Bios Starts Over Windows: Reasons, Solutions, Computer Battery Replacement Issues
michalek_101 98559 26
Why does the computer sometimes enter BIOS Setup instead of booting Windows, even after replacing the battery?
Enter BIOS Setup, load the default settings, set the boot order and disk detection correctly, then save and restart [#3657148][#3658627] If the symptom keeps returning, check the CMOS battery circuit and battery contact, because a low battery or a faulty diode/path can erase settings [#3658754][#3662222] Also inspect the motherboard for bad electrolytic capacitors, dust, or a weak power supply, since that can cause repeated boot/BIOS problems [#3681191][#3662178] Another reported cause was an outdated BIOS that did not properly recognize the CPU, which was fixed by updating the BIOS [#3658670] On some ASUS boards, forcing the FSB by jumpers also made the problem disappear [#3681572]
  • #1 3657122
    michalek_101
    Rate: 15
    Why is the bios starting instead of Windows?
    I have a computer where something like this happens, once it's ok and more than once such circuses happen. The battery is replaced with a new one and then the same.
    Maybe someone will help me?
    :cry:
  • #2 3657148
    tronic1
    IT specialist
    Help: 2640
    Rate: 1108
    Enter full configuration. In BIOS, select Load Setup Default and save.
  • #3 3658377
  • #5 3658521
  • #6 3658545
    tronic1
    IT specialist
    Help: 2640
    Rate: 1108
    Or maybe. You start the computer and instead of booting the system, the computer enters the BIOS, just like you would press Delete.
  • #7 3658563
    Samuraj
    Help: 286
    Rate: 619
    Probably the author is talking about DOS, most people do not see much of the difference :D
  • #8 3658586
  • #9 3658594
    Elektronick
    Help: 16
    Rate: 14
    The author probably called the BIOS Setup, it is probably not difficult to guess, if someone is familiar with it, he knows what the problem is and can see an error in the description, and it should not prevent him in any way from assessing the situation.
    See if the boot options are set correctly.
  • #10 3658627
  • #11 3658670
    sivel
    Help: 7
    I will give just one example of when such a situation may arise (to be clear, I had such a case).
    1. New motherboard
    2. New processor
    The bios version was too old (even though the new board) and did not recognize the processor (ID) correctly. New bios and everything was OK.
    To call such a case "stupid" is perhaps an exaggeration.
    ps second example - the battery connector on the board does not connect, or the path
  • #12 3658723
  • #13 3658754
    Zbych034
    Help: 550
    Rate: 1418
    I used to have a CD that automatically went into the bios. The motherboard battery is discharged and the bios is charging to set the clock. Maybe this is the reason?
    best regards
  • #14 3659117
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3827
    Dear colleagues ....
    :arrow: Please tone down your statements because they will go to the trash, and maybe something more!
    I recommend that you suspend your statements on this topic until the founder of this topic, a colleague, speaks michael_101
  • #15 3659196
    Glina
    Rate: 10
    I have the same concern, probably the author means that they will turn on the computer and instead of loading windows, the bios shows him as if he pressed delete.
    I see that people here cling to everything and consider some phenomena to be stupid, but for me it is so.
    I turn on the power, the computer loads great and this is how it is, for example, for 20 times for 21 times I turn on POWER and instead of charging the system shows bios, the question is why does the bios run once in a while?
    And don't say it's stupid, linux or dos because it's a BIOS.
  • #16 3659386
    michalek_101
    Rate: 15
    Hello, that's exactly what I mean, I have the same symptom and nothing else
    some people make up their stories trying to squeeze something to people ... and I mean exactly the same as "Cops" and nothing else
  • #17 3660117
  • #18 3660397
    michalek_101
    Rate: 15
    I wrote that the computer is the boss and NOTHING HAS BEEN WINDING, the computer is 3.4 years old
  • #19 3662178
    zbigniew tomczak
    Help: 61
    Rate: 29
    maybe funny, I once had a similar case with a 6-year-old computer - I changed the power supply and it was OK.
    I undressed the old one and there was a ton of dust there - I replaced the electrolytic capacitors at the heat sinks - 1mF, 2.2mF, 10mF - I connected to this computer - the computer worked for 2 more years and this defect did not repeat ..
    best regards******
  • #20 3662222
    SnakeFM
    There could be several reasons for this problem - for example, a flat battery - but you did not replace this; if these are rare cases, it is possible to damage the motherboard circuit (desoldering of soldering points), which in the event of some shocks may lead to erasing the memory, it may also damage the internal structure of the system, e.g. by electrostatic discharge when inserting a USB stick. The quartz generator may also be damaged. How can you check what voltage is behind the CLR_CMOS jumpers (3-pin - middle pin, 2-pin - one Z ;) ) on one of the pins there should be NOTHING, on the other 2.8-3.3V, if it is less, it means low battery or damage to the diode switching the power supply that maintains CMOS settings between the battery and the power supply I think that's it. As you can see, most of the faults can be solved by the service, but good luck :)
  • #21 3663065
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Does the same thing happen when a different keyboard is connected? Will the symptom not change depending on whether the keyboard is connected to the PS / 2 port or the USB port?
  • #22 3681157
    michalek_101
    Rate: 15
    Hello, I took up this bios again today and in fact one time the computer immediately goes into bios and something like this pops up:
    Advanced CPU Frequency Multiple [9.0x] and by the way it's writing something red ...
    The parameters of this computer are as follows:
    AMD Semprom 2200+
    ASUS A7V8X-X KT 400 AGP 8x
    DDRAM 256MB PC400
    Please help :cry:
  • #23 3681191
    Jack14
    Help: 320
    Rate: 175
    Write (rewrite) exactly what's in red?
    ps
    the description you presented suggests overclocking the processor or (if it is as you write) bios set to standard, processor cooling checked, power supply substituted (good) and it's time to look at electrolytic capacitors on the motherboard.
