Renault Espace IV: Fuse Box Locations & Detailed Fuse Descriptions (Engine & Glove Compartment)
technolo 131361 8
  • #1 11784623
    technolo
    Help: 9
    Rate: 66
    Hello and welcome
    Maybe the topic seems trivial, but it is not.
    Despite spending a lot of time with Uncle Google, I fail to find where the fuse boxes are hidden in this car.
    I found two (in the engine compartment and on the left side of the board in the glove compartment) and there are probably four. However, it does not give me too much, because I do not have a description of what, under which fuse it sits.
    If someone has a list (preferably Polish) what, where and how, I will be very grateful.
    Interestingly, there is nothing in the car's manual. Eh French ........ :D
  • #2 11784752
    _Megamax_
    Help: 29
    Rate: 131
    As far as I remember, these are 4. Two on the driver's side, in the engine compartment - one is visible, and the other is quite hard to get to because it is in the apron recess. The other two are in the cabin, one on the driver's side and the other on the passenger's side, probably under the feet. I had this espace a few years ago, so I might be a bit wrong. As for the light fuses, they are in the second box I have described.
  • #3 11786182
    technolo
    Help: 9
    Rate: 66
    I need to know exactly where the washer pump fuse (if any) is.
  • #4 12366973
    kikasd
    Rate: 29
    My friend, there are four boxes, one in the glove box, the little one above the steering wheel, another in a small glove box at the counter on the passenger side (all under the gray carpeted bottoms.
    another box is in the engine compartment and another box is in the cabin under the left tweeter on the driver's side - but there is only one fuse for the vent.
    Regards
  • #5 12367050
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Here you have an item from the series I repair myself http: // xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx I think there is a fuse diagram.
    Moderated By T5:
    3.1.18. It is forbidden to publish information to sources that expire after a certain time (publishing links to pages of a short-term nature).
  • #6 12367088
    olo114
    Help: 14
    Rate: 95
    If the wiper switches on after activating the washer, the pump should be replaced or the harness is damaged.
    Regards
  • #7 13549821
    technolo
    Help: 9
    Rate: 66
    The pump failed.
  • #8 17955281
    Kubwodz
    Rate: 53
    I am looking for a list of espace 4 fuses. 2.0 T. More specifically, the fuse for the automatic parking brake. Thank you
The discussion centers around the locations and descriptions of fuse boxes in the Renault Espace IV. Users identify four fuse boxes: two in the engine compartment, one in the glove compartment, and another under the dashboard on the driver's side. Specific inquiries include the location of the washer pump fuse and the fuse for the automatic parking brake. A link to a fuse diagram is provided for further reference. Users also discuss potential issues with the washer pump and wiper functionality.
