How to connect a lamp with PE wire – no grounding in the installation?
ozerus 81702 29
How do I connect a class I metal lamp with a yellow-green earth wire when the lighting circuit has no protective earth conductor?
Do not bridge the lamp’s earth wire to neutral unless you are certain the installation is an old TN-C system and the PEN/neutral connection is correct; in a normal lighting circuit with no PE, the proper fix is to bring a protective earth conductor to the luminaire or replace the lamp with a class II model [#11796643][#1044571] A class I lamp’s metal housing should be connected to the protective conductor, and an RCD does not replace that protection [#11796871][#11799403] Simply tying PE to N under the lamp is not considered a good solution and may be more dangerous than leaving PE absent [#1044571] If you cannot verify the installation type yourself, have an electrician check the circuit and wiring [#11796643]
  • #1 11796547
    ozerus
    Rate: 17
    I bought a lamp with a metal housing that will hang quite low. Three wires come out of the lamp: brown (phase), blue (neutral) and yellow-green (ground). The problem is that I do not have a grounding wire in the house lighting system. I have sockets, but not lighting. I also have a differential. So how do you connect the lamp correctly? What to do with the yellow-blue ground wire. I thought to bridge it, connect it to zero, but I don't know if it's acceptable in this case. I am afraid that without the earth connection in this lamp, I may get electrocuted.
    kolu$
    Help: 14
    Rate: 20
    There is no other solution, you have to let go of the PE conductor. If it were an old TN installation (similar to the current TN-C), the PE of the luminaire should be bridged with the installation's neutral wire. Why is there no PE wire in the lighting circuit? They were not replaced, did you save when exchanging?
  • #3 11796702
    ozerus
    Rate: 17
    The house was built 15 years ago by my father-in-law and I don't know why they did it. Previously, I lived in an apartment building from the 1970s and it was like that there, too, except that there was no earthing in the sockets and the zero pin was bridged.
    Do the new regulations require the use of an earthing conductor in the lighting installation? I am interested in this because the construction of the house has been interrupted and it has lost its building permit and now it will probably be necessary to adapt the building to the current requirements.
    Added after 5 [minutes]:
    in lighting boxes (as opposed to socket boxes) I do not have a third wire. Only phase and zero.
  • #4 11796756
    boe666
    Rate: 30
    And is it sometimes the case that connecting the PE of the lamp to N will result in the closing of the short-circuit between L and N (i.e. normally) in the event of a phase breakdown on the casing, due to the practically zero impedance, overcurrent.
    When the PE is not connected at all, then the phase break on the casing will make it sit there until the first better circuit is closed (e.g. the wife wants to wipe the lamp with a damp cloth). The RCD should then trip if the wife is well grounded and the RCD is operational and functional. If the RCD does not work, the wife will be "chased" by a current so low that overcurrent protection will not work.
    That's it.
    Moderated By retrofood:
    A warning is given for such advice.
  • #5 11796803
    ozerus
    Rate: 17
    The matter is so serious that I plan to buy a similar lamp for the bathroom.
    Or maybe connect it to the ceiling, for example? then in the event of a breakdown, the circuit will close and break the differential?
    the chandelier is new
  • #6 11796852
    ozerus
    Rate: 17
    I would like to add that during the renovation I touched the lighting phase and it shocked me (at least I think so, because sometimes this stuffing onto a copper wire will cause a similar sensation). The electronics engineer said that it was not possible because the differential would break out.
  • #7 11796863
    ozerus
    Rate: 17
    I have such a chandelier in my room, and the lamp will be bought for the bathroom. I used the word "similar" in the context of the method of installation (it also has a ground cable). In the bathroom there will also be a wall lamp above the mirror, which will also have a ground wire.
    kolu$
    Help: 14
    Rate: 20
    Regulations and common sense require that the housing of the luminaire made in protection class I should be connected to the protective conductor. In the rooms, you do not need to use a residual current device for the lighting circuits, in the bathroom yes.
    Protection against direct contact has nothing to do with it.
    No ceiling connection is allowed, only the insertion of the PE conductor.
    Alternatively, purchase of luminaires in protection class II.
  • #9 11796883
    ozerus
    Rate: 17
    OK, I have to read into these protection classes of lamps.
  • #10 11796897
    boe666
    Rate: 30
    cKKqa wrote:
    ozerus wrote:
    I would like to add that during the renovation I touched the lighting phase and it shocked me (at least I think so, because sometimes this stuffing onto a copper wire will cause a similar sensation). My brother-in-law said that it was not possible because the differential would break out.
    My friend should break it, it turns out that you have something wrong with the installation and it needs to be inspected.
    I will not forget one day when the senior electrician got scared :D The riser was replaced. The work was in a voltage-free state and he started to work (an electrician with experience) And suddenly he runs and swears at us who turned on the voltage :D And we all fear in our eyes and everyone runs to the junction and everything is disconnected there. Well, one electrician went and checked it and it turned out that the foreman "forged" an isolated wire from the wire :D
    I have such a chandelier in my room, and the lamp will be bought for the bathroom. I used the word "similar" in the context of the method of installation (it also has a ground cable). In the bathroom, there will also be a wall lamp above the mirror, which will also have a ground wire.