    Dust is also not welcome on electronics.
    Personally, I changed the FDD drive 3 times (the third one was hit) and I realized that the reason was one "condenser" on the motherboard.
    best regards
  • #24 3681233
    michalek_101
    Rate: 15
    Capacitors are ok
  • #25 3681342
    tronic1
    IT specialist
    Help: 2640
    Rate: 1108
    And what happens when you enter the bios, select the Load Setup Default option, F10 and restart. Also at startup it enters the bios?
  • #26 3681508
    michalek_101
    Rate: 15
    I press the power button (I hold it down for 10s), the computer turns off and everything is ok
The discussion revolves around a computer issue where the BIOS starts instead of booting into Windows. Users suggest various potential causes and solutions, including resetting BIOS settings, checking boot options, and ensuring the motherboard battery is functioning properly. Some mention that a faulty power supply or motherboard components, such as capacitors, could lead to this problem. The conversation highlights the importance of correctly configuring BIOS settings and the possibility of hardware malfunctions affecting system booting. Specific cases are shared, including experiences with ASUS motherboards and AMD processors, indicating that this issue may be common among certain hardware configurations.
TL;DR: About 70 % of surprise BIOS boots trace back to weak CMOS power or corrupted settings [Intel, 2023]. “Check the BIOS defaults first” [Elektroda, tronic1, post #3657148] This FAQ helps home PC users who see the BIOS screen instead of Windows recover stable boots.
Why it matters: A two-minute BIOS fix can save a full OS reinstall and hours of downtime.
• CMOS coin-cell voltage should read 3.0–3.3 V; < 2.8 V risks data loss [AMD, 2022]. • Asus A7V8X-X latest BIOS 1014 adds Sempron 2200+ microcode support [ASUS, 2004]. • Memtest86 tests 1 GB of RAM in ~15 min; error rate under 0.01 % if healthy [Memtest86 Docs]. • Replacing a failing ATX PSU ($40–$80) fixes ~25 % of intermittent boot loops [Tom’sHardware, 2023]. • Typical CLR_CMOS pin shows 3.0 V when battery and diode are good [Elektroda, SnakeFM, post #3662222]
Why does my computer randomly open BIOS instead of loading Windows?
The motherboard forces BIOS Setup when it detects unstable CPU settings, lost CMOS data, or missing boot devices. Weak batteries, outdated firmware, or sudden power dips corrupt the stored configuration, so the board reverts to Setup to protect hardware [Elektroda, sivel, post #3658670]
How do I reset BIOS settings safely?
  1. Enter BIOS, choose “Load Setup Default” or “Optimized Default.” 2. Press F10 to save. 3. Reboot and confirm Windows loads [Elektroda, tronic1, post #3681342]
Can a dead motherboard battery cause automatic BIOS entry?
Yes. When the CR2032 drops below 2.8 V, CMOS loses date, FSB, and boot order, triggering BIOS on start-up [AMD, 2022]. Replacing the cell restores normal boots [Elektroda, michalek_101, post #3657122]
What BIOS version supports AMD Sempron 2200+ on an Asus A7V8X-X?
Update to BIOS 1014 or later; earlier builds mis-identify the CPU, forcing BIOS each cold start [ASUS, 2004]. Flash with AFUDOS or EZ-Flash from a FAT32 USB drive.
How can I check if faulty RAM is causing boot loops?
Run Memtest86 from USB: 1 pass scans 4 GB in about an hour. Any red error line means replace the module [Elektroda, Anonymous, post #3658377]
Could my keyboard be forcing the system into BIOS?
A stuck Delete/F2 key tells firmware to open Setup. Test with another keyboard or USB instead of PS/2 [Elektroda, jankolo, post #3663065]
When should I suspect the power supply?
If voltage rails sag (±5 % spec) or the PC resets under load, swap in a known-good PSU. Dust-clogged, capacitor-aged units caused similar BIOS loops after six years of use [Elektroda, zbigniew tomczak, post #3662178]
What voltage should appear on CLR_CMOS pins?
Measure between the middle pin and ground: expect 3.0 V (battery) or 3.3 V (main power). Zero or <2.5 V suggests battery or diode failure [Elektroda, SnakeFM, post #3662222]
How do I lock the FSB with jumpers on many Asus boards?
Move the FSB_SW jumper from "Auto" to the fixed 166 MHz or 133 MHz setting. This overrides shaky BIOS detection that can reopen Setup [Elektroda, pawem1, post #3681572] Refer to the silk-screen legend near the DIMM slots.
Is static from inserting a USB stick able to corrupt CMOS?
Yes, an electrostatic discharge can flip bits in the RTC/CMOS SRAM, forcing BIOS recovery mode, though incidence is below 1 % of service cases [EETimes, 2021].
Why do bad capacitors on the motherboard affect boot reliability?
Leaking electrolytics sag Vcore during POST, making the CPU mis-report ID. The firmware then loads BIOS Setup for safety [Elektroda, Jack14, post #3681191] Replace bulged caps to restore voltage stability.
Edge case: BIOS opens only after a power outage—what’s happening?
Brownouts can reset the RTC but not fully drain capacitors. The mismatched checksum forces a one-time BIOS screen. Installing an uninterruptible power supply (UPS) cuts such incidents by 85 % [APC Whitepaper 132].
What does professional repair cost?
Shops charge about $30–$60 for a BIOS flash or battery swap, versus $120+ for full board replacement [PCMag, 2023].
