Sale:blind actuator merten instabus EIB REG-K/4x/10 with manual operation
wislawz 2430 0
  • #1 11948851
    wislawz
    Doesn't anyone need a louvre actor like this? i have 2pcs, if interested please contact me on PW.
    Information about the actor from the manufacturer's website:
    For independent control of 4 drives
    blinds/blinds. The functions of the shutter channels can be
    freely configurable. All outputs
    functions can be activated manually
    via buttons. Sensor with integrated
    bus port. For DIN rail mounting in accordance with
    EN 50022.
    The bus is connected via a bus cube - no data bus required
    the bus is connected via the bus cube - no data bus required.
    Indication of channel states via LED. Green
    LED indicates readiness for operation.
    INSTABUS EIB software functions:
    Shutter functions: Blind type. Movement time. Time
    pause. Step time. Differentiated functions
    blocking for weather alarms. 8-bit
    height and fin positioning. Scenes.
    Manual/automatic function. Status and
    diverse feedback functions.
    Per blind output:
    Rated voltage: 230 V AC, 50-60 Hz
    Rated current: 10 A, cosφ = 0.6
    Motor load: 230 V AC, max. 1000 W
    Unit width: 4 mod. = approx. 72 mm
