Amica EB7542 - oven wrong temperature the light disconnects cause?
leon100 7143 9
Why does my built-in Amica oven overheat far above the set temperature even though the heating light goes out, and is the thermostat/thermoregulator the cause?
Yes—the mechanical thermostat/thermoregulator is the likely fault, and replacing it fixed the problem. One reply identified it as a standard mechanical thermostat rather than electronic control and recommended replacing the thermostat [#16876819] The original poster later confirmed that after replacing the thermostat with a replacement part, the oven worked correctly again [#16882924] The replacement thermoregulator cost about 45 PLN, and the access steps were to remove the oven, unscrew the rear top cover, then remove the front knob and controller [#16883458]
  • #1 16876157
    leon100
    Rate: 12
    Built-in Amica oven. It burns at the set temperature of 100 ° C on the knob, I put the thermometer in the middle and it shows 250 ° C, and at 50 ° C on the knob it really is about 200 ° C ... The red lamp that lights up while the oven is heating up turns off after heating up yet the oven does not maintain the set temperature. Is it also the fault of the thermoregulator?
    kot mirmur
    Help: 206
    Rate: 561
    Hello, 100 percent yes. Can you provide the oven model?
  • #3 16876268
    leon100
    Rate: 12
    Today I will disassemble it, I don't know the model I bought 5 years ago, but it looks like this:
    Link
  • #4 16876339
    kot mirmur
    Help: 206
    Rate: 561
    The temperature sensor may have fallen off. Available e.g. at NORTH.pl 97 PLN ..
  • #5 16876583
    leon100
    Rate: 12
    And how to check that it is a temperature sensor and how to replace it?
  • #6 16876697
    kot mirmur
    Help: 206
    Rate: 561
    I haven't had a chance to play with an oven like this, but the sensor is definitely mounted in the back wall, on top of the oven. See the photo from the website North.pl. You will unscrew the rear cover of the oven, you will definitely find it, the assembly is two nuts or bolts. As for the parameters - it is definitely an NTC sensor, but I can't find anything. Maybe these are just the burnt ends of the connectors of this sensor? Did you use this pyrolysis?
  • #7 16876819
    bubu64
    Help: 57
    Rate: 283
    Judging by the photo, we are dealing with an ordinary mechanical thermostat, not with an electronic control :)
    In my opinion, to replace the thermostat :)
  • #8 16882924
    leon100
    Rate: 12
    The stove after replacing the thermostat with a replacement and everything works ok.
    At the beginning, the thermometer in the center showed 30 ° C more, but it was placed on a baking sheet and hence the difference I think. On the grate it shows OK.
  • #9 16883418
    Kartonik102
    Hello, I have the same problem with this model if you replaced this thermostat yourself and what is the cost
  • #10 16883458
    leon100
    Rate: 12
    Yes. I replaced it myself. replacement thermoregulator cost PLN 45. Remove the oven, unscrew the top rear cover. Remove the knob at the front, remove the controller.
The discussion revolves around an Amica built-in oven exhibiting incorrect temperature readings, where the set temperature of 100 °C corresponds to an actual temperature of 250 °C. Users suggest that the issue may stem from a faulty temperature sensor or thermostat. One participant confirms that after replacing the thermostat, the oven functioned correctly, with only minor discrepancies in temperature readings attributed to the placement of the thermometer. Instructions for checking and replacing the thermostat are provided, indicating that it is located at the back of the oven and can be accessed by removing the rear cover. The cost of replacement parts is also discussed, with prices around 45-97 PLN.
