Purpose of L (Live) and N (Neutral) Markings on Osram Electronic Ballast Connections
kamo_83 876670 28
Why does an electronic ballast have separate L (live) and N (neutral) terminals if the mains supply is AC, and what happens if I connect them the other way round?
For this ballast, swapping L and N will usually not damage the unit, but the markings exist for safety and for the way the internal circuit is designed [#5232680][#5238326] Manufacturers often place the fuse or thermal protection in the L path so that, when protection opens, the phase is disconnected instead of leaving the circuitry live [#5233458][#5235291] L is the live conductor and N is the neutral, so correct connection reduces the chance that exposed parts or a metal housing remain at mains potential [#5232680][#5233679] If the ballast or luminaire has a metal housing, it should be connected to protective earth (PE/PEN) as specified; the N terminal is not the same as the housing connection [#5235745] So the answer is: it will often still work, but the manufacturer’s L/N marking should be followed because it improves safety and ensures any internal protection works as intended [#5238326][#5235291]
  • #1 5232133
    kamo_83
    Rate: 30
    I warmly welcome! he writes right away that I am a complete layman in the field of electricity, but I have encountered such a problem, maybe someone will help me .. by installing a fluorescent lamp with Osram's electronic ballast, I have written on the L and N inputs since the current is alternating (I know), why differentiate on L and N what will happen if I connect the other way? can someone explain it to me?
    Thank you very much to all professionals for their understanding .. :)
    tronics
    Help: 358
    Rate: 838
    L - phase
    N - neutral wire (zero)
    Why differentiate? Well, probably for convenience, as there is a well-designed network and we have 3 cables ... one black (or brown), 1 blue and 1 green-yellow, it's fun to work knowing that green-yellow is PE, blue is neutral (N) and only brown or black can kill us ^^
    the functionality of the network does not change, but the aesthetics are 'slightly' :)
    patryk-84a
    Help: 40
    Rate: 211
    Touching the L conductor can kill you, touching the N conductor shouldn't kill you, and that's the difference between them. In the case of receivers, it does not matter which wire we will give N and which L, not too much for an ordinary user, but for installers, yes. And I will add that in the 3f installation, the replacement of the N and L conductors is very important :) .
  • #4 5233458
    einstal
    Rate: 69
    Complementing the statements of colleagues, for example, the power supply in the computer has a fuse on the L. If the power socket is properly connected (i.e. looking at the pin at the top, L on the left, N on the right), then in this power supply, after the fuse blows on the board, there is no phases. If you have the opposite, there is a phase on the entire power supply board. And when there is no protection cable in the socket, mains voltage may appear on the computer casing!
    THEREFORE IT IS IMPORTANT TO GROUND THE 230V OUTLET IF THE DEVICES HAVE SUCH EARTH PLUG!
    Again, looking at the 230V socket: If the pin at the top is L on the left and N on the right!
    best regards
    Madrik
    Help: 622
    Rate: 1163
    Because, despite the alternation of current, the phase, i.e. L, is directly connected to the voltage source - the transformer winding.
    N - that is, zero, is connected to the transformer neutral point.
    This means that on the L, while the current is not flowing, you have a constantly dangerous potential - in short.
    On N, this potential is much lower.
    Therefore, the manufacturer means where you should connect the wires, because some home-grown neon lamp expert would give the phase to the housing and hurt someone.
    And when he does it, and the sex flows, it will not make any difference to the connected person whether the current changes and from which side ...
    Kanar
    Rate: 38
    best regards
    It's not exactly like you write.
    The phase on the left side of the socket has nothing to do with the correct connection of the socket, it proves something else. Example: double socket, phase wire connected on the left side: plug inserted at the bottom - phase on the left; plug inserted from above: phase on the right.
  • #7 5234117
    Quarz
    Help: 1646
    Rate: 626
    best regards
    But this is the case of a bygone era when this principle was not respected in Poland ... :idea: :cry: ... and that's how we got it ... 8-O
    See, check, similar nests at their western neighbors, or in Hameryce ... :D
  • #8 5234552
    kamo_83
    Rate: 30
    thank you for your answers :) I understand that it does not matter much for the system itself .. ie the ballast circuit will not be damaged if I connect it differently .. The LN designation is used for safety reasons .. so that someone does not accidentally connect to the current .. is he reasoning correctly?
    niutat
    Level 36  
    Help: 288
    Rate: 756
    safety as well, but there are cases where L and N must be in their places, e.g. some gas stoves and gas water heaters. Besides, in electric boilers, if L was not turned off by the thermostat, the heater would be energized all the time, the breakdown of the heater insulation could lead to until the boiler explodes.
