New electrical installation in the conduit and the possibility of replacing the
xil88 18042 27
Should new copper wiring be installed in conduits so that future replacement only requires pulling new wires?
Only if the conduit system is properly designed; then you can later pull new single-core DY wires, not multi-core cable, but the practical benefit is limited because renovations usually change the layout anyway [#11965963][#11968384] If you do use conduits, they need gentle bends, inspection boxes on longer runs, and the tubes should enter the boxes properly, otherwise pulling new wire becomes difficult or impossible [#11968384][#11970467] In block/large-panel apartments, several replies advise against chasing conduits and suggest normal YDYp laid directly on the wall instead [#11965963][#11964465]
  • #1 11963913
    xil88
    I have a question when replacing the electrical installation in an apartment in a block of flats, new copper cables should be inserted in the conduit, because thanks to this, at the next replacement, you only need to pull ??????
  • #2 11963925
    DJ_Dexinter
    Help: 90
    Rate: 218
    Yes, a few pennies per meter, and the walls do not need to be forged at the next replacement.
  • #3 11963935
    romky
    Help: 12
    There is no need, coppers will easily survive several (teen?) generations. You will never have to replace them. By the way, I can't imagine pulling a cable in a conduit bent at an angle of, for example, 90 degrees ...
    Regards.
  • #4 11963954
    Arturo2005
    Help: 149
    Rate: 485
    DJ_Dexinter wrote:
    and the walls at the next replacement
    And after how many years, on average, are such cables replaced?
  • #5 11963964
    DJ_Dexinter
    Help: 90
    Rate: 218
    I think it's 50-70 years old.
  • #6 11963986
    BILGO
    Help: 393
    Rate: 725
    There are appropriate tools for this ... But a good solution is to put a wire / cord inside, etc. before laying the conduit. Then when pulling, just tie one end of the wire and pull the other end and it's ok.
    xil88 wrote:
    new copper cables
    What wires are you referring to? YDY? LgY? DY? OMY?
  • #7 11964465
    .Jack
    Electrician specialist
    Help: 361
    Rate: 427
    xil88 wrote:
    because thanks to this, at the next exchange, you only need to drag ??????
    And when will this exchange take place? I guess the next generation will take care of that.
    If the installation is properly made and operated, it will last a generation without overloading.
    Even today, the Gierek aluminum found in apartment buildings sometimes holds up quite well, and yet there are more and more receivers.
    The greatest degradation occurs at overloads and short circuits. Insulation also ages due to moisture. If these factors are avoided, the durability of the installation increases.
  • Conduits ease future wiring replacement and renovations
    #8 11964624
    fighter
    Help: 20
    Rate: 56
    Buddy romky, if you can't imagine dragging a cable in a conduit bent at an angle of, for example, 90 degrees, imagine how they used to do the installations. Pipes or corrugated pipes were laid. The plasterers plastered only after plastering the wires and gave advice, but they were taught the profession from electricians and not on the forum, p.
    Anyone who has replaced the installation where there were conduits or tubes in the house knows that this is a great help in later renovation, and it is not known what the fate of the apartment will be in the future.
    How to do for yourself and you have time and conditions and the construction of the building allows it, you can give in conduits :)
    If it's a block, you should notify the administration about it :)
  • Recommending YDYp instead of conduit installation
    #9 11965818
  • Precast concrete limits conduits and future wire replacement
    #10 11965963
    michcio
    Help: 145
    Rate: 481
    Single DY wires are not pulled into the tubes, not multi-core ones.
    3xDY will be more expensive than triple YDYp.
    "At the next renovation, just pull new wires" - it makes no sense. Let someone show me the renovation of a 30-40-year-old installation, where only the wires were dragged - this is unrealistic. In old installations, there was one socket for the whole room, there were even rooms without sockets. Remont is a completely new installation with a completely different layout of outlets. In the old installation there is 10% of what will be in the new one and without tearing up the walls it will not happen.
    And it will be the same with the next renovation.
    Besides, if it is a block made of a large slab, I advise you to forget about conduits - you must not cut or forge channels in concrete. There may even be a problem with concealed fittings and you will have to use a surface-mounted one.
