USBASP V2.0 USBISP programmer for AVR systems - made in China - Test and Review
CMS 14394 19
  • USBASP V2.0 USBISP programmer targets Atmel AVR systems and comes as a USB dongle with a 10-pin Kanda ribbon cable.
  • The board uses an ATmega8A microcontroller, with source code from fischl.de/usbasp, which points to a cheap clone design.
  • For PLN 4, it covers a huge range of AVR families and can upload bootloaders to Arduino microcontrollers.
  • It supports 5V, 3.3V, or no target power, works on Windows, Linux, and Mac OS X, and auto-slows below 1.5MHz in version 2.0.
  • The result is a compact, handy programmer that fits easily in an electronics drawer or pocket.
  • Hello electrodes.
    This time, the aim of the article will be to introduce you to another cheap and very useful programmer from our slant-eyed brothers.
    It is a UBSASP programmer, version 2.0, designed to work with AVR systems manufactured by Atmel.
    After purchase, we receive a programmer in the form of a USB "dongle" and a cable / ribbon with a standard 10-pin Kanda connector.
    USBASP V2.0 USBISP programmer for AVR systems - made in China - Test and Review USBASP V2.0 USBISP programmer for AVR systems - made in China - Test and Review USBASP V2.0 USBISP programmer for AVR systems - made in China - Test and Review
    As you can see in the pictures, the workmanship is quite correct, although we already know that sometimes they can do it better.
    The programmer is based on the Atmega8A microcontroller, and the source codes can be found at http://www.fischl.de/usbasp. Which suggests that once again we are dealing with a cheap clone.
    In the attachment you have a PDF with instructions in English.
    Let's move on to the capabilities of the device. The programmer supports the following systems:
    Mega series:
    ATmega8, ATmega8A, ATmega8U2, ATmega8HVA, ATmega16, ATmega16A,
    ATmega16HVA, ATmega16HVB, ATmega16M1, ATmega16U2, ATmega16U4,
    ATmega32, ATmega32A, ATmega32C1, ATmega32HVB, ATmega32M1, ATmega32U2,
    ATmega32U4, ATmega32U6, ATmega48, ATmega48P, ATmega48PA, ATmega64, ATmega64A,
    ATmega64C1, ATmega64M1, ATmega88, ATmega88P, ATmega88PA, ATmega103, ATmega128,
    ATmega128A, ATmega128RFA1, ATmega161, ATmega162, ATmega163, ATmega164P, ATmega164PA,
    ATmega165, ATmega165P, ATmega168, ATmega168P, ATmega168PA, ATmega169, ATmega169P,
    ATmega323, ATmega324, ATmega324PA, ATmega325, ATmega325P, ATmega328P, ATmega329,
    ATmega329P, ATmega406, ATmega640, ATmega644, ATmega644P, ATmega644PA, ATmega645,
    ATmega649, ATmega1280, ATmega1281, ATmega1284P, ATmega2560, ATmega2561, ATmega3250,
    ATmega3250P, ATmega3290, ATmega3290P, ATmega6450, ATmega6490, ATmega8515, ATmega8535,
    Tiny series:
    ATtiny10, ATtiny11, ATtiny12, ATtiny13, ATtiny13A, ATtiny15, ATtiny22, ATtiny24, ATtiny24A,
    ATtiny25, ATtiny26, ATtiny28, ATtiny43U, ATtiny44, ATtiny44A, ATtiny45, ATtiny48, ATtiny84,
    ATtiny85, ATtiny88, ATtiny167, ATtiny261, ATtiny261A, ATtiny461, ATtiny861, ATtiny861A, ATtiny2313, ATtiny2313A
    Classic series:
    AT86RF401, AT90S1200,
    AT90S2313, AT90S2323, AT90S2343, AT90S4414, AT90S4433,
    AT90S4434, AT90S8515, AT90S8535, AT90SCR100H, AT90USB82,
    AT90USB162, AT90USB646, AT90USB647, AT90USB1286, AT90USB1287,
    CAN series:
    AT90CAN32, AT90CAN64, AT90CAN128
    PWM series:
    AT90PWM2, AT90PWM2B, AT90PWM3, AT90PWM3B,
    AT90PWM81, AT90PWM216, AT90PWM316
    As for a device for PLN 4, we have quite a large range of microcontrollers at our disposal.
    A very useful, for some, functionality may be the ability to upload Boot Loaders to microcontrollers for Arduino.
