300L Double Coil Boiler: Enamelled vs Stainless Steel - Lifespan and Corrosion Concerns
MIRAS-S 67584 35
Should I choose an enamelled or stainless steel 300 L double-coil boiler, and what lifespan and corrosion risk should I expect from stainless steel?
Choose stainless steel only if it is a well-made tank with the right alloy and weld quality; otherwise a cheaper stainless tank can still fail at the welds or in aggressive water, while enamel is cheaper but typically less durable and needs anode replacement [#12457950][#12570734][#12081189] Several users point out that “stainless” is not one uniform material: look for acid-resistant steel such as INOX 316L/316L-equivalent, properly pickled welds, and ideally an inspection opening so sediment can be cleaned out [#12457950][#13647391] Generic stainless tanks are often sold with 8–10 year warranties, but some manufacturers offer 10 years or even a lifetime warranty on better designs; one user cites Viessmann as a good reference, and another notes ACV as a manufacturer that treats welded joints properly [#118?]. Limescale and sludge are mainly a water-quality issue, so a water treatment plant/softener is more effective than cartridge filters, and an inspection hole makes maintenance easier [#12103883][#12101482] For enamelled tanks, one user estimates about 15 years max with anode changes, while another warns that if the enamel fails, corrosion can progress quickly [#12081189][#12086096] Overall, the thread leans toward stainless as the safer long-term choice, but only when the tank is truly good quality and suited to your water conditions [#15941462][#12457950]
  • #31 12571851
    saskia
    Help: 174
    Rate: 1086
    orzech1984 wrote:
    I suggest doing a simple water test first. Then you will know if the chlorine control is actually exceeded.
    I don't have to do the tests, the rams hooked me up to the water supply pipe to the water tower.
    There must always be a higher concentration in this pipe for some of the chlorine to reach the pressure tower. What most water consumers feel as chlorine is the remnants of what went down the pipes to the water tower where most of it evaporates.
    If I close the bathroom while filling the bathtub with water, before half the bathtub is filled with water, there is a gas chamber in the bathroom, it is impossible to enter, not to mention breathing.
  • #32 13213685
    monteron
    Rate: 9
    orzech1984 wrote:
    Don't confuse stainless with acid-proof. Acid-resistant is stainless, but not all stainless steel is acid-resistant. There are a lot of stainless steel alloys and their quality is not always high. That is why we often get anodes for such tanks. Only a few people wonder why? If something is supposed to be stainless, what the hell do they put on me with anode protection? Also, don't look at the price in the first place. Nobody will give anything for free and if something is cheaper, unfortunately, the manufacturer has saved somewhere.
    If you are looking for an acid-resistant tank (INOX 316L) with coils that are also acid-resistant, then in Poland you will only find LAPESA. ACV does only on INOX 304, i.e. stainless steel. Unfortunately, hardly anyone checks such facts and the slogan "stainless steel" is constantly circulating without checking what kind of steel alloy it is. You can't stick a magnet to a real sourdough, which shows that this type of steel really won't stick to the walls. Stainless isn't like that anymore.
    In LAPESA you also have an inspection gangway so you can clean any sediment physically without the need for rinsing. The walls of such an undulating tank work when the water temperature changes, so that if a stone appears there, it will be rejected
    Of course, such tanks can also be destroyed. First of all, you need to pay attention to:
    1. "blading currents". So that they do not destroy the acid-resistant and stainless steel, the installation should be separated from the tank with a material that does not conduct electricity (e.g. a piece of PP or brass).
    2. Chlorine. INOX 316 has twice as much protection against the action of these compounds as INOX 304, so watch out for lifetime guarantees, because when reading the small print, there are written values of chemistry that may be in the water cycle. Then you think you have a guarantee and you find out you don't.
