Choosing an Efficient 80L Electric Boiler for 2-3 People: Installation, Longevity, and Costs
sirfriday 11718 18
How should I choose an 80 L electric boiler for 2–3 people in terms of capacity, installation, efficiency, and longevity?
Choose a boiler primarily by insulation quality and tank construction, not by brand name or extra electronics, because heat losses and scale formation affect running cost and lifespan the most [#16677509][#16677126] For a 24/7 tariff, a plain mechanical thermostat is enough, and 1.5–2.5 kW heaters are fine for 80–120 L tanks; a continuous water heater only makes sense with more than 18 kW and a 3-phase supply [#16677509][#16672857][#16678731] An 80 L boiler can work for one person and even for 3 people if usage is careful, but 100–150 L is the better target for 2–3 people if you have the space [#16674303][#16675588] During renovation, give the boiler its own circuit with separate overcurrent protection, and optionally its own RCD for better independence if another appliance trips a fault [#16673152][#16676939] If the kitchen is far from the bathroom boiler, a separate small 10 L heater for the kitchen can be a practical solution [#16673152] For longevity, keep the tank temperature around 50°C to limit limescale and reduce scald risk, and look for easy access to the heater, anode, and tank details like weight/thickness and insulation [#16677509][#16677126]
  • #1 16671752
    sirfriday
    Hello, I'm undergoing major refurbishment. I am currently looking for an electric boiler for 1 person, but I would like to buy a little bigger for 2-3 people because the number of people living may change.
    So yes my idea is an 80L boiler
    I found (just a heater) link
    or boiler link2
    Generally, I need or expect more warm water in the bathroom and kitchen, so the installation would be based on this water heating (shower, sink and sink in the kitchen), I am more interested in efficiency, i.e. that the equipment works as it should for a long period of time (no replacement every year for new) .
    I will add that I also do new electrics in the apartment with a view that the boiler will be properly protected so there is no problem with the supply of energy.
    24/7 tariff so it makes no difference whether it heats at night or during the day as I work differently.
    I hope I have sketched the topic enough, please give me a hint :)
  • #2 16672079
    stanislaw1954
    Help: 2013
    Rate: 4675
    In general, this heater, and the boiler, is practically the same. Differences - probably in the equipment - one has electronic control, and thus, various setting options. A second, probably ordinary thermostat. The pros and cons have both. I didn't compare prices, because maybe there will be a bigger difference here. It will be cheaper, probably the one with an ordinary thermostat.
  • #3 16672646
    sirfriday
    The price certainly depends on whether there is electronics or not. The thermostat itself is the simplest and cheapest version. However, a few interesting features for a small price difference will certainly only ask a question about failure, and these two examples I gave only from my search I am open to suggestions of other companies and models.
  • #4 16672857
    wnoto
    Help: 58
    Rate: 744
    If the 24-hour tariff is a continuous water heater please. But this requires a lot of power> 18kW. But then you have little heat loss.
    If you have a boiler, it offers a G12x tariff - where you will heat water at a cheap tariff (only).
  • #5 16673152
    BUCKS
    Help: 536
    Rate: 1087
    I do not know what and how you do but I would give the boiler a separate, dedicated circuit only for the boiler and protected it with a separate differential (RCD) and overcurrent fuse.
    This increases costs but gives greater system independence. For example, if the boiler activates the RCD, the rest of the apartment will work without a problem and vice versa if something in the kitchen / bathroom initiates a differential, the boiler will work because it will have a separate system with protections, so you increase your confidence in access to hot water.
    In the same way I would also connect a washing machine, because a washing machine can sometimes make a difference.
    In the same way, divide other rooms into separate circuits and use several separate differentials, because nothing irritates as one differential for the whole apartment and in the event of a failure of one device cuts off the electricity in the whole apartment.
    Probably what you will do now will serve you several dozen years, so there is no point in saving too much on materials and equipment, because it is better to have a bit too much in this respect than too little, because then it can be a big problem to add.
