Iveco Daily 35C15 - EDC Indicator, Engine Fault 0117, Unknown Code & Repetitive Pattern
gulu666 236241 12
What causes the EDC light to flash after start-up and fault code 0117 on an Iveco Daily 35C15?
Fault 0117 in this thread was identified as a temperature sensor fault, so the first check is the temperature sensor and its wiring [#12009150][#12009250] Another suggestion was to inspect the crankshaft/camshaft position sensor, its harness, and the timing if the EDC light comes on and the engine loses power [#12007076] One later report from a similar case said the fault finally disappeared after replacing the camshaft position sensor, even though a Bosch sensor had already been tried, so the sensor itself may be the issue [#16924439]
  • #1 12002644
    gulu666
    Rate: 361
    Hello. I have an error right after firing, the EDC indicator lights up once, then it goes out and so on. The engine fault is 0117 Unknown fault code.
    What could it be?
  • #2 12005171
    osmaster81
    Rate: 70
    From what I remember, it was a shaft position sensor error
    Which year is which engine?
    If it is a common rail, try to smoke with the plug from the fuel pressure sensor in the pump disconnected
  • #3 12005357
    gulu666
    Rate: 361
    Year 2008, engine 3.0 176KM
  • #4 12007076
    osmaster81
    Rate: 70
    crankshaft position / camshaft position, bank 1 sensor b-correlation
    Check the shaft position sensor, camshaft, harness, if ok, check the timing
  • #5 12008649
    gulu666
    Rate: 361
    But 0017 probably signifies this error and I have 0117 unless it's the same. When the EDC is lit, the car has no power.
  • #6 12009150
    osmaster81
    Rate: 70
    I'm sorry my mistake ,
    but you wrote that after firing the car goes out, you did not write anything about the fact that when the edc lights up, it's just a lack of power
    0117 - temperature sensor
  • #7 12009250
    gulu666
    Rate: 361
    I replaced the temperature sensor and it's still the same. I'll check the wiring.
  • #8 12017193
    skorp
    IVECO Trucks specialist
    Help: 22
    Rate: 346
    Have you checked if you have brake lights?
  • #9 12257588
    gulu666
    Rate: 361
    problem solved
  • #10 16582471
    krzys2711
    Rate: 137
    buddy, how did you solve this, the problem and what was the reason, because I have the same
  • #11 16924006
    gulson
    System Administrator
    Help: 148
    Rate: 6050
    A lot of people would like to know how you solved your problem, see how many votes the post with the question got.
  • #12 16924439
    krzys2711
    Rate: 137
    I also solved my problem, after replacing the camshaft position sensor with Bosch, the car still went out after the ignition and caused the camshaft position sensor error, the mechanic did not know what to do, he checked everything and still no answer. So I went to the store and bought the cheapest Chinese for a test for a replacement and success the car stopped catching the error of this roller, after a long fight, finally, calm for now.
  • #13 20205076
    stodziez
    Rate: 16
    gulu666 wrote:
    problem solved
    you can know what the cause
✨ The discussion revolves around an issue with an Iveco Daily 35C15, where the EDC indicator lights up intermittently, and an engine fault code 0117 is displayed. Users suggest potential causes, including a shaft position sensor error and issues with the crankshaft or camshaft position sensors. The original poster mentions that the vehicle has no power when the EDC light is on and that they replaced the temperature sensor without resolving the issue. Other participants recommend checking wiring and brake lights. A successful resolution was shared, where replacing a faulty camshaft position sensor with a cheaper alternative resolved the problem.
