Which DIN rail dimmer modules support soft-on/off, scenes and MASTER OFF?
Dj.MaX 5076 8
  • #1 11633231
    Dj.MaX
    Hello everyone,
    I’ve got quite a conundrum: following the refurbishment of the lounge, I’ll have around 6–8 independent lighting circuits.
    I’d like each of them to be dimmable; I’m planning to achieve this using push-button switches and dimming modules housed in the distribution board (the whole installation will be star-shaped).
    My wife wants the system to have a soft fade-in and fade-out function.
    Do you know of any specific modules that offer scene dimming and brightening functions, including a gradual fade-in when switched on and a gentle fade-out when switched off?
    It would be great if we could also add a MASTER switch to turn off all circuits.
    I hadn’t really planned on using PLC modules, due to the cost; I’d also prefer a simple installation
  • #2 11656209
    Dj.MaX
    Does anyone have any ideas?
  • KNX dimmers provide soft transitions; PLCs lack dimming
    #3 11657325
  • #4 11657394
    Dj.MaX
    Could you recommend a specific KNX system, provided it’s reasonably easy to programme?
    I should also add that it’s important to me that it can be controlled via doorbell switches.
    KNX dimmer setup with binary inputs and LED caveat
    #5 11657491
  • Velleman VM101 and F&F SCO-815 alternatives
    #6 11658380
    Dj.MaX
    This is at least one solution worth considering.
    Personally, I’ve also found solutions using the Velleman VM101 MULTIFUNCTION DIMMER
    http://sklep.avt.pl/p/pl/485978/wielofunkcyjny+sciemniacz.html
    And also the F&F SCO-815, which will be available from the new year, although the dimming only works whilst the switch is held down, which won’t be entirely practical.
    I reckon I’ll definitely go for one of these solutions – I’m sure I’ll find the budget for it :) Do you have any other ideas?
  • KNX dimming controls and special glass switch cabling
    #7 11658439
  • Seeking affordable 4-8 circuit soft-on/off dimmer
    #8 11658529
    Dj.MaX
    I’ll write down exactly what functionality I need once again (the things one does to please one’s wife)
    I want to control the lights on 4–8 circuits using a two-way switch. The most important thing is that it has a soft-on and soft-off function. Holding the switch down for a long time should brighten or dim the light.
    A memory function and the option to add a master switch to turn off all circuits would be welcome.
    The Lutron controller :) perfectly meets these requirements, but you can probably guess why I’ll be giving that one a miss – I’m simply looking for a cheaper alternative.
  • KNX meets requirements, while Lutron is costly and proprietary
    #9 11658571
