The message - we apologize, the selected number is not responding at the moment
62235 6
  • #1 11727290
  • #2 11727422
    andk1eltd
    Level 37  
    Help: 396
    Rate: 374
    The message is extremely precise in its message: no one answers the call - neither human nor machine, i.e. voicemail or answering machine. There can be two reasons: either they don't want to be taken away or they can't. In the latter case, it may be due to a line break (if there is no PG on the number).
  • #3 11727467
  • #4 11727561
    andk1eltd
    Level 37  
    Help: 396
    Rate: 374
    Yes. If the service were active, it would pick up the call if it weren't for a human. It is a software service and it does not matter what reason someone does not answer. In this case (with and without PG) it is impossible to determine whether someone is not picking up or there is a line break.
  • #5 11727577
  • #6 11727656
    andk1eltd
    Level 37  
    Help: 396
    Rate: 374
    It can be like that.
  • #7 11728262
✨ The discussion revolves around the message "sorry the number you have dialed is not responding at the moment" encountered when calling a landline from a mobile phone. Responses clarify that this message indicates that the call is not being answered, either due to the recipient's choice or a potential line issue. The absence of a voicemail or answering machine suggests that the line may be disconnected or experiencing a break. The conversation also touches on the possibility of the telephone being disconnected from the RJ socket, confirming that such a scenario could lead to the message received.
