Which wireless thermostat for De Dietrich MCR 24 – boiler + floor pump?
goyotte13 6711 2
  • #1 11923275
    goyotte13
    Welcome,
    I am very much in need of help in finding/advising a wireless room temperature controller for a de dietrich mcr 24 gas furnace, which is additionally able to control wirelessly on/off the socket to which the underfloor pump is connected.
    Regards
    Dawid
    Please observe the rules of correct Polish and proper spelling of units, symbols and technical names. Letters are case-sensitive! [retrofood]
  • #2 11928000
    Marek_Pe
    Help: 46
    Rate: 112
    Please take a look at the offer of this company.
    I am considering the CM67Z along with the HR80 remote controlled radiator heads.
    Regards
  • #3 12524769
    lobo0
    Level 19  
    Rate: 15
    If it is an installation of radiators + underfloor heating, I have implemented such functionality in a different way.
    I have a regular wireless controller (on/off principle) and the floor pump is switched on by a thermostat which takes the temperature from the supply pipe. When the furnace is switched on and starts pumping hot water, the floor pump is switched on when the supply tube exceeds 30*C. A cheap and effective solution :)