    As for the tariff, the power plant allows me to change the tariff once a year, so with the boiler for the test you can choose the G12 (day and night) or G12w (weekend) tariff for a year and see what bills you have.
    With the G12, you can easily calculate how much you would pay in the G11 (24-hour) tariff, because you add up the amount of kWh, add the appropriate subscription fees according to the price list and you have a comparison to the penny. Depending on the results, after a year you would stay on G12 (day and night) or continue testing by changing to G12w (weekend) or return to G11 (24-hour).
    In the case of the G12 tariff, you connect the boiler with a timer, which you program to switch on the boiler only during the "cheap" electricity period. In practice, you will judge for yourself what comfort it offers.
    Another thing is that if you are far from the boiler to the kitchen, it may be better to give an 80l boiler in the bathroom, and a smaller one, e.g. 10l for the kitchen. Without so-called DHW circulation, you have to wait a bit before hot water flows, especially if it is a section of pipes from the boiler to the tap in the kitchen that will be several meters long.
  • Insulation losses matter more than boiler features
    #6 16674303
    gaz4
    Help: 77
    Rate: 2983
    In my opinion, the minimum is 50l per one person, the optimal capacity is 100l. If 2-3 people are to use the boiler, it is worth aiming at a capacity of 100-150l. In the case of a large distance between the boiler and the kitchen, you can think of a separate, several dozen liters only for kitchens. In the 24-hour tariff, all "goodies" do not make sense, I would bet on an ordinary mechanical thermostat.
    What really distinguishes boilers in the context of operating costs is the quality of insulation. The documentation should say how much energy (degrees) they lose daily, but you have to look in pdf files because producers for "strange reasons" don't want to brag about that. In one of the threads on the electrode there is a discussion on this topic and good insulation can be several hundred annual savings. This parameter is not important only for people heating the bathroom with electricity - the heat that escapes from the boiler will heat it up so the electric heater will consume less electricity and the balance will zero. In our climate there are only 3-4 months when heating the bathroom is not needed so you can afford a boiler losing more heat which compensates for this inconvenience with smaller dimensions.
  • 100l is optimal, but 80l may be the practical limit
    #7 16674348
    BUCKS
    Help: 536
    Rate: 1087
    There is only one thing, but taking into account the size of the apartment, I see the chances at most for a 80l boiler, unfortunately it is not possible to push into every apartment, and where it can be pressed it will be necessary to compromise, which may mean more disadvantages than advantages because of more water.
    In addition, a lot depends on consumption. I use about 20l for a shower, also 50l is too much for me.
    The quality of the insulation seems to matter, but because of the long breaks during the day, in fact, the more water it is, the better, except that in person I haven't met a boiler over 80 liters.
  • Larger boiler size reduces heat losses
    #8 16674879
    gaz4
    Help: 77
    Rate: 2983
    I used to follow boiler offers and max. hanging capacity was 150l. But in small apartments it can be a problem, however, from what I remember there were a lot of offers around 120l. The larger the boiler, the smaller the external surface in terms of volume, i.e. the smaller the losses. The larger the boiler, the lower the temperature it can be maintained, i.e. we reduce losses again. At least for these two reasons it is worth looking for the largest that can be placed in the apartment. The difference in dimensions 100l and 80l does not have to be big, 100l of the same company is 93 cm high, and 80l 80 cm with identical diameters. The bigger one is about PLN 100 more expensive, and those a dozen or so cm don't make much difference, and 20l of additional water and smaller heat losses are "a plus".
    https://www.bojlery.pl/category/bojlery-elekt...hash=54396b89f030ca2dbff4e20abbc39f97&mobile=
  • #9 16675588
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    If you are renovating, a separate circuit for the boiler socket is recommended. Typical heater power is 1.5 and 2kW. At 2 kW, a separate circuit is required. Differential separately for the boiler in my opinion, no sense. If something is damaged, it should be repaired.
