • #14 16936257
    jedreg
    Rate: 10
    Well, I got it, today in the afternoon after almost 10 years of work, the fridge hit ARC7550 / IX and it with a loud slam :) after opening the controller casing you could feel the pleasant smell of the "magic balloon" that disappeared from the torn switch TNY268PN.
    Generally, the most common repairs are: TNY268PN, 2 * 22 µ F / 400 (better give slightly higher capacity than too small), 1N4007 SMD, 10 Ω / 5W.
    Marcin, thanks for pointing out the cause of the explosion. The capacitors were easy to find (C13 and C32, 15 µ F / 400V). The diode and the power resistor are probably next to the C32 capacitor - therefore D1 and R42 respectively. Anyone can confirm this? R42 efficient (about 8 Ω no outlets), D1 also C32 theoretically efficient (14uF), C13 slightly swollen and at the outlet he hissed, leaving behind the leg in the PCB :) The other side of the PCB clean, no visible damage. Is it worth refining or replacing any other elements in advance?
    EDIT : After replacing U11, C13 and C32 refrigerator still did not get up. However, R42 was burned so that there was no trace on it except the micro-cracks on the underside, and I, at the beginning of laziness, did not desolder the resistor for measurement. Here's a tribute to Trull for a clue. After replacing the R42, the fridge came back to live and continues to work.
    -andrzej.
  • #15 17278202
    rzepikwp
    I just got caught up with this fault. In addition to the previously mentioned elements, I replaced the C15 capacitor because it was also swollen.
    The fridge is 10 years old
The Whirlpool ARC 7558/IX refrigerator experienced a failure due to a burnt transistor in the control module, specifically identified as TNY268PN. Users discussed the challenges of identifying the burnt component's parameters, with suggestions to replace it and other associated components like capacitors (C13, C32, C15) and diodes (D1). Recommendations included using surge protectors to prevent future damage and ensuring proper voltage levels to avoid repeated failures. Some users successfully repaired their units after replacing the damaged parts, while others noted the importance of checking for underlying issues that caused the initial failure.
