Iveco 35C15 2012 - Emergency mode the oil light flashes and the edc is on
xxxxxPL 13560 1
  • #1 16894646
    xxxxxPL
    Hello, I have a problem iveco 35c15 delphi displays two errors 52158 (P0521) and 52468 (P0524) on the clocks, edc lights up and the oil is flashing red, the car in safe mode after removing the errors, it works after turning off and starting it is in safe mode again. Anyone had such a case? Is it a clogged dpf?
  • #2 16894760
    Foxtrott
    Help: 253
    Rate: 944
    Rather to check the oil level in the engine and the pressure sensor.