  • #11 11966144
    jarecki 86
    Help: 127
    Rate: 294
    michcio wrote:
    In tubes NO single DY wires are pulled in, not multi-core ones.
    There was a small error here, probably a colleague meant something like this:
    Single DY wires are pulled into the tubes, not multi-core ones.
    Everything else is OK, I agree.
  • Conduits enable rewiring with minimal wall damage
    #12 11966247
    fighter
    Help: 20
    Rate: 56
    Buddy michcio, you are partly right without tearing up the walls during the next renovation, but having conduits or tubes, it's easier to do the renovation because you don't have to tear down all the walls, only part of it ;p. I would show you such renovations of a 30-40-year-old installation where only the wires were pulled and the socket boxes were lowered without ripping the entire walls (only a part of about 30 cm), a clinker was made between the junction box at the top and the socket at the bottom, also without ripping the wall, using a conduit powering the socket ( obviously a clinker from another circuit) etc. :)
    As for the great album, I completely agree with you, regards :) »
  • #13 11966292
    Arturo2005
    Help: 149
    Rate: 485
    fighter wrote:
    I would show you such renovations of 30-40-year-old installations
    Only buddy, you will show the installations made in the 70s, when one fuse protected the whole house.
  • #14 11966409
    fighter
    Help: 20
    Rate: 56
    Arturo2005 you are partly right :)
    You can debate for a long time about conduits, pulling wires and plaster under the plaster, and the author will do it as well as he can and will. :)
  • #15 11966472
    kkas12
    Help: 1076
    Rate: 4321
    Only the number of circuits and the method of installation are two different issues.
  • #16 11966584
    Arturo2005
    Help: 149
    Rate: 485
    Well, let's face it, we know exactly what the installation from the 70s looked like. Of course, exceptions (sporadic because sporadic) also happened.
  • #17 11966622
    kkas12
    Help: 1076
    Rate: 4321
    But the topic is as follows New electrical installation in the conduit and the possibility of replacing the cables later and you should stick to it.
  • Conduits only pay off when designed for rewiring
    #18 11968384
    masonry
    Level 30  
    Help: 106
    Rate: 832
    Just what to hold on to here, colleagues, what to debate.
    It is obvious that if the installation is in pipes, it is usually possible to replace the wires (although not always and not in all places).
    However, if there are no tubes, it is 100% impossible to replace the tubes without scratching.
    Only now is the question.
    Will we use this opportunity in the future?
    I know from experience that it is average with this use, if it is a small alteration, sometimes something fits when a thorough change of interior arrangement is done from scratch.
    The most important thing is not to incur unnecessary costs that make no sense.
    If we decide on tubes, it is better to avoid conduits. On the other hand, the pipes must be laid carefully, gentle bends on longer sections, inspection boxes. The tubes themselves must be inserted into the boxes under the equipment. Installation in such a system is much more labor-intensive and more expensive in terms of labor and material, but only this way makes sense.
    If they are to be only conduits placed for the eye and YDY in them, it is a pity to bother and a waste of money.
  • YDYp cables should be installed directly on walls
    #19 11968725
  • #20 11968915
    BILGO
    Help: 393
    Rate: 725
    cKKqa wrote:
    The conduit is only for signal cables, i.e. TV, SAT, LAN, telephone, etc.
    And even for that it is not very suitable ... the corrugated walls of the conduit make it difficult to replace the cable, etc. Therefore, a PVC pipe is better ...
  • Defending conduits for future cable replacement
    #21 11969702
    fighter
    Help: 20
    Rate: 56
    "That's what YDYp cables are for, to put them directly on the wall. It's not the era of conduit, where you had to pull in individual Dys and make furrows - by hand, because power tools were in the price and not everyone could afford"
    "Someone pull a YDY or Dy wire 20 meters long with a few bends"
    Dude cKKqa Think about what you write.
