Understanding ISO 9141/14230 KWP2000 Protocol: Atmel Studio 6, Debug AVR, and Makefile Errors
vgeorgiev 6384 1
  • #1 11959802
    vgeorgiev
    Hi all,
    This is original post from this thread. However this post has been moved to bin folder because "Separated from the topic". I really do not understand!?!
    I downloaded ISO package.
    I am using Atmel Studio 6.
    Tried to create new project using make file (Create Project form Makefile Extension (Beta) extension) however there are some errors:
    ------ Build started: Project: iso, Configuration: Debug AVR ------
    Build started.
    Project "iso.cproj" (default targets):
    Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
    Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Atmel Studio 6.0\Vs\Compiler.targets" from project "C:\Users\Bibi\Documents\Atmel Studio\kpw2 - Copy - Copy\iso.cproj" (target "Build" depends on it):
       Using "RunCompilerTask" task from assembly "C:\Program Files (x86)\Atmel\Atmel Studio 6.0\Vs\Compiler.Task.dll".
       Task "RunCompilerTask"
          C:\Program Files (x86)\Atmel\Atmel Studio 6.0\make\make.exe -C "C:\Users\Bibi\Documents\Atmel Studio\kpw2 - Copy - Copy" -f "Makefile" all
          The system cannot find the path specified.
          make: Entering directory `C:/Users/Bibi/Documents/Atmel Studio/kpw2 - Copy - Copy'
          ECHO is off.
          -------- begin --------
          avr-gcc (AVR_8_bit_GNU_Toolchain_3.4.1_830) 4.6.2
          Copyright (C) 2011 Free Software Foundation, Inc.
          This is free software; see the source for copying conditions.  There is NO
          warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
          -f was unexpected at this time.
          make: *** [sizebefore] Error 255
          make: Leaving directory `C:/Users/Bibi/Documents/Atmel Studio/kpw2 - Copy - Copy'
       Done executing task "RunCompilerTask" -- FAILED.
    Done building target "CoreBuild" in project "iso.cproj" -- FAILED.
    Done building project "iso.cproj" -- FAILED.
    Build FAILED.
    ========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
    Anyone build this project? I wonder why author did not provided HEX file...
    P.S. XTAL on schematic is 4MHz and in make file it is defined as 7,372800 MHz.
    Thanks you in advance.
  • #2 12054060
    vgeorgiev
    Finally I managed to display all necessary data on a LCD.
    Video:
    video