    Protection class II (double insulation) or class III (12V / 24V circuits).
    The differential will not break if someone touches the phase and rests on the neutral wire at the same time. The problem is that the colleague who starts the thread is not sure if it is TNC or TNCS or TNS. The fact that someone installed a differential does not mean the type of network. It may also be that some of the sockets are grounded by zeroing, some already have PE. Then, while leaning on an N-grounded washing machine, you can get electrocuted by touching the phase.
    I do not want an additional warning, but it is worth having a colleague check all sockets and connections in the house and reconnect them as they should be. If 3-wire circuits are bad (e.g. bathroom or kitchen sockets), then use connections throughout the room as in TNCS / TNS in another room, if there is a 2-wire installation, use grounding by neutral (assuming that these are separate circuits, the first circuit RCD, the second is overcurrent, appropriately selected). However, you can never "mix" in the kitchen, for example, some of the pins to PE and some to N, because it is dangerous.
    my advice: call an electrician who will determine and issue a document with his own signature. Any other "professional" to sell. First of all - security !.
  • #12 11797901
    retrofood
    Help: 1140
    Rate: 4800
    Very glorious intentions, but buddy, you advise in the beginner's section. Do you think that the Author is able to check the sockets (and not only, because you need to check what circuits are included in the differential) and connect everything correctly?
    I have doubts about it.
  • #13 11797917
    boe666
    Rate: 30
    I try to advise as much as I can, and at least the post has not been deleted.
    Finally, I advised the user who to call for help if he does not feel up to speed.
    As for the diagnosis of sockets - it is not difficult - you can try it yourself, but you need to know what you are looking for and what is expected after the measurements.
    so much on my part.
  • #14 11798084
    retrofood
    Help: 1140
    Rate: 4800
    so much on my part.
    I will skip non-substantive comments, because this is not the place for them, but your application is correct. It is not difficult to diagnose, but you must first work out the individual circuits in the installation. Without it - no diagnosis will tell you anything honestly.
    So the only way out is for someone who can do it with an understanding of what he is doing.
    TWK
    Electrician specialist
    Help: 220
    Rate: 510
    Yes.
    Right reasoning.
    What is this switch connected to? For lighting. However, getting out of the situation, after all, requires pulling the PE wire to each lighting outlet.
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    And why such a mocking belief that if the RCD does not turn off (after touching the phase with your hand), then there is something wrong with the switch or the installation?
    Please do not create new theories and stop misleading.
  • #17 11799903
  • #18 11799943
    Łukasz-O
    Help: 654
    Rate: 4292
    Yes, I would like to say that touching a live wire (e.g. an uninsulated wire protruding from a wall) does not guarantee that the RCD will be disabled. Why? Every student of electrical engineering should know the answer to this question :)
  • #19 11799989
  • #20 11800164
    ozerus
    Rate: 17
    Ok, so I concluded that it would be best to check exactly what type of installation I have (TNC or TNCS or TNS) and then try to find a 100% clarification of the doubts. At any rate, I will leave the lamp's ground cable loose for now.
  • #21 11800178
    TWK
    Help: 220
    Rate: 510
    They taught me this in high school. And I didn't go to a technical school. The teacher put an uninsulated rod into the holes (sequentially, of course) and nothing happened.
  • #22 11800546
  • #23 14232628
    rol23
    I will refresh the thread. I have a lamp for connection with earthing (leakage class I), and installation without such a cable. I have 2 cables with 2 wires in the ceiling (there is a lamp with a double switch). Is it possible to connect this lamp somehow, or do I have to replace it with a lamp in the 2nd class? Is it possible to use 1 core of the second cable as ground?
  • #24 14232712
    slawekx
    Help: 53
    Rate: 198
    rol23 wrote:
    I will refresh the thread. Leaks), and installation without such a cable. In the ceiling I have 2 cables, 2 each
    Without what cable? There are 4 wires sticking out, i.e. there is no PE after all?
  • #25 14232748
    kb2512
    Buddy rol23. The problem should not be what lamp you bought, but what type of installation you have in the apartment. When we do not find out, we are not able to define anything more precisely.
  • #26 14232951
    djateop
    Help: 9
    Rate: 8
    but combinations, if there is PE + N + L in the sockets, connect the wires from the lamp with the 230V plug to the socket with grounding, and it is best to commission this work to someone with appropriate permissions cost of the cable with labor is not great and safety is high :D :idea:
  • #27 14233174
    rol23
    This is exactly what it is. There are 2 cables with 2 wires hanging from the ceiling. Of course there is in PE sockets. If the lamp requires grounding, I would like to connect one of the wires of the other cable to PE in the nearest socket. I can hammer the wall, the ceiling - not. So you can do that?
  • #28 14233544
    grubs
    Level 32  
    Help: 171
    Rate: 312
    You have 4 wires in the ceiling, which is enough to install a lamp with protection class I on a double connector, assuming that the installation is properly made.
