How do you connect a GSM module to control a garage door?
niemilce 4617 8
  • #1 11536200
    niemilce
    I have a GSM module (CLIP- and SMS-controlled) which has a transistor output that can control the power supply ground up to 100mA. I would like to connect a CLIP-controlled garage door opener at home to this output. As far as the programming is concerned, I’ve got that sorted, but the wiring diagram is a bit of a headache. I have a wall-mounted button for opening and closing the door. What connection diagram should I use so that I can control the garage door opening via my phone? Do I need a relay or a fuse, or should I simply connect a cable directly from the output to the door controller?
  • #2 11536398
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    A relay connected in parallel with the existing wall-mounted button.
  • #3 11536689
    niemilce
    Could you explain which relay to use (would a standard 12V one do?) and how to make the connection, and whether to omit the fuse?
  • #4 11536752
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    And what is the voltage at that output on the GSM module?
  • #5 11536788
    niemilce
    The output controls the ground, so it’s 0V, but the voltage is 12V.
    If I’m thinking correctly, I connect the relay like this:
    coil: +12V and the signal from the output (-)
    Once the output is triggered, the relay switches from NO to NC.
    On one side, I connect the cable from the gate opener controller, but what about the other side?
    I’m not sure if I’ve explained this correctly.
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Almost right – you’ve got the power supply side sorted; on the other side of the relay, you break the circuit in the same way as the button does. So, you connect a 0.5 mm² two-core cable to the same terminals on the gate control unit, specifically to the COM and NO terminals on the relay.
  • #7 11536831
    niemilce
    So, apart from the power connection being correct, the relay is the opposite of what I thought. Thanks for your interest and the tip.
    And what kind of relay should I use, and perhaps a fuse, to make sure it all works as it should, because I’m afraid I’ve no idea.
  • #8 11536858
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    For example this and stand . A fuse is not necessary.
  • #9 11536874
    niemilce
    Thank you very much for your help. I think the issue has been resolved and can be closed.