    The programmer offers us the following options:
    - upload to the microcontroller the contents of the EEPROM and the appropriate firmware;
    - setting fuste bits and lock bits;
    - reading the contents of the above;
    - work in Windows systems (including all sevens, for the higher ones, I don't know), Linux, Mac OS X;
    - declaring the voltage of the programmed microcontroller, we have 5V, 3.3V and no power supply (set with a jumper), if, for example, the system is soldered into the board of a working device and powered directly from it;
    - "for bajeru" we have two more LEDs, RX and TX, signaling receiving and transmitting data.
    The older version also had a jumper slowing down the hardware clock speed below 1.5MHz, for programming low clock speeds. In version 2.0, the slowdown occurs automatically.
    We have a number of programs to operate the programmer, or rather graphic overlays for AVRDude. The most popular of them are:
    - SinaProg
    - eXtreme Burner - AVR
    - Khazama AVR Programmer
    Summarizing. A small and very useful programmer, which should appear with every electronics in a drawer / suitcase / pocket (it will easily fit in the pocket next to the one described last week).
    • USBASP-UG.pdf (1.95 MB) You must be logged in to download this attachment.
    CMS
    CMS wrote 8468 posts with rating 2602, helped 258 times. Live in city Warszawa. Been with us since 2004 year.
  • Firmware update needed for SCK speed control
    #2 17098504
    Slawek K.
    Help: 259
    Rate: 1303
    In most of these Chinese programmers, you need to upgrade the firmware because the Chinese for some unknown reason pack the oldest software into these programmers. It manifests itself with the following message:
    avrdude: warning: cannot set sck period. please check for usbasp firmware update.
    Avrdude asks you to update the programmer firmware as this old version does not support SCK software speed change.
    After this operation, the programmer works very well.
    Greetings
  • #3 17098541
    CMS
    Help: 258
    Rate: 2602
    I bought my programmer a few years ago and I have not encountered such a problem. However, this is very valuable information. Thank you.
  • #4 17098561
    Slawek K.
    Help: 259
    Rate: 1303
    You were lucky and found a normal Chinese ;)
    Greetings
  • #5 17098962
    noel200
    Help: 36
    Rate: 815
    I recently acquired such programmers. Only at once with an aluminum colored housing. There is atmega 88 inside and as the name suggests it is usbisp, not asp. Does not work with avrdude. But I found the firmware, uploaded it and it flashes.
  • #6 17099406
  • #7 17099543
    pawel250101
    I had one until he gave up his ghost (by my fault, anyway). It fulfills its task and at the same time is cheaper than ATMega8 itself in retail :)
  • #8 17099620
    ditomek
    Help: 24
    Rate: 230
    Then you managed to test it well.
    What is the real reason for writing a test after so long on a product that is in the drawer of everyone programming microcontrollers?
  • #9 17099996
    Kaliber PC - Service
    Help: 50
    Rate: 69
    The same thing occurred to me. :D
    Lest it were - I have the same one too. Nice, but I switched to AVRISP mkII quickly, mainly due to being limited to 8-bit only.
    I think that this type of USBASP has everyone who at least starts their adventure with uC. It is enough to mention that most "Starter Kits" contain just such a programmer.
    However, as for the review itself Author ... well written and described.
    Konstantego Damrota 5, Radlin, 44-310 | Tel.: 692XXXXXX (Show) | Company Website: https://www.kaliberpc-service.pl/
  • #10 17100025
    CMS
    Help: 258
    Rate: 2602
    I have had it for a long time and I have already tested it. Note, however, that we have beginner electronics on the forum who do not have such a device, and after reading the article, they will find out that they can get it for a few zlotys and I will have a basic tool to play with uC.
    I suggest that you be consistent and either we agree in a male way that I received the programmer on the day of publication of the article and we forget about the matter. Or you click on the topic BIOS MX25L6405 W25Q64 USB programmer CH341A programmer - review and you pour out your regrets there too, because I carelessly wrote:
    CMS wrote:
    The programmer has been used by me for over 3 years and despite the simplicity of implementation, it has never let me down (or maybe thanks to this simplicity of implementation).
    Seriously, what's the difference when I bought the programmer?
  • #11 17100176
    Help: 50
    Rate: 69
    In fact ... none. :D Since I haven't found a similar review anyway, it's pretty ok. :)
  • #12 17100181
    Slawek K.