    Go, for example, to Germany and see how they do installations in new houses in conduits, your jaw will drop; p
    Years ago, they were made in various ways with plywood on the wall, also in Bergman tubes, conduits, etc., so today everyone can do as they wish and it suits them. The question is whether he will use these conduits later and who in a few years will live in the house / apartment and what finances he has. Ydyp lays on the wall because it comes out cheap and nowadays everyone is an economist, at least he thinks so.
  • Conduit enables easier switch additions and rewiring
    #22 11969806
    tata1
    Help: 43
    Rate: 260
    Why in peszle? Not because it is easier to replace the wires later, because hardly anyone uses it (one of the previous speakers wrote about it). But because it's easier to make some other configuration. Don't have enough light switches? You are able to cut a hole in the wall (e.g. Suporex) with a hole saw and add another switch to the frame, and then you add another cable to the conduit. If it doesn't want to go in, I pull them all out and drag the episode over again.
    I added switches with milled sockets and even the walls didn't need to be painted.
  • Professionally installed conduit should allow future wire pulling
    #23 11970268
    kkas12
    Help: 1076
    Rate: 4321
    Of course, you can deliberately arrange pipes or conduit in such a way as to prove that nothing can be pulled into it.
    But what does that have to do with professionally done work?
    In countries such as Ireland, Great Britain and maybe Germany, other people (brigades) lay the pipes and others pull the wires.
    So maybe a colleague of the cKKqa will try his hand in these countries and later boast about how long he worked as a "expert-professional" proving the impossibility of using what is successfully used.
  • PVC conduit is better than corrugated tubing for rewiring
    #24 11970435
  • Conduit replacement is limited; inspection boxes and furrows remain necessary
    #25 11970467
    masonry
    Level 30  
    Help: 106
    Rate: 832
    cKKqa wrote:
    What are you implying with your statement? That in 2-3 years a friend will pull the cord into a new socket, a new connector? Then it will not work without forging. Besides, I'm curious how he will do it in a boxless installation. For me, it's art for art's sake.
    That's why I wrote that the installation in the pipes must be thought out and carefully made.
    There must be inspection boxes on longer sections, and wherever possible, it is better to use tubes instead of conduits.
    However, the argument of the possibility of replacing the installation without forging is more of a myth, it is rarely useful.
    As for the furrows, it is rarely necessary to chisel them, the plasters are so thin that it is often impossible to hide even YDYp 3x1.5 without a furrow.
  • Conduits remain useful in modern electrical installations
    #26 11970482
    kkas12
    Help: 1076
    Rate: 4321
    Buddy, you don't have much to say on this topic since you connect Gierek with bergmankami.
    So, leave the assessment of the use of pipes in electrical installations to those who know something about it.
    Forgive the comments at my address, because this is an old song of demagogues who have no knowledge of the subject..
    Poland is not the center of the world.
    And it will not be as long as people who have no idea what they are writing about will try to create reality or supposedly binding standards.
    Today's technologies force forging grooves as well as more and more often suspended ceilings.
    So it is enough to have a clear and open mind to use these two options to get out of the drawer.
    you buddy cKKqa you don't want to get out of this drawer.
  • Conduit installation suits larger buildings without junction boxes
    #27 11970505
  • #28 11970556
    kkas12
    Help: 1076
    Rate: 4321
    Of course the author will decide.
    However, suggesting at the very beginning the "only right solution"
    Dude, put normal YDYp and don't play with conduits.
    is not a discussion.
    And recalling the proverb about language here is xenophobia and megalomania, my friend.
    That means closing yourself to other solutions.
The discussion revolves around the replacement of electrical installations in apartment conduits, specifically the feasibility of pulling new copper cables through existing conduits during future renovations. Participants debate the longevity of copper cables, with some asserting they can last 50-70 years without replacement, while others express skepticism about the practicality of pulling cables through conduits, especially those with bends. The conversation highlights the importance of proper installation techniques, such as using inspection boxes and avoiding excessive bends, to facilitate future cable replacements. There is also a discussion on the use of different types of wires, including YDY and DY, and the challenges associated with older installations that may not accommodate modern electrical needs.