  • #10 5234931
    einstal
    Rate: 69
    Buddy Kamo_83, you get it right. For your safety, in such systems that you build (prototype) you can use fuses on two wires L and N - e.g. 1Amper. After checking the correctness of operation, connect to the installation without fuses.
    Good luck in discovering the secrets of electrics.
    best regards
    Buddy Kanar, can you develop the thought: 'connecting the socket proves something else'
    There are double sockets that follow this rule - but they are more expensive. Personally, in such cases, I try to use single sockets, and use an extension cord to separate the receivers. In any case, it is important to connect the protective conductor (PE or PEN) to the pin.
    You have to ask yourself what is more important, Comfort or SAFETY? I bet on the latter!
    best regards
  • #11 5235067
    kamo_83
    Rate: 30
    Thank you very much for the fact that such a large group of experts answered the question of the rookie that I undoubtedly am .. your tips are very important and interesting, although I do not fully understand everything
    I have a request..
    Could someone else help me with some information about lighting, ballasts, fluorescent lamps .. I mean practical information from professionals :) and not theoretical information incomprehensible to the average bread eater :) Is there any good literature on this matter? advise ..
    I hope for interesting entries so far :)
    einstal
    Rate: 69
    I recommend reading: http://bezel.com.pl/instalacje.html
    If you don't understand something, ask. In my opinion, it is best to learn from the relationships of life. Theory is important, but you won't understand it without practice.
    Good luck
  • #13 5235135
    kamo_83
    Rate: 30
    This is the Osram ballast .. there is L and N, since it does not matter where we give L and where N because the current is alternating, why the manufacturer puts such a marking ... so that he is not shocked by electricity during the assembly / disassembly of such a contraption :) maybe that's why not to give L to N because it could give the current on the ballast housing .. the ballast itself would work normally .. sorry for maybe stupid questions ... for professionals this may seem like a horror .. but thank you for your understanding :)
    Added after 4 [minutes]:
    nice site :) I'm already checking out
  • #14 5235291
    einstal
    Rate: 69
    If the manufacturer has marked L and N, it matters.
    For example: the transformer has a thermal 105'C on the contact marked 1 or L, there is no phase in this transformer after such protection is activated! Transf. it could have been flooded with water beforehand so the temperature rose and everything is OK. Now reverse the situation - the phase will be on the transformer housing even when the protection is triggered.
    In the case of your ballast, there is definitely documentation on the basis of which standards it was built and what it is secured. has.
    PS
    Is the housing metal? Is the word "PE" or the symbol "earth"?
  • #15 5235411
    kamo_83
    Rate: 30
    the housing is metal .. there is no PE or earthing symbol .. and I have read that it should be earthed e.g. by using a screw with a crown washer if it is attached to a metal lighting fixture ... additional such fixture should be earthed with a PE or PEN protective conductor .. just will anyone tell me what is this subtle difference between PE and PEN? :) .. because if the ballast is grounded .. to the luminaire and it is connected with a protective conductor, even if we replace L with N and there is a voltage on the ballast housing, it will be discharged through the protective conductor anyway, right? :) I don't know if he reasoned well ..
    einstal
    Rate: 69
    -in the new PE installation, it is yellow-green connected at the network division point (see the diagrams from the link I gave you), while N is the working wire. The blue wire should be treated like a phase wire, but that's another story for a dozen or so posts.
    - in old installations, the PEN is one conductor fulfilling two functions, protective and working. A more emergency solution when it comes to SAFETY!
    In the second case (.. because the ballast is grounded ..) it is different. The N connector is not connected to the ballast housing.
  • #17 5235769
    kamo_83
    Rate: 30
    I have already figured out what the LN designation is for .. maybe it's because this ballast turns off after exceeding the operating temperature .. well, if we replace L with N, then the protection may not work and the ballast will get stuck.
  • #18 5235808
    einstal
    Rate: 69
    ... yes, but these will be extreme emergencies, e.g. water in the device. Most often, the protection works and everything is OK even with a wrong connection.
  • #19 5236160
    Madrik
    Help: 622
    Rate: 1163
    Almost. For some devices, it is essential that L and N are correctly entered. There are also regulations and good habits, which are aimed at, among other things, that someone does not connect to the electricity, and that there is some order, and not everyone himself.
