Removing BIOS Password on HP EliteBook 8440P After Disconnecting Motherboard Batteries
Adri9700 18465 3
  • #1 16576971
    Adri9700
    Rate: 11
    How to remove the password in the bios in the HP EliteBook 8440p computer, I disconnected the batteries on the motherboard for 10 min, the laptop appeared a message that there was a reset, after a while the message asking for entering the password appeared again, I want to get to the bios to set boot from the CD and install the system.
  • #4 16585463
    Adri9700
    Rate: 11
    I turned to HP for help in removing the password, after completing all procedures (ID card photocopy, hardware user's statement, photo of the "system information" tab available after pressing the F1 button during the POST phase), in return e-mail I received the SMC.BIN file using whose password from the BIOS should be removed.
    A description of the entire procedure for removing the administrator password from Bios was sent to me,
    identically as on the website http://www.nhl.pl/index.php?showtopic=74953.
    I tried to run a file from a USB stick, which I placed in the USB socket, unfortunately the file did not work in Bios, the message SMC comand failue popped up, I also checked if the file would run from the root directory of the D: HP_TOOLS partition, suming up on the first attempt I was unable to remove the password.