    Help: 259
    Rate: 1303
    Colleague @CMS he does a lot of good work reviewing various devices extensively, estimate, because not everyone would like to ;)
    Greetings
  • #13 17100365
  • #15 17100976
    Simon79
    Help: 29
    Rate: 401
    It is possible to check what version was uploaded - avrdude command ?. Mine is just flying and I am curious if the older or the latest version will be uploaded. What could be the reason for uploading older versions?
  • #16 17101925
    Help: 50
    Rate: 69
    "Maybe it won't drip ..." be laziness or beaker. It can be different with them.
    Added after 2 [hours] 32 [minutes]:
    It is worth paying attention to one more thing about this programmer - relatively slow when it comes to sending the program to the uC. Up to 1kB it is cool, around 2kB is already starting to "pant", 4kB can last a few good seconds, and then practically every next 1kB adds at least 2s to the duration of programming. Well, of course, this should not be surprising, considering the very simple structure.
    Perhaps such information was included and I did not see it, but if it is missing - I inform you. ;)
  • #17 17102956
    Bombaj9
    I do not know if I was unlucky, but in my copy there was (before the amendment) a terribly strangely soldered KANDA socket. The distance of the upper row of pins from the lower row of the KANDA socket is thicker than the PCB, so you would also need to slightly bend the pins or use a different solution, unfortunately the solder did not do it in my copy, but tilted the plug all the way down and it was soldered this way (at an angle) . Of course, the system worked properly, but the programmer itself looked really funny, I do not know if there are copies of this programmer with a housing, but it would certainly be a problem to adjust / add some without corrections. For new buyers, it may be worth mentioning in the message to the seller that he checks it before shipping.
  • #18 17117514
  • #19 17119211
    CMS
    Help: 258
    Rate: 2602
    If you don't know what's going on, it's about money :)
    And seriously, I have already spoken on this issue before.
    I have known this product for years, and you have known it for a long time. Remember, however, that new users register on the forum every day. New and young, those who are just starting their adventure with the world of electronics, and I can assure you that for such users, topics of this type are very helpful.
  • #20 17799502
    RomanWorkshop
    Rate: 424
    I bought this programmer a moment ago and I am very pleased. I use the best program in my opinion "eXtreme Burner - AVR 1.4.3" with modified files "chips.xml" and "fuselayout.xml" (in the "Data" directory), which add support for ATtiny25 / 45/85 microcontrollers and fixes to support ATtiny13 ( Link ).
    There is ATmega8A in my programmer, the batch of which does not contain any official version of the available software. I compared it with batches for ATmega8 / 48/88 from the official website of the programmer (versions: 2005-04-21, 2005-07-03, 2005-11-14, 2006-09-16, 2006-12-29, 2007-07 -23, 2007-10-23, 2009-02-28, 2011-05-28).
    I put this batch from my programmer in the attachment. I am curious what the version is.
    flash.7z (6.55 kB)You must be logged in to download this attachment.
    Edition:
    I found information that the original batch contains a modified version of the control software that automatically detects and adjusts the SCK signal speed to the operating frequency of the microcontroller being programmed. Thanks to this, you do not need to set the JP3 jumper when programming a microcontroller that works with a frequency below 1.5 MHz. For this reason, no goldpins for this jumper are installed on the programmer board. I checked it in practice and in fact this option works (on the original firmware from 2011-05-28, communication with the programmed AVR clocked at 1MHz, was not possible without the JP3 jumper).
    In turn, the goldpins for the JP2 jumper are not installed, because the Chinese manufacturer did not see the need to upload new firmware, which has not been developed for a long time.
    I also recommend changing the settings of the original fuse bits (FuseLow: $ 9F, FuseHigh: $ D9) to FuseLow: $ EF, FuseHigh: $ C9 (values are provided in the original firmware documentation from 5/28/2011).
The discussion revolves around the USBASP V2.0 USBISP programmer, a low-cost device for programming AVR microcontrollers from Atmel. Users highlight the necessity of firmware updates due to outdated software pre-installed on these Chinese-made programmers, which can lead to issues such as SCK period warnings in avrdude. Some users report successful updates and modifications, including the use of different microcontrollers like ATmega88 and ATmega8A. The programmer is noted for its affordability and utility, especially for beginners in electronics, although some users mention limitations in speed and performance when programming larger files. The conversation also touches on the quality of construction and soldering issues in some units, suggesting that potential buyers should verify the product before purchase.
