[Solved] Bosch KGV-2605 Fridge: Seeking Diagram for Blown Driver 9.981.310.017-5 & Resistor Parameters
marcin64 17967 9
How can I identify the value of the burnt resistor on the Bosch KGV-2605 driver module 9.981.310.017-5, and is there a diagram for it?
The burnt part is reported to be two 56-ohm resistors, not 5.6 kΩ. [#9125182] One reply specifies the marking as 2×56.2 Ω, with color bands green, blue, red, gold, brown. [#15636824] Another user initially guessed 5.6 kΩ, but this was corrected to 2×56 Ω. [#9072498][#9125182]
  • #1 8700919
    marcin64
    Hello, I am looking for a diagram, as in the subject I gave, driver 9.981.310.017-5 fridge Bosch KGV-2605; because one resistor probably blown and it is impossible to read its parameters :) in advance, thank you
  • #2 9072423
    MATEO XXX
    Rate: 31
    Hello, I have the same problem as someone will have a shemat to ask for urgent contact.
  • #3 9072434
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    You have the option to give a good picture of this module?
  • #5 9072498
    MARCIN.SLASK
    Help: 1037
    Rate: 2658
    Yesterday I did a very similar module, just without the triac and resistors.
    By stripes this looks twice after 5.6K.
    :arrow: Edit: corrected TONI_2003 2x56?
  • #6 9125182
    stan14
    Not 5.6k, but 2 * 56 ohms. In my fridge one of them has been burned out.
  • #7 11538585
    mkris
    This morning I felt something burned in the kitchen and it turned out that it was a Siemens fridge, but the driver was the same. I would like to show two pictures. This one resistor has burned a light "hole," but I hope it can be soldered. I have one more request. Please look at the second image on resistors from R30 to R33, I must also replace them. The easiest way would be to :) them :) only, that currently I borrowed my meter.
    Thanks and best regards.
    Bosch KGV-2605 Fridge: Seeking Diagram for Blown Driver 9.981.310.017-5 & Resistor Parameters Bosch KGV-2605 Fridge: Seeking Diagram for Blown Driver 9.981.310.017-5 & Resistor Parameters
    One 112? resistor can be used or it must be 2 * 56??
  • #8 11538640
    MATEO XXX
    Rate: 31
    Buddy, I did it that way ... I picked up all the carbon from the burnt board with a screwdriver and soldered the resistors in this way. I would like to add that I sold 1/25,6K / 1W in series
  • #9 14146009
    kamecki99
    Can you specify which resistors? Is 2x5,6K or 2x5,6??
    UL7855
    Help: 49
    Rate: 173
    Here are 2x56.2?
    Stripe colors: green blue red golden brown.
Discussion revolves around the Bosch KGV-2605 fridge, specifically seeking a schematic diagram for the driver 9.981.310.017-5 due to a blown resistor. Participants share similar experiences and inquire about resistor specifications, with suggestions indicating the burnt resistor is likely 2x56 ohms. Some users provide links to images of the module and discuss methods for repairing the burnt components, including soldering techniques and resistor replacements. The conversation highlights the importance of identifying the correct resistor values for effective repairs.
