Can GIRA radio receivers be added without altering the existing installation?
nicholasp 4131 24
Can I add Gira wireless lighting control to an existing apartment installation without major changes to the walls and ceilings?
Yes, the thread points to Gira’s Funk-Bussystem as the retrofit option for wireless lighting control [#11596785] For a one-room setup it was said to be feasible, but for several rooms it was said not to work well, so the exact layout matters [#11598447] You should have an experienced installer or company draw up the design, because the number of light sources, wattage, and switching points all need to be matched to the system [#11599005] For the described lighting load, one suggested parts list was 1113100, 1111100, 041300 x3, 080900, and 0211505 x2, at roughly 4,000 total [#11598976] The system was also described as expensive, and the price list was called “astronomical” [#11597536]
  • Adding GIRA radio receivers without rewiring walls
    #1 11595625
    nicholasp
    I already have the entire electrical installation in my flat.
    Today I came across the GIRY radio system, which allows for multiple buttons on a single column.
    Is it possible to add radio receivers without causing too much disruption to the ceilings, walls, etc.?
    I don’t have a server; this isn’t a smart home.
    Link to the transmitter: http://www.gira.com/en/produkte/funk-wandsender-flach.html
    Best regards
    Nicholas
  • #3 11597077
    nicholasp
    Does anyone know the approximate cost of such a system?
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Here’s the Gira price list, Link , but the prices are astronomical. I’ve installed quite a bit of their fittings, and sometimes you have to wait a long time for your order to be processed. Interestingly, a lot of the components are compatible with the higher-end Berker models, and the price is half as much.
  • Berker component quality depends on production origin
    #5 11598230
  • #6 11598257
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Yes, but, for example, the glass frames are identical, and the Berkera ones are half the price; and when it comes to frames, it doesn’t matter at all whether they’re Chinese, Czech or French.
  • #7 11598270
    nicholasp
    That’s true. Could someone please post the exact products I need? I’d be very grateful, as I don’t know anything about this yet :)
  • #8 11598278
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    What would you like to use it to control?
  • #9 11598280
    nicholasp
    Lighting only :)
  • #10 11598419
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Which series are you interested in? And, above all, how many points would you like to manage? From how many locations? If I were you, I’d put together a quick simulation of your requirements and send it to tema.pl so they can draw up a quote for you.
  • #11 11598440
    nicholasp
    Radio, black glass.
  • #12 11598447
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    If it’s just one room, I can have a go, but if there are more, it’s not going to work.
  • #14 11598476
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Well then, tell us what it’s supposed to light up, because surely it’s not just a single light bulb above the table in the living room? :D
  • #15 11598487
    nicholasp
    3 double spotlights, ceiling LEDs and 6 single spotlights (in a staircase arrangement)
  • #16 11598506
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Fudging the figures? I sort of get it – from two sources?
  • #17 11598513
    nicholasp
    There’ll be three double spotlights on a dimmer switch, but otherwise not.
    Yes, the staircase has two light fittings because those five little lights are sort of like the hall.
  • #18 11598530
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    There’s also the option of using a remote control.
  • #19 11598535
    nicholasp
    I’d rather not add to the cost; I’m doing this so that everything can be conveniently controlled with a single switch.
    It would be a nice feature to have on an iPhone, but that’s getting into the realm of smart homes and the like.
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    I’ll send you that breakdown tomorrow; I can’t be bothered to do it today.
  • #21 11598563
    nicholasp
    Thank you :)
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    You’ll need the following items: 1113100, 1111100, 041300 x 3, 080900, 0211505 x 2. When you place your order, ask if that’s everything. It’ll come to about 4,000.
  • #23 11598987
    nicholasp
    Thank you very much for your help; thanks to this, I can now see how to choose the rest of the décor for the whole flat.
    I’m sending them an email: :)
  • #24 11599005
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    But I’d still recommend getting someone experienced to help with the selection – it’s not as straightforward as it seems. You need a design, the wattage, the number of light sources and so on.
  • #25 11599009
    nicholasp
    I’d like to ask someone from the company to work it out and check whether this is feasible at this stage.