    GREETINGS
    Magnesium will stick to both 304 and 316L and is unrelated to the type of stainless steel. Magnesium will not stick only to ferritic steels because it has a different structure. In fact, the corrosion resistance of steel depends mainly on the elements contained in the steel, in particular molybdenum, chromium and titanium, which protects against corrosion at higher temperatures. There are steels that have a similar chemical composition as 316L and even better because with the addition of titanium to which magnesium will not stick and corrosion resistance will be greater. Indeed, the Lapessa company makes tanks from 316L and praise them but the prices are cosmic 300L tank PLN 5520 net, where Chełchowski PLN 1932 net and Termica PLN 3190 net. Who can afford what. As I have already found out, Termica actually makes them of 304 steel, i.e. linden, while the Chełchowski company has good steel, but they did not give me the grade, they only told me that it is steel like 316L with the addition of titanium that protects against corrosion at high temperatures.
  • A durable boiler needs more than a 316L tank
    #33 13647391
    EkoGrzew
    Help: 28
    Rate: 232
    monteron. Tank only with specification. Never a word. Chełki may already be working in standard on 316 L. But the insulation of this tank....... . Therefore, the price will be lower. It all depends on who can afford what. Producers for what production, buyers for what purchase. But the most important awareness: All the important details should be combined (316L steel tank and coil, pickled welds, inspection hole, polyurethane foam insulation, Alu or PVC jacket) Then we have the perfect... And the perfect costs.... :) .... and so that it does not turn out that the weakest link will be .... an electric heater .... from a subcontractor ... :) :) :)
    P.S. To the moderator: Wouldn't it be better to move this topic to SG Utility to expand the readership?
  • Duplex stainless steel offers longer life without anodes
    #34 15941462
    1977Tomek
    It's like comparing an enallic pot to a stainless steel pot.
    Enamelled - advantages: lower price, good resistance to poor quality water
    Disadvantages - lower durability, the need to replace the anodes, sometimes an unpleasant smell of water due to the anode, high defect
    Stainless - as someone wrote, you can't put all stainless steel in one basket. The best used in Europe is Duplex steel.
    Advantages - very high durability, practically several dozen years when using a water softener, hygienic - no anode, light tank
    Disadvantages - the price is about 1/3 higher than a good enameled tank
    watch out for limescale in the water.
    There are some good manufacturers at reasonable prices with a very decent warranty
    Kingspan Ultra - 12 years, Termica - 8 years, Acv - depends on the type.
  • #35 17306382
    keruza
    Hello, there is also the option of a copper boiler, I bought one 250 liters with a 3 m square coil in the UK I heat the water with a mitsubishi ecodan heat pump revelation 5 kw will charge 25 groszy in the G 13 tariff Albion Aerocyl boiler, I note that it is made entirely of copper, including the coil greetings.
  • #36 18406447
    Mopel44
    Cool. Only if you know how much you paid? How do you assess the costs with depreciation over, say, 15 years?
    As far as I know, copper is not allowed for sanitary hot water installations. I wonder if something like this is even being sold.
    Added after 17 [minutes]:
    We are talking about acid, not stainless steel. Let's be serious. There are two cool films on the market what they will do with 316L 130l for about PLN 2000.
    To a large extent you are right, but it also depends on what you expect from the pot.
    Here we have a tank in the basement and we count the costs and risks - probably everyone has such expectations.
    In order for a standard canister to show possible hidden defects, you must change the anode through the service for 5 years. (I'm curious about titanium because you have a "wonderful" Galmet has been writing back to me for over a week)
    Later, these anodes have to be changed and this is also a cost. Counting, let's say, 20 years (although I would rather see 25-30 here), the whole cost makes sourdough at a reasonable price a cheaper solution. Even a lot. Not even counting a few replacements of the ordinary steel tank. And this is a risk - an additional cost that must be factored in. This cost is unknown and poses a high risk to this alternative in the water mania business :) I don't want that and probably everyone expects that from this investment. How much will the sourdough take?
    With good water, the prospect of a minimum of 30 years is the most appropriate expectation.
    Acid does not seem to catch the stone.
    The pot is not a boiler. Needs may change, I cook something else, the family composition has changed, you change kitchens, you want different ones, this one got bored because I prefer something retro, blackened, it could be damaged.
    The water tank is hanging in the basement and thank you. I think hardly anyone needs to get a new boiler because it already has an ugly casing and you would prefer red and horizontal rather than standing.
