Removing or Cracking BIOS Password for Entire System: Steps & Tips (Max 90 Ch)
Daro__ 77850 9
How can I remove or crack a BIOS password for the whole system?
Disconnect the PC from mains and clear the BIOS/CMOS by using the CLEAR CMOS jumper for about a minute, then put it back; this resets the BIOS to default settings and removes the password [#1192902][#1226554] Removing the motherboard battery for a few minutes can also work, but one reply warns the jumper method is safer because pulling the battery can bend the contacts [#1192886][#1192910] If you do not want to open the machine, some replies mention trying manufacturer-specific universal BIOS passwords or password-recovery tools, but they are less reliable and should be used at your own risk [#1226495][#1192886]
  • #1 1192879
    Daro__
    How to remove or crack the password set in the bios? (for the entire system)
  • #2 1192886
    hlw
    Rate: 16
    The first option is to remove the battery from the motherboard for a few minutes. Option two is a program for these purposes Ex:! Bios
    katomasz
    Help: 12
    Rate: 11
    Disconnect the computer from the mains (completely plug), remove the battery and put the jumper on CLEAR BIOS. After a minute, reverse the steps. Note that all settings will be reset to default.
    R_Przemek
    Help: 32
    Rate: 12
    As he wrote hlw ... but I do not recommend removing the battery because it is easy to bend the contacts ... It is better to remove the jumper from the motherboard, it should be next to the battery. in the motherboard book it should write about this jumper "Clear CMOS JUMPER".
  • #5 1226495
    sylwwwek
    Help: 17
    Rate: 14
    hello-if you are afraid of removing jumpers and batteries, there are always "universal passwords" left, although this method is not as effective as the previous one, but completely safe - we can enter passwords indefinitely ... passwords are on the net ... greetings
  • #6 1226554
    LtLog
    Level 30  
    Help: 165
    Rate: 39
    Hello, put the battery back on the shelf, not these times have been around for a long time. The easiest way for you will be to move the CLEAR CMOS jumper, for this minute also shorten yourself and put the jumper back, then the BIOS settings will be restored to their defaults, however, the settings will be restored to the default configuration. If you do not want to play, enter the BIOS manufacturer (provided when starting the computer), we will give you general passwords.
    Regards Lt.
  • #7 1226637
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    Download the boot floppy from Ciche's website http://www.vojtas.fr.pl/cgi-bin/load.cgi?http://www.csk.pl/~cichon/files/Cichy_BootDisk22.zip " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.vojtas.fr.pl/cgi-bin/load.cgi?http://www.csk.pl/~cichon/files/Cichy_BootDisk22.zip , there are - among others - programs to crack \ extract passwords from bios, Award and Ami.
    Or you can watch at http://www.ultimatebootcd.com/ " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.ultimatebootcd.com/ department BIOS or download files:
    BIOS http://www.geocities.com/mbockelkamp/index.htm?dos?200514 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.geocities.com/mbockelkamp/index.htm?dos?200514
    Cmos password recovery tools 4.5 http://www.cgsecurity.org/?cmospwd.html " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.cgsecurity.org/?cmospwd.html
    WipeBIOS http://www.geocities.com/sjwoolham/ " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.geocities.com/sjwoolham/
    !BIOS http://www.11a.nu/index.php?menuValue=15&chooseType=art&chooseValue=27 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.11a.nu/index.php?menuValue=15&chooseType=art&chooseValue=27
    These are only part of the programs, but most of the time it will be enough.
    Just a small but important note: improper use of these programs may damage the BIOS, you do so at your own risk!
    Ps. I took some passwords off the BIOS without any loss so far ...
  • #8 2141720
    radomirs
    I tried to run the bios 3.10 program, but it gives an error:
    runtime error 200 at 1276: 0091
    award bios v6.00pg .... I managed to read something like that after a few tries, because it barely appears on the screen, it already disappears .... does anyone have any association? :) . if so, I will ask for some universal passwords ... before I clean my cmos ...
    Added after 4 [minutes]:
    yet modular ... :) ...
    award modular bios ....
    Added after 12 [minutes]:
    I tried the slogans:
    alarbrww (Supervisor on Chaintech boards)
    alfarome
    akakal (User na Chaintech)
    award_?
    AWARD_SW
    AWARD? SW
    awardsw
    awkward
    aPAf
    AW
    AWCRACK
    aLLy
    AWARD? PW
    BIOS310
    biostar
    BIOSTAR
    biostar
    condo
    CONDO
    CMOSPWD
    Compleri
    CONCAT
    CTXA
    efmukl
    HLT
    j64
    j256
    j322
    j262
    KILLCMOS
    lkw peter
    LKWPETER
    lkwpeter
    Sxyz
    SWITCHES_SW
    SZYX
    Syxz
    CHEESE
    SKY_FOX
    syxz
    SKY FOX
    ttptha
    water
    Water
    zjaaadc
    zjaaade
    Zbgn
    589589
    SERSKY_FOX
    ally
    589721
    awkword
    Condo
    01322222
    aPAf
    award
    award
    award_ps
    biostar
    condo
    awkward
    CONCAT
    \\\with
    \\ bb
    CHEESE
    ZBAAAC
    ZAAADA
    and nothing. I would prefer to avoid the bios configuration from the beginning (I need not add that I have never done that :) .... so I don't know what it is supposed to look like ... maybe some tips ??
    Added after 9 [minutes]:
    the more so that I do not know which jumper it is, because I do not have a description of the board, and there are 2 or 3 around the battery, none of them clearly signed (e.g. ccj :) )
  • #10 2141867
    radomirs
    Oki, I cleaned the cmos jumper (after a long search for a downloadable manual, on the network :) ). bios configuration, it's probably a different topic ...
    Thank you for all your help. I close the topic
To remove or crack a BIOS password, several methods are discussed. One common approach is to disconnect the power, remove the motherboard battery, and use the CLEAR CMOS jumper to reset the BIOS settings to default. Caution is advised when handling the battery to avoid bending contacts. Alternatively, users can utilize universal passwords available online, though this method may be less effective. For those preferring software solutions, various tools for BIOS password recovery are recommended, including programs like CmosPwd and WipeBIOS. Users are warned that improper use of these tools can damage the BIOS. Specific universal passwords for Award BIOS are also shared, along with troubleshooting tips for running BIOS recovery programs.
