Iveco Daily 35C15 (3.0 176 HP) - EDC Error, No Start: Possible Sensor, Fuel, or Electrical Issue
SokolPatryk 36813 4
  • #1 16877398
    SokolPatryk
    Rate: 8
    Hello, I have a problem with Iveco as in topic 3.0 176 HP
    One of the drivers probably lacked fuel, the car went out, the EDC light was on, there was no electricity to the pump, the pump was shortened for a short time.
    All fuses
    The forum has a similar topic but without explaining how it was fixed. The only useful information is about the sensor position of the shaft which I will verify today or tomorrow as I will have the car "on the table"
    I would like to ask what is worth checking if it is not a position sensor problem.
    I know that the control itself is not enough, unfortunately I do not have access to diagnostic equipment.
    I will add that the car turns very "sluggish"
    For any tips beer!
  • #2 16881650
    Krzysius93
    I suggest checking the area and connections in the lower region of the water cooler on the left side of the car in terms of corrosion and continuity of wires
  • #3 16882068
    Megawe
    Help: 246
    Rate: 1437
    In a box with fuses and relays on the engine there are two relays from the injection: the main one and the fuel pump.
    Is the main relay activated?
    If there is a gap between the controller and the fuel pump relay (the controller shorts the relay to the ground), the engine will not fire even for a short time, plus a pump. You can try to short the relay to ground by a 12V indicator. If we connect the copper wire control wire to ground, we will not start the engine. After switching the ignition on the valve, the dose on the toilet pump should be + 12V. The toilet pump with disconnected plug pumps to the maximum pressure.
    First check the controller relay cable.
  • #4 16885293
    SokolPatryk
    Rate: 8
    The problem found, just the question why did it happen?
    • Iveco Daily 35C15 (3.0 176 HP) - EDC Error, No Start: Possible Sensor, Fuel, or Electrical Issue IMAG0935.jpg (2.74 MB) You must be logged in to download this attachment.
  • #5 19449847
    Śledźbmw
    Rate: 12
    I have the same problem, only with me the bundle is all right
    Added after 5 [hours] 37 [minutes]:
    In my Iveco the pompa works like this for about 0.5 seconds and turns off what may be
