How to design a smart home to increase energy savings?
siutek84 13860 33
How should a smart-home automation system be designed to produce measurable savings in heating, electricity, and water use?
Design the system primarily around heating, HVAC, and occupancy control, while treating standby-power switching and automatic lighting as secondary measures; good insulation and ventilation/heat recovery should come first [#12007423][#12050002] Use schedules and presence detection to lower temperatures when occupants are away or asleep, zone rooms that are temporarily unused, stop heating when windows are open, and coordinate heating, blinds, and mechanical ventilation [#11994495][#11997190][#12019210] Avoid disconnecting general socket circuits because many chargers consume only about 0.03–0.3 W, while contactors and the always-on controller may consume comparable power; reserve switched circuits for clearly defined loads [#11993388][#12007423] Measure the automation system’s own consumption before calculating savings: one measured KNX installation averaged about 9.2 W, while a Sterbox example used 1.8 W [#12000258][#11994495] Treat marketing claims such as 23–30% savings cautiously, since results depend heavily on the building, heating system, climate, and occupants; one seven-month test reduced heating costs from PLN 3860 to PLN 3300, with PLN 2305 in components and an estimated 51-month payback before installation labor [#12022258] Keep conventional switches and local control available if the controller fails, and consider rainwater collection for garden irrigation as the only water-saving measure specifically mentioned in the thread [#12007423][#12049718]
  • #31 12050071
    kwantor
    Help: 352
    Rate: 1227
    Certainly not a myth, the myth is cost-effectiveness.
    Pay attention when you read reviews, calculations, descriptions and incentives on Google - these are the works of the people and companies selling these products. :D
    It is rarely mentioned anymore that a window for such a building is 3x more expensive, than the popular and widely used ones.
  • #32 12050191
    siutek84
    Rate: 21
    I came across an interesting text by a man who has a lot of exposure to energy audits etc:
    http://www.audyt-energetyczny.net/dom-pasywny.php
    a text from 2008, admittedly, and moreover unfinished, but it helps to illuminate the picture of the passive house.
  • #33 12051938
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 671
    siutek84 wrote:
    ey,
    I'm a bit afraid of off-the-shelf systems, mainly because of the cost, and also because of the low flexibility. I can add modules and programs I need to my own system at any time. With off-the-shelf systems, I am limited to what the manufacturer offers. If anything, I am not afraid of the soldering iron ;)
    What do you mean with these "manufacturers" restrictions ?
    Greetings
  • #34 14606289
    siutek84
    Rate: 21
    Greetings
    I will reheat the chop :P
    What do I mean? Namely that I am in this situation limited to what the manufacturer designs and programs. If I need some new functionality, a new module that the manufacturer does not provide - I am cooked.
    In the case of an automation system of my own design, I can always develop such a module myself. What is more, I can improve and modify the module at my own discretion.
