Short Circuit in Renault Megane III Grandtour 2012: Fuse Location for LED License Plate Lighting
Andreastychy 14694 5
  • #1 16689867
    Andreastychy
    Hello, when replacing the license plate lighting for LED I did a short circuit, does anyone know where the fuse is located?
    Renault Megane III grandtour 2012
  • #2 16689880
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Is the fuse box missing?
  • #3 16689886
    Andreastychy
    Only which, in the cabin, there are fuses and under the battery, can not find a diagram anywhere.
    Added after 31 [minutes]:
    I ask which fuse and whether it will be under the battery or in the cabin.
  • #4 16689936
    jdubowski
    Help: 2511
    Rate: 2804
    I bet that it will be in the vicinity of the fuse from the position and passing lights.
    There are probably three fuse boxes in the car - under the bonnet, in the glove box and under the passenger seat.
    milejow
    Help: 1563
    Rate: 5149
    Fuse No. 1-7.5A on the UPC module next to the battery.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #6 16690082
    Andreastychy
    Thank you for your help, exactly the fuse is located next to the battery in the security and connection module. F1 fuse (10A)