    You only need 80 l for 3 people for 3 people, you also need to use it wisely. You raise at a higher temperature and you have more hot water, and more usable time after mixing to 40-45 degrees. You can additionally install a special 3D thermostatic valve on which you can set any constant temperature you expect to prevent e.g. accidental burns.
  • #10 16676939
    BUCKS
    Help: 536
    Rate: 1087
    For me, additional differentials and appropriate circuit layouts mean greater security and reliability in terms of maintaining power continuity.
    In short, in the event of a breakdown of a device, e.g. a boiler, I minimize the negative effects of a sudden power outage, limit the size of the zone without electricity, and it's much easier to determine the "culprit", which is not senseless but quite important to me.
    I once had 1RCD and failure of one device caused a lack of electricity in the entire apartment and Egyptian darkness.
    Then there was an investigation which caused the RCD to break out and as far as I managed it was generally poor comfort of such a solution, so I definitely advise against 1RCD for the whole apartment.
    It is hard for me to imagine a situation like grandma staying at home alone, because the rest went for the weekend, and suddenly the cycle and there is no electricity in the whole house, because the RCD broke, and after turning on it still breaks.
    If not a separate RCD, only for the boiler, then a separate RCD for the bathroom, because in the case of "we lose" power for the boiler, washing machine, etc., and the kitchen refrigerators work smoothly.
    I would definitely give a person a circuit and an RCD dedicated only to the central heating boiler, because this is a key device and here you can not afford the lack of electricity caused by the breakdown of the RCD by another device.
    Electrical installation repair is an investment for several dozen years, so it's worth doing wisely. During the renovation, adding an additional circuit or an additional RCD is a small cost, while after renovation such changes mean the need for an additional, relatively expensive renovation, which usually generates greater costs than potential benefits.
  • #11 16676962
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    If I have a damaged boiler or a washing machine, I remove the plug from the socket and repair / replace the damaged element. According to your thinking, each circuit should have a separate difference because it can break.
    I, when making electrical installations, usually give two: for lighting and for + ew sockets, for external circuits (lighting, external sockets, gate automation) and 3-phase ones.
    For me, the author can have up to 3 differentials in the bathroom and it doesn't change much about his questions about the boiler. It is more important, for example, to make separate circuits for the boiler and washing machine, and for the socket at the sink. if it has 3-phase power supply and appropriate power allocation, it enables simultaneous heating of water, washing and drying of hair through our "better fishing". :D
    As for the boiler in the bathroom, it's worth thinking about the possibility of draining water from the dropping safety valve, i.e. the drain with a drain to the sewage system with a siphon.
  • #12 16677050
    BUCKS
    Help: 536
    Rate: 1087
    No, that's not my thinking, you don't understand what I mean or you don't want to understand and you draw the wrong conclusions.
    If you want to have 1RCD on all sockets in the whole apartment is your choice.
    During renovation, not everyone thinks and takes into account all variants, so it's worth to signal different options, because then it is usually too late for such changes. And everyone will apply this solution that will meet their needs, so long as it was a conscious decision, not a decision caused by a lack of insight into the subject and lack of full information or full advice from the contractor, etc.
  • #13 16677104
    sirfriday
    I wrote above, I did not specify the fact. But the electrical installation will be made for years and as it should separate circuits will fly, I was thinking about the washing machine but decided that there is no need. In the bathroom, only the boiler and washing machine from electrical appliances, the rest are sockets for razors and other bullshit.
    So I can confidently write that gentlemen's electricity is OK. Thank you for the signals, but I planned the renovation of the apartment "wisely" so as not to have such problems and I try to do everything for years without saving.
    However, now I have a dilemma about the boiler because I still haven't heard specific answers to the question.