The discussion revolves around the choice between enamelled and stainless steel 300-liter double coil boilers, focusing on lifespan and corrosion concerns. Users express that enamelled tanks typically last around 15-20 years, while stainless steel tanks can last significantly longer, with some expecting a lifespan of 50 years or more. Concerns about corrosion and the need for magnesium anodes in stainless steel tanks are raised, with some manufacturers offering warranties ranging from 8 to 10 years. The quality of stainless steel varies, with recommendations for specific grades like INOX 316L for better corrosion resistance. Users also discuss the importance of proper welding techniques and the potential for scale deposits in both types of tanks. Brands like Viessmann, Termica, and ACV are mentioned, with some users advocating for stainless steel due to its durability and lower maintenance needs compared to enamelled tanks.
TL;DR: 300 L double-coil boilers: enamelled ~PLN 2,500, 15-year average life [Elektroda, 12081189]; stainless ~PLN 4,000, often 30 + years if welds hold. “Steel is not equal” [Elektroda, 12397621]
Why it matters: The right tank choice balances upfront cost, long-term durability, and maintenance.
• Purchase price: enamelled 300 L PLN 2,500–3,000; stainless PLN 3,000–4,500 [Elektroda, MIRAS-S, #12081086; Elektroda, marek37372, #12397205] • Warranty range: enamelled 5–7 years; stainless 8–10 years (ACV lifetime option) [Elektroda, robert45, #12081811; Elektroda, 12337309] • Lifespan: enamelled ≤15 years with anode swaps [Elektroda, Anonymous, post #12081189]; stainless 25–50 years when 316L or Duplex used [Elektroda, orzech1984, #12457950; Elektroda, 1977Tomek, #15941462] • Anode cost: change every 1–2 years, ~PLN 100 each time [Elektroda, MIRAS-S, post #12099068] • Water softener: 4-person unit ~PLN 2,000, reduces scale by >80 % [Elektroda, Piotr77777, post #12103883]
Is stainless steel worth the extra PLN 1,500?
Stainless costs about 40 % more yet often serves 25–30 years, twice the enamelled average [Elektroda, MIRAS-S, #12081086; Elektroda, 1977Tomek, #15941462]. Over two decades, lower maintenance and no anode fees offset most of the price gap.
Do stainless tanks need a magnesium anode?
High-grade 316L or Duplex tanks do not. Some 304 tanks include anodes because the lower alloy can pit [Elektroda, berga, post #12082715] ACV treats welds and therefore omits anodes, offering a lifetime warranty [Elektroda, 12337309].
How often should I clean or descale the cylinder?
Open the inspection port every 3–5 years. A 60 L stainless tank yielded half a 10 L bucket of sludge in five years [Elektroda, Piotr77777, post #12101482] Stainless walls shed scale more easily, but deposits still reduce heat exchange.
Can cartridge filters stop limescale build-up?
No. Forum experience shows disposable cartridges remove limited grit but leave hardness unchanged [Elektroda, Piotr77777, post #12103883] A softener or full treatment plant cuts scaling by over 80 % and protects all appliances.
How can I verify weld quality before purchase?
Ask for pickling certification and visual inspection. Smooth, silver welds without discoloration show argon shielding. If possible, pressure-test at 0.5 MPa and brush soapy water along seams; bubbles indicate leaks [Elektroda, jojo32, post #12570734]
Should I insist on an inspection hole?
Yes. It allows manual sludge removal and element replacement. Users cleaning through this port find maintenance easy and hygiene better [Elektroda, MIRAS-S, post #12103817] Models without ports need chemical flushing, raising cost.
Are used stainless tanks a safe deal?
Good brands like Viessmann still fetch high resale values due to long life [Elektroda, Anonymous, post #12086079] Inspect for weld corrosion and request prior water quality data. Replacing a failed coil can erase savings.
How do I replace a magnesium anode in an enamelled tank?
  1. Isolate and drain 10 % of tank water.
  2. Unscrew old anode, install new rod, torque to spec.
  3. Refill, purge air, check for leaks. Whole task takes 30 minutes and prevents hidden corrosion [Elektroda, MIRAS-S, post #12099068]