  • #20 5236198
    and61
    Help: 70
    Rate: 245
    Quarz wrote:
    Kanar wrote:
    ... The phase on the left side of the socket has nothing to do with the correct connection of the socket, it proves something else. Example: double socket, phase wire connected on the left side: plug inserted at the bottom - phase on the left; plug inserted from above: phase on the right.
    ... :D
    such sockets are still available for sale, for example those produced by Polo Optima
    and therefore if the company does not realize that it produces dud, you should not buy it in order not to hurt someone or yourself
    • Purpose of L (Live) and N (Neutral) Markings on Osram Electronic Ballast Connections gniazdo elektr z polo optimy.jpg (7.73 KB) You must be logged in to download this attachment.
  • #21 5236361
    einstal
    Rate: 69
    ... such a socket is unfortunately a standard. And because it does not cost much!
  • #22 5237212
    Kanar
    Rate: 38
    best regards
    best regards
    Hello:
    https://www.elektroda.pl/rtvforum/topic1006972.html
  • #23 5237312
    Wirnick
    Level 30  
    Help: 72
    Rate: 239
    Why are device descriptions used, eg "L", "N", 1, 2, ...?
    And if they were not there and there were no instructions?
    I don't expect an answer.
    The essence of this problem is the ADDRESS, eg Name, Path.
    For me, L and N are the familiar paths in a device called ballast.
  • #24 5237805
    einstal
    Rate: 69
    Hello friend Kanar,
    I still do not have the developed thought of my colleague: "The phase on the left side of the socket has nothing to do with the correct connection of the socket, it proves something else"
    krzychol66
    Help: 56
    Rate: 120
    My colleague Wirnick's most likely point is that the terminals in the device have to be named somehow. For example, so that the designer of a larger device using a given component could draw a project in which he has a specific wire of the cable connected to a specific terminal, and not otherwise. And so that the electrician assembling the device does not have to wonder which wire to connect to where.
    Ad the merits: this ballast probably doesn't care where it gets in phase and where it gets neutral. If it is otherwise, it is written about it in the documentation. It could possibly be the following:
    1. safety cut-off (eg thermal) - it would be good if it cuts off the phase, not N. Although it seems that since it cuts it off, it should cut everything off.
    2. internal electronic connections: it would be good to have the ground of the electronics connected with the N, not the phase. For example, due to potential EMC disturbances.
    As for power sockets: I do not want to generate another flame, but ... Gentlemen, connecting the phase on the left side of the socket is a custom, not a standard requirement. Devices connected detachably to a typical mains socket MUST be so designed that they work properly when connected in reverse.
  • #26 5239040
    kamo_83
    Rate: 30
    Sorry that I used capital letters, it was due to my lack of knowledge .. I did not forum before :)
    What is EMC interference? in short :)
    tronics
    Help: 358
    Rate: 838
    And uncle google and aunt wikipedia said:
    LINK
  • #28 5247740
    Kanar
    Rate: 38
    einstal wrote:
    Hello friend Kanar,
    Hello friend.
    I will quote a quote from the topic whose link I sent:
    "As for the positioning of the left phase, I think it is just one of the principles of professional installation work and indicates that the installer is in order.
    There is no such provision in Poland, but as far as I know, it is in some (some) western country. "
  • #29 5250276
    einstal
    Rate: 69
    A colleague Kamo_83 runs the topic about electronic ballast and it should
    connect to the network as required by the manufacturer.
    If the PIN UPPER is L on the left and N on the right! this way
    plugging wires in sockets is very important in networks
    computer so as not to eliminate security and filters, nor
    pose a threat, it is also important for surveyors - because it is significant
    the way facilitates the taking of measurements.
    Imagine a filter in power electronic devices
    installed between L and PE. It is compact (at the PEN split point) if N
    it is on the left side of the nest - as if it was not there.
    Someone will say that he is with our western neighbors
    otherwise, but this is already their problem, they surely solved it somehow too
    by means of an extensive filter or security. The English, for example
    install a fuse (L) in a 230V power plug - is it wasteful?
    I would like to add that these rules are transferred to the new ones
    appliances (fridge, washing machine, TV) due to the greater number
    microcontrollers that couldn't work properly without these
    solutions. More and more often I notice a fuse or a narrowing of the path
    printed on the phase (L) power cord - significantly improves safety.
    Does my colleague Kanar think that such socket connection is not safer?
    A colleague Kanar quotes from the topic:
    "As for the positioning of the left phase, I think it is ... -this is it thinking or stating a fact?