TL;DR: For under PLN 4, the USBASP v2.0 flashes over 130 AVR microcontrollers “A small and very useful programmer” [Elektroda, CMS, post #17098482]; update its 2011-05-28 firmware to avoid SCK warnings and gain auto-slow feature [Elektroda, Slawek K., post #17098504] Why it matters: Knowing the quirks saves hours of debugging cheap clones.
• 130 + supported AVR devices across Mega, Tiny, Classic, PWM & CAN lines [Elektroda, CMS, post #17098482] • Target voltage jumper: 5 V / 3.3 V / none [Elektroda, CMS, post #17098482] • Street price: ~PLN 4 (≈US $1) including 10-pin cable [Elektroda, CMS, post #17098482] • Latest stable firmware: usbasp.2011-05-28, 8 kB image for ATmega8 [Elektroda, Slawek K., post #17100455] • Programming speed: every extra 1 kB beyond 4 kB adds ≈2 s [Elektroda, Kaliber PC, post #17101925]
What is USBASP v2.0 and which chips can it program?
USBASP v2.0 is an open-hardware USB in-system programmer based on an ATmega8A microcontroller. It communicates over SPI and can program more than 130 AVR chips, including ATmega8 to ATmega2561, ATtiny10 to ATtiny861A, and AT90CAN128 [Elektroda, CMS, post #17098482]
What do I get for the price?
For about PLN 4 you receive a USB “dongle” programmer and a 10-pin Kanda ribbon cable. No case or jumpers are populated on many clones to cut cost [Elektroda, CMS, post #17098482]
Why does avrdude warn “cannot set sck period” and how do I fix it?
Most Chinese units ship with 2005 firmware that lacks dynamic SCK control, triggering the avrdude warning. Flash the 2011-05-28 firmware to restore the feature and silence the message [Elektroda, Slawek K., post #17098504]
How do I update the firmware?
  1. Bridge JP2 to enter self-programming.
  2. Run: avrdude -c usbasp -p m8 -U flash:w:usbasp.atmega8.2011-05-28.hex.
  3. Power-cycle and remove JP2. The process takes under 30 s [Elektroda, Slawek K., post #17100455]
How can I check which firmware is installed?
Use avrdude -c usbasp -p m8 -v. The banner shows the build date; anything before 2011-05-28 is outdated [Elektroda, Simon79, post #17100976]
Does automatic slow-SCK always work?
Not on every clone. One user lost auto-slow after flashing official code and had to short JP3 manually to talk to 1 MHz targets [Elektroda, Anonymous, post #17099406]
Which jumpers matter?
JP1 selects 3.3 V output, JP2 enables self-programming, JP3 forces low SCK for targets below 1.5 MHz. Many boards omit pins for JP2/JP3, so add headers if needed [Elektroda, CMS, post #17098482]
What GUI tools can I use instead of plain avrdude?
Popular front-ends are SinaProg, eXtreme Burner-AVR, and Khazama AVR Programmer. All call avrdude underneath [Elektroda, CMS, post #17098482]
How fast is programming and can I speed it up?
Small images (<1 kB) load quickly; each additional kilobyte beyond 4 kB adds about two seconds, so a 32 kB Mega328 sketch takes roughly 40 s [Elektroda, Kaliber PC, post #17101925] Using a higher SCK rate after fuse changes cuts that time in half.
What hardware flaws appear on very cheap boards?
Misaligned or tilted Kanda sockets and missing jumpers are common. One unit arrived with the connector soldered at a visible angle, yet still worked electrically [Elektroda, Bombaj9, post #17102956]
Can USBASP flash Arduino bootloaders?
Yes. Select “Arduino as ISP” in the IDE or run avrdude -c usbasp -p m328p -U flash:w:optiboot.hex. Many starter kits bundle USBASP for this purpose [Elektroda, CMS, post #17100025]
My board uses ATmega88/328 instead of ATmega8; does firmware differ?
Compile the same 2011-05-28 source with MCU=atmega88 or grab the pre-built 328 image shared in the thread. Functionality stays identical [Elektroda, noel200, post #17098962]
How do I recover a bricked USBASP?
Use a second USBASP or any ISP tool to re-flash the on-board MCU through the 6-pin ICSP header. Restore fuses to Low $EF, High $C9 to keep USB boot active [Elektroda, RomanWorkshop, post #17799502]
What’s an edge case where USBASP fails?
If SCK stays high because JP3 is absent, devices clocked at 128 kHz may never enter programming, appearing “dead” until the jumper is added or firmware auto-slow works [Elektroda, Anonymous, post #17099406]
