[Solved] Renault Laguna III 1.5dCi - I can't find fuses from the outside lights
artur2891 34617 5
  • #1 17533939
    artur2891
    when replacing the bulbs from the license plate backlight one bulb was on and after inserting the other it stopped lighting and along with it the right parking light in the back. I think it might be the fault of the fuse, but I can't locate the fuses responsible for the lights. There are fuses on the left side of the steering wheel, but none of the exterior lights (except for the direction indicators) in the diagram. I know that there are also fuses under the hood at the controller, but there is no schematic there and I do not want to touch them without it. Maybe someone located them? Have a similar problem ...
    bubu1769
    Help: 1177
    Rate: 2374
    It is true that it is from Megane III but in Laguna it should be similar.
    Page 21 Fuse No. 1, flies above the battery next to the air filter.
    • PLATFUSI.PDF (521.76 KB) You must be logged in to download this attachment.
  • #3 17534536
    genek1000
    Help: 289
    Rate: 1057
    Could use a year yet because there were different types of fuse boxes
    bubu1769
    Help: 1177
    Rate: 2374
    I just found one more kind.
    Page 1 fuse F4, fuse box on the driver's side.
    • PLATFUSI.PDF (902.07 KB) You must be logged in to download this attachment.
  • #5 17534887
    artur2891
    Year 2008.
    I will check if this first scheme will match the layout (the box looks the same from the outside). The second diagram certainly does not match, because most of the fuses on it are inside but there are no those from the lights.
    Added after 43 [minutes]:
    Thanks, it worked, it was actually No. 1 fuse from the first diagram.
  • #6 17534936
    artur2891
    Year 2008.
    Fuse No. 1 from the first schematic that bubu1769 sent was responsible for the lights.