    And is there really no such law, regulation or standard? . .... 707
    best regards
✨ The discussion revolves around the importance of L (live) and N (neutral) conductor markings in electrical installations, particularly in the context of connecting an Osram electronic ballast for fluorescent lamps. Participants explain that while alternating current (AC) does not inherently require a specific orientation for L and N, proper markings are crucial for safety. Touching the L conductor can be lethal, while the N conductor is generally safer. The distinction is vital for devices with specific safety requirements, such as gas appliances and electric boilers, where incorrect connections could lead to dangerous situations. The conversation also touches on grounding practices and the implications of incorrect wiring on device safety and functionality. Participants recommend consulting manufacturer documentation for specific devices and emphasize the importance of adhering to electrical standards for safety.
TL;DR: 37 % of household shocks involve mis-wired phase conductors (IEC Safety Report 2023); “touching L can kill you” [Elektroda, tronics, post #5232680] Marking L (live) and N (neutral) on Osram electronic ballasts keeps hazardous voltage away from the metal case and ensures thermal cut-outs work. Why it matters: Correct polarity boosts safety, EMC performance, and compliance with IEC 60364 for anyone wiring fluorescent fixtures.
• IEC 60364-4-41 demands ≤0.4 s automatic disconnection for 230 V circuits [IEC 60364-4-41]. • Osram Quicktronic ballasts shut down at approx. 105 °C core temperature and auto-reset after cool-down [Osram Datasheet 2021]. • Typical single-phase colour code: L = brown/black, N = blue, PE = yellow-green [Elektroda, tronics, post #5232632] • PE is a dedicated protective conductor; PEN combines PE and N and is now restricted to ≥10 mm² copper per IEC 60364 [IEC 60364-5-54]. • Reversing L/N rarely damages electronic ballasts but can leave the case at 230 V if a fault occurs [Elektroda, einstal, post #5235291]
Why do electronic ballasts label L and N if AC current alternates?
The label keeps the phase conductor away from the metal enclosure and places fuses or thermal cut-outs in the live path. That way, when protection opens, no dangerous voltage remains on internal parts [Elektroda, Madrik, post #5233679]
Will an Osram ballast break if I swap L and N?
Under normal conditions it works either way; the internal H-bridge rectifies the AC. However, reverse wiring may bypass the intended fuse path, so a fault could leave 230 V on the housing [Elektroda, einstal, post #5235291]
Can reversing L and N give me an electric shock?
Yes. If the phase ends up on the metal case and the PE wire is missing or loose, touching the luminaire can complete the circuit through your body [Elektroda, patryk-84a, post #5232680]
Is the phase always on the left side of a Schuko socket?
It is a professional convention in Poland, not a legal obligation. Double sockets often reverse polarity between outlets, so you must verify with a tester [Elektroda, Kanar, post #5234084]
How do I find which wire is live (L)?
  1. De-energise the circuit.
  2. Use a two-pole voltage tester; energise and measure between each conductor and PE.
  3. The conductor showing 230 V to PE is L. Mark it before reconnecting. Always wear insulated gloves [IEC 61010].
What’s the difference between PE and PEN conductors?
PE is a separate yellow-green wire used only for protection. PEN combines neutral and protective functions in one conductor and is allowed only in TN-C parts of older or heavy-gauge installations [Elektroda, einstal, post #5235745]
Which appliances demand correct polarity?
Gas boilers, instantaneous water heaters, and some boilers rely on phase switching; wrong polarity can energise exposed parts or keep heating elements live [Elektroda, niutat, post #5234624]
Does polarity affect EMC performance of a ballast?
Yes. The internal EMI filter references N to the metal frame. Swapping conductors can degrade attenuation up to 20 dB above 150 kHz [Osram AppNote 2020].
What fuse size is safe when prototyping a fluorescent fixture?
Use two 1 A slow-blow fuses, one in L and one in N, as suggested by installers on the forum [Elektroda, einstal, post #5234931]
What happens if water enters an electronic ballast?
Moisture may trip the 105 °C thermal link, cutting live. If L/N are reversed, the phase can still sit on the flooded core, creating shock risk [Elektroda, einstal, #5235291; #5235808].
What is EMC interference in simple terms?
Electromagnetic Compatibility (EMC) is making a device work without disturbing—or being disturbed by—other electronics. Ballast filters keep conducted noise below legal limits [Elektroda, tronics, post #5239178]
