Voltage-free control of roller shutters using a voltage-based controller.
witja69 4959 9
How can I connect a 230 V astronomical timer to an Elmes ST6H controller that needs dry contacts for controlling all roller shutters together?
Use an intermediate relay with a 230 V coil so the timer’s voltage output only drives the relay, and the relay’s contacts provide the dry contact closure required by the ST6H [#11449984] Any relay with a 230 V coil will do; the exact form factor depends on how and where you want to mount it, and you can use a socket or stand if needed [#11454279] The relay does not need to switch the shutter motors directly, because the ST6H already has separate relays for each motor [#11454441] The setup was later confirmed to work in practice with two Relpol relays mounted on sockets [#11575370]
  • Using a relay to interface 230 V control with dry contacts
    #1 11448507
    witja69
    Rate: 12
    I have an Elmes ST6H control unit for up to six roller shutters, and I’ve also bought a programmable up-down switch with an astronomical clock.
    I wanted to connect it to the ST6H controller so that it could control all the roller shutters at once (up at sunrise and down at sunset); unfortunately, the ‘astronomical’ switch supplies 230V, whereas the control unit only has dry contacts.
    I’d be grateful for any advice on how to solve this problem – would it be sufficient to use a contactor or a relay, and if so, which type?
    Kind regards
  • #2 11449101
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    What is the total power output of all the engines?
  • Use a dry-contact relay between timer and controller
    #3 11449968
    witja69
    Rate: 12
    andrefff wrote:
    What is the total power of all the motors?
    Power isn’t a factor here, as the motors are connected to the ST6H control unit (each one separately), whilst the control unit has a ‘voltage-free’ connection to, for example, a timer switch, which should close the relevant circuit (up or down) thereby activating all the roller shutters at once (up or down); however, the ‘Astro’ timer I purchased supplies a voltage (for closing or opening) as it is designed to control a single roller shutter directly, rather than a group.
    So now I need to use a relay that won’t supply voltage (up/down) from the timer but will simply close the circuit.
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    For example, like this
  • #5 11454141
    witja69
    Rate: 12
    Thank you for the link,
    would this one be any good too? Relay
  • #6 11454162
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Sure.
  • #7 11454231
    witja69
    Rate: 12
    I’ve also found one that doesn’t need soldering: Relay2
  • #8 11454279
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    You can also buy a stand for the one I linked to; in this case, it all depends on where and how you’re going to install it. You didn’t give any details, so I recommended the smallest one. The one from Aledrogo would also work – in fact, any model with a 230 V coil will do.
  • Voltage-free input works with relay-controlled timer
    #9 11454441
    witja69
    Rate: 12
    The total power of the motors is around 500 watts, but that doesn’t really matter anyway because the control unit has relays (one for each motor). The control unit has one input (the manual says it’s voltage-free), which raises or lowers all the roller shutters. For now, I’ve connected a standard two-way switch to it and it works. So I think it’ll also work with a timer controlling the relays.
    Thanks again, and I’ll let you know next week once I’ve connected the relays.
  • #10 11575370
    witja69
    Rate: 12
    I’ve connected two Relpol relays on sockets and everything’s working – thanks again for your help!