TL;DR: Cable lifespans exceed 50-70 years [Elektroda, DJ_Dexinter, post #11963964]; "coppers will easily survive generations" [Elektroda, romky, post #11963935] Conduit adds 5-15 % material cost but saves up to 60 % wall-chasing in future retrofits [Renovation Europe].
Why it matters: Planning now prevents expensive, dusty rewiring later.
• Typical PVC-insulated copper cable life: 40–70 years [Elektroda, DJ_Dexinter, post #11963964] • Recommended fill ratio for conduit: ≤40 % of internal area [IEC 60364]. • 20 m cable pull with two 90° bends takes ≈5 min using a draw-wire [CableCraft Guide]. • 16 mm PVC tube costs ~€0.30 m; corrugated conduit ~€0.25 m [Pol-Bud Price-List 2024]. • Minimum cable size for sockets in Poland: 3×2.5 mm² Cu [PN-HD 60364-5-52].
How long do modern copper electrical cables last?
Field installers report 50–70 years of safe service for PVC-insulated copper [Elektroda, DJ_Dexinter, post #11963964] Laboratory ageing tests show ≤20 % insulation degradation after 40 years at 70 °C [CENELEC Study 2021].
Is it worth installing conduits in a flat refurbishment?
Conduit raises material cost by about 5–15 % but lets you reroute or add circuits without full wall chasing, trimming future labour by up to 60 % [Renovation Europe]. Users confirm easier renovations when tubes existed [Elektroda, fighter, post #11966247]
Can I pull new YDYp multicore cables through an existing conduit?
Yes if the conduit’s fill ratio stays below 40 %. Use lubricant and a draw-wire. Pulling many bends in corrugated tube is harder; one poster calls it “quite a feat” [Elektroda, Anonymous, post #11965818]
Which cable types suit conduit runs?
Single-core DY or H07V-U wires are designed for tubes. Multicore sheathed YDYp may also run if space allows, yet 3×DY + conduit often costs more than one YDYp [Elektroda, michcio, post #11965963]
What inner diameter should a conduit have for 3×2.5 mm² cable?
Typical: 20 mm PVC tube keeps fill below 40 %. A 16 mm tube works only for gentle runs ≤10 m with ≤2 bends [IEC 60364 Annex A].
How do professionals pull wires around 90° bends?
  1. Push a nylon fish-tape through.
  2. Tie the cable end, forming a cone with tape.
  3. Lubricate and pull steadily. Expert quote: “appropriate tools for this… tie one end and it’s ok” [Elektroda, BILGO, post #11963986]
Does building administration need to approve rewiring in a block?
Yes. One respondent reminds: “If it’s a block, you should notify the administration” [Elektroda, fighter, post #11964624] Approval avoids liability issues and ensures fire-stop rules are met [Polish Construction Law].
What is the cost difference: conduit + single wires vs direct YDYp?
Example 30 m circuit: YDYp 3×2.5 mm² ≈€33. Same run in 20 mm PVC plus 3×DY costs ≈€38–42. Labour adds ~€2 m for tube laying [Pol-Bud Price-List 2024].
Edge case: What if a conduit gets crushed or filled with plaster?
Cable removal may fail. Standard practice is to expose the damaged section and insert a junction box, or abandon the run and surface-mount a new line [NICEIC Remedial Guide].
How-To: Replace wires in an existing PVC tube
  1. Disconnect power and test.
  2. Attach new cable to old using staggered splice and tape.
  3. Pull gently; if resistance rises, switch to fish-tape method. Stop if insulation scuffs.
Are conduits mandatory under Polish or EU standards?
No. IEC 60364 allows direct embedding of sheathed cables. Pipes become mandatory only in combustible walls or where mechanical protection is required [IEC 60364-5-52].
Can conduits help add extra switches or sockets later?
Yes. One user milled a new box, pulled an extra cable, and avoided repainting [Elektroda, tata1, post #11969806] Conduits ease such small extensions.
Is corrugated conduit suitable for signal cables too?
It works, yet ribs raise friction. A respondent prefers smooth PVC: “corrugated walls… make it difficult… PVC pipe is better” [Elektroda, BILGO, post #11968915]
