Amica Built-in Oven Tripping 25A Differential Fuse After an Hour of Operation: Fuse Issue?
jac0205 41835 17
Why does a built-in Amica oven trip the 25A/30mA differential breaker after about an hour of operation, and is the breaker itself faulty?
The oven is probably leaking current to ground from one of its heaters or heater wiring, not tripping because of a bad fuse; the 25A/30mA device is a residual-current device, and in this case the fault was ultimately fixed by replacing the upper heater [#11622746][#11696126][#11729174][#13591325] Start by checking insulation resistance from the heater to ground with a proper insulation tester/megger, because a normal multimeter may not reveal the breakdown [#11622746][#11696349] A hot-air heater was suspected first and replaced, but the problem remained until the upper heater was changed [#11668454][#11729174] If the oven still trips after a heater swap, the fault may be in another live part or its wiring inside the oven rather than in the breaker itself [#11696126]
  • #1 11622689
    jac0205
    Rate: 102
    After turning on the Amica oven (built-in), after about an hour of operation, it trips the differential fuse - 25A with the TEST button. The oven and the installation are less than 4 years old.
    It also happens after disconnecting the plugs from the sockets of other devices (dishwasher, fridge, TV, computer, washing machine, light). The fuse is not too warm, and you do not smell any suspicious odors by the oven. Was it a fuse?
    Trull
    Help: 138
    Rate: 600
    A breakdown on one of the heaters to ground, I would bet on the bottom or hot-air heater. Measure against ground on a 20M? meter measurement.
  • #3 11623711
    jac0205
    Rate: 102
    Well, it's rather a hot-air heater, because basically only this is used.
  • #4 11668454
    jac0205
    Rate: 102
    Heater replaced. We'll see if it helped ...
  • #5 11690921
    jac0205
    Rate: 102
    And linden.
    The same thing ... Is it possible to check the disassembled (allegedly damaged) heater if it has any punctures? If I have to replace the remaining heaters, it is probably better to buy a new oven. The replacement cost me PLN 130, I wanted to do it myself, but the rear panel resisted and there was a fear of breaking a cable.
  • #6 11691848
  • #7 11692017
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    skryn wrote:
    Of course, you have to call a decent electrician for the installation, not one from the "round-up" ...
    By the way, there is a chance that a decent electrician will be able to perform basic measurements and make sure whether the oven or the switch itself is damaged.
  • #8 11692102
    LiutenetMaria
    Help: 59
    Rate: 210
    Give the designation of this "fuse".
  • #9 11693758
    jac0205
    Rate: 102
    Written from the fuse:
    EFI-4
    25A I AN 30mA
    AT N ~ 400V
    3000 A.
    22.5 kA2s
    4 pol. IP40
  • #10 11694515
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    jac0205 wrote:
    25A I ?n 30mA
    So we go back to the starting point - you have to check whether the oven or the switch is damaged (by the way is not is a fuse).
  • #11 11695764
  • #12 11696126
    sebastian.rak
    Help: 10
    Rate: 31
    (Well, now I will probably expose myself to the admin)
    secretary
    First. Why would you want to replace an item that is not showing signs of damage so far - this is it residual current device and so far it seems to fulfill its function in the installation.
    Secondly. Why "From the oven, wara ..." if there is a problem only during its operation:
    "This also happens after disconnecting the plugs from the sockets of the rest of the devices (dishwasher, fridge, TV, computer, washing machine, light)"
    jac0205
    First, it must be clearly stated whether the oven or the RCD is damaged.
    If you only have a problem with the oven working, the problem will be with it.
    30mA is enough for the RCD to trip.
    Puncture does not necessarily occur on the heaters. The heater power cables may be damaged, as well as other elements that are live while the oven is in operation.
    If you do not have a meter to measure insulation resistance, look for a good electrician who will have one. Measurement with an ordinary ohmmeter or multimeter may not be sufficient to show breakdown.
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1623
    jac0205 wrote:
    And linden.
    You can see that you have excess money. You need to know what you are doing and why, so you can start with the oven and finish the replacement of the entire installation. Wouldn't it be cheaper to call an electrician? - because with the universal meter you could check the heater (if you can) and not replace it.
    This advice is dictated by our concern for you, because from what you have done, I do not advise you to check anything with a meter, let alone under voltage, because you have no idea about it.
  • #14 11697410
  • #15 11697911
    jac0205
    Rate: 102
    buddy Topolski Mirosław: the equipment has been returned to the service.
    Right, I don't know anything about it, so that's why I entrusted it to a professional. However, as it turned out, he was rather a pseudo-specialist. I described the problem to him and he said it was 100% heater and he replaced it, but the problem did not disappear. I go to this establishment again after Christmas.
  • #16 11729174
    jac0205
    Rate: 102
    The problem seems to be resolved.
    The power magician came, measured, examined, looked and replaced the upper heater. Oven checked for several hours. Nothing happened.
  • #17 11730769
    Topolski Mirosław
    Help: 355
    Rate: 1623
    You do not write anything about your visit to this plant. Was it an authorized home appliance service or an electromechanical plant?
    PS
    Electric magician who is this some shaman from the African bush? (this is a technical forum)
  • #18 13591325
    jac0205
    Rate: 102
    Replacing the top heater solved the problem.
The discussion revolves around an Amica built-in oven that trips a 25A differential fuse after approximately one hour of operation. Users suggest that the issue may stem from a breakdown in one of the oven's heaters, particularly the hot-air heater, which is commonly used. Several participants recommend measuring the heater's resistance to ground and checking for any damage to the power cables. After replacing the hot-air heater, the problem persisted, leading to further investigation. Ultimately, a professional technician replaced the upper heater, which resolved the issue, indicating that the original diagnosis was incorrect. The importance of consulting a qualified electrician for proper diagnostics and repairs is emphasized throughout the discussion.
