1.
Does anyone know of a ready-made solution that would allow control via relays of
2 garage doors
2 lighting systems
Controlled via an Android system and a web interface
I’m looking for a solution that even a complete novice could connect and set up
2.
BTW, for my own needs I use the Integr 64 with MobilekPD2 Pro and Marka support; it works really well, but I’m running out of outputs.
Which additional output expander is best to choose?
Does the DIN-rail version differ in any way apart from the price?
Once connected, is it simply a matter of selecting the device ID from the service menu?
Once the device is recognised, will the virtual outputs become active physical outputs?
At the moment, I’ve already used up all 30 virtual outputs – on which of these virtual outputs will the active outputs from the output expander appear?
Best regards,
DT
2 garage doors
2 lighting systems
2.
Best regards,
DT
