Auraton 2025 RTH: how do I control the temperature independently in two rooms?
bartekfigura 6366 4
  • #1 11471039
    bartekfigura
    Level 30  
    Help: 112
    Rate: 525
    I’m planning to buy Auraton thermostats for my AEG WKL 2000W radiators, but I have a few questions.
    I need to control the temperature independently in two rooms: my child’s bedroom and the living room. Will one controller and two sensors fitted to the radiators be enough, or do I need to duplicate the system in each room – i.e. a separate controller and a separate sensor for each radiator? And if so, will two such systems interfere with each other? I’m only interested in the RTH version because of the 16 A relay contact rating; the wired version can only handle 8 A.
    I’d also appreciate some general feedback on these controllers.
  • #2 11479037
    duddy
    Help: 56
    Rate: 186
    There must be a separate thermostat for each room. The temperature will need to be measured in each room. However, I would recommend setting up a system with a controller and sensors in the rooms. I have a system like this using an EL-PIAST controller, which controls the heating in four rooms. It has a single main HMI panel for managing room temperatures. In addition, the controller naturally manages the heat demand in the house and starts the boiler. The only minor drawback is that you need to write a programme, which took me about two hours.
    PITSTOP
    Piłkarska 21, Gorzów Wielkopolski, 66-400
  • #3 11483058
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    You can’t control this system with just one Auraton; I’d recommend – given that it’s electric heating something like this thermostat, plus a double frame and a light switch. Just so it looks presentable. I’ve got a fan in my duct heater connected this way.
    Plumpi
    Heating systems specialist
    Help: 874
    Rate: 2676
    bartekfigura wrote:
    I’m planning to buy Auraton controllers for my AEG WKL 2000W radiators, but I have a few questions
    I need to control the temperature independently in two rooms: my child’s bedroom and the living room. Will one controller and two sensors fitted to the radiators be sufficient, or do I need to duplicate the system in each room – i.e. a separate controller and a separate sensor for each radiator? And if so, will the two systems interfere with each other? I’m only interested in the RTH version because of the 16 A relay contact rating; the wired version can only handle 8 A.
    You can use 2 RTH receivers, one 2025RTH or 2030RTH controller/transmitter, and 1 or 2 T-2 sensors
    The whole system can be configured as follows:
    Register the controller (2035 or 2030) with the first RTH receiver, followed by one of the T-2 sensors
    Register the controller with the second RTH receiver, followed by the second T-2 sensor
    Each RTH receiver will be controlled by the same controller using the same programme, but temperatures will be measured by separate T-2 sensors.
    Instead of one of the T-2 sensors, you can use the sensor built into the controller. In that case, you’ll only need: two RTH receivers, one controller and one sensor.
    The only drawback of these controllers is that the controller’s display does not show readings from the remote T-2 sensors.
    And then there’s the question of whether it’s possible to buy an RTH receiver separately, or whether you’ll actually need to purchase two sets of controllers after all?
  • #5 11717202
    bartekfigura
    Level 30  
    Help: 112
    Rate: 525
    Thanks, Plumpi. I’ve tried your solution and it works a treat:)