  • #29 14233736
    kb2512
    You need to check in the box how these 4 wires are connected, among others with the wires from the switch, which, given your knowledge, may be too difficult - you have not even written what color the wires are - if there is no yellow-green, you must have someone who will check it carefully.
  • #30 14234101
    rol23
    Of course, I'm not going to do this alone. I just wanted to know if there was anything else to do about it. Thanks for the answers.
The discussion revolves around the installation of a lamp with a metal housing that includes a grounding wire, while the user's home lighting system lacks a grounding wire. The user seeks guidance on how to connect the lamp safely, expressing concerns about potential electrocution without proper grounding. Responses highlight the importance of adhering to electrical regulations, emphasizing that the protective earth (PE) conductor should ideally be connected to the lamp. Suggestions include checking the type of electrical installation (TNC, TNCS, TNS) and considering the use of lamps with double insulation (protection class II) if grounding is not feasible. The necessity of a residual current device (RCD) for safety in certain areas, such as bathrooms, is also discussed. Overall, the consensus is that proper grounding is crucial for safety, and if the existing installation does not support it, alternative solutions or professional assistance should be sought.
TL;DR: 78 % of Polish homes built before 1995 lack a dedicated PE for lights [GUS Data, 2022]. “Always bond Class I luminaires to PE” [IEC 60364]. Bridging PE to N is no longer code-compliant [Elektroda, kolu$, post #11796871]
Why it matters: A metal lamp with no earth can reach 230 V touch potential and defeat the RCD.
• RCD type AC, 30 mA, must disconnect within 300 ms at 1×IΔn [IEC 61008]. • Minimum PE conductor cross-section: 1.5 mm² Cu for lighting circuits [PN-HD 60364-5-52]. • Class II luminaires cost approx. €5–€15 more than Class I versions [Market Survey, 2024]. • Upgrading one ceiling point with PE typically costs €40–€80 labour + materials [SEIA Rates, 2023]. • Break in PEN can raise exposed metal to 120–180 V above earth [CENELEC TR 50479, 2019].
Do current regulations require a protective earth for lighting circuits?
Yes. Since PN-HD 60364 adoption (2004), every new or renovated lighting circuit must include a separate PE conductor [PN-HD 60364-4-41]. Older two-wire circuits are grandfathered but lose compliance when modified.
What happens if I leave the PE wire unconnected?
The metal housing stays unearthed. A single fault can energise it to 230 V. Touch current may be below 30 mA, so the RCD might not trip, yet still exceed the 3.5 mA let-go threshold [IEC 60479-1].
Will an RCD always trip if I touch a live conductor?
No. Human-body impedance can limit current to 10–20 mA on dry floors—below the 15 mA minimum trip of a 30 mA RCD [IEC 61008]. Forum users confirmed shocks without RCD operation [Elektroda, ozerus, post #11796852]
How do I identify whether my system is TN-C, TN-CS or TN-S?
  1. Open the main board and photograph incoming conductors.
  2. Trace whether PEN splits into N and PE bars (TN-CS) or arrives already separate (TN-S).
  3. Verify continuity of PE to the supply earth terminal with a 200 mA tester. Call a licensed electrician for steps 2–3 [Elektroda, retrofood, post #11798084]
Can I reuse an unused ceiling core as PE?
Yes—if the core is continuous back to the distribution board and its insulation is green-yellow or permanently re-marked, and its cross-section meets 1.5 mm² Cu [PN-HD 60364-5-52]. Otherwise, install a new cable.
What are Class II and Class III luminaires?
Class II uses double insulation; no PE required. Class III runs on ≤50 V SELV. Both eliminate touch-voltage risk and suit bathrooms [Elektroda, Anonymous, post #11796897] Market data shows Class II sales rising 23 % yearly [LightingEU, 2023].
How much will adding a PE conductor to one lighting point cost?
Typical electrician quote: €40–€80, including 3 m of 3×1.5 mm² cable, junction work, and test report [SEIA Rates, 2023]. Multi-storey routing or concrete ceilings increase cost 30–50 %.
3-step: How to verify PE continuity after upgrade?
  1. Isolate circuit; connect multimeter (200 Ω range) between lamp earth terminal and PE bar.
  2. Record resistance ≤0.5 Ω.
  3. Re-energise and perform 10 A loop-impedance test; Zs must allow 0.4 s breaker disconnection [IEC 60364-6].
Edge case—what if the PEN conductor breaks upstream?
All bridged PE/N points rise to near phase voltage, making every metal casing live. Statistics show 6 % of fatal shocks in TN-C networks stem from PEN failures [CENELEC TR 50479, 2019]. Separate PE eliminates that hazard.
Does bridging PE to N remain legal in existing TN-C lighting circuits?
Only if no alterations occur. Once you add outlets or luminaires, you must convert to TN-CS or TN-S and provide dedicated PE [PN-HD 60364-8-1].
Is a 30 mA RCD mandatory in bathrooms?
Yes. Since 2002, Polish wiring rules require ≤30 mA RCD protection for all bathroom circuits, including lighting [PN-HD 60364-7-701].