    Tomorrow I am going to the supermarkets to ask "professionals" castoramas etc. what they will offer me but I hope that I will get answers or hints here so that I can talk to this "specialist" a bit about.
    The initial assumption is a 80 l boiler because it is for 1 person (max 3 people but occasionally), a small apartment and a small gap between the bathroom (where the boiler) and the kitchen. So it also doesn't make sense for 3D valves.
    The question is what brand of power what something solid would last for years.
  • #14 16677126
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    The durability of the boiler depends on the water quality and pressure in the installation. The most commonly used safety valves with a check valve are the minimum required protection of the boiler, but unfortunately they force the tank to work with a maximum pressure of 6 bar-opening pressure. This situation occurs only when all hot water is selected and the entire tank is heated. Then the greatest stress occurs in the tank and micro cracks in the protective enamel.
    I would assume theoretically such criteria as: a product of a well-known brand on the market for years, relatively the largest weight at the same capacity (wall thickness) and tank insulation thickness (less stoppage loss). The aesthetics of the workmanship, ease of access to the heater, anode, suspension method etc. are also important.
    gaz4
    Help: 77
    Rate: 2983
    Anyone who has done on the site will say that putting only on a brand (even a good one) is pointless. One of the worst car radios I put in was produced by Sony (it had more certificates than it was worth), and on Panasonic's radio I found such an obvious structural error that even a 1st grade technical technical student would have caught it. In the first place I would bet on technical parameters, and only later looked for boilers that would meet them.
    1) The quality of IMHO insulation is crucial because it will affect operating costs. Unfortunately, this information is difficult to find, producers will "cheat their eyes" with some clichés.
    2) The heater power in the case of boilers in the 80-120l range used in the 24-hour tariff does not matter much because 1.5 and 2.5 kW will cope perfectly. Simply any, even the smallest water consumption will cause the temperature to drop, the thermostat will activate and heat up.
    3) When it comes to durability, it should be remembered that the higher the water temperature in the boiler, the more stone, so the less durability. This is another reason to be interested in as much capacity as possible. And if the boiler temperature is around 50 degrees, we will limit limescale, the risk of burns equal to zero, so you do not need additional mixing valves, and after exceeding 50 degrees ceases to multiply.
  • #16 16678731
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Such power requires adaptation of the electrical installation to such a high load. It must always be a 3-phase supply.
  • #17 16679890
    sirfriday
    So, following these steps, are you able to recommend something specific to me?
  • Look for dual 0.8 kW heaters and good insulation
    #18 16683169
    gaz4
    Help: 77
    Rate: 2983
    Nothing specific can be recommended because everyone has specific requirements, and boiler manufacturers like ants. At the beginning of the 90s I wanted to buy a boiler with a max 1.5 kW heater because I did not want it to overload my old installation. As for all angers, all boilers> 50l had 2 kW, it was only in the last store where I came without hope of purchase that I came across the ideal: Elektrolux 60l with 2 heaters 0.8 kW each + switch. Normally he worked on 1 heater, heating it to 50 degrees, only when I had to "drive" it turned on full power. One of the heaters burned out after about 10 years of work, and the other after almost 20 years. Heaters could be replaced without draining the water from the boiler, but this solution is a disadvantage. It simply hinders the transfer of heat to water, so the risk of heater burnout increases.
    In my opinion, you should look at the quality of insulation, I do not think that the manufacturer who saves on everything while doing trash, warmed the boiler well. Unfortunately, this requires tedious browsing of the user manual because only there is this information.
  • #19 16693563
    sirfriday
    I think the topic is exhausted enough and I would like to close it.
The discussion revolves around selecting an efficient 80L electric boiler suitable for 2-3 people, focusing on installation, longevity, and costs. Key considerations include the type of thermostat (mechanical vs. electronic), the importance of insulation quality to minimize energy losses, and the necessity of a dedicated electrical circuit for the boiler to ensure reliability. Participants suggest that while an 80L boiler may suffice, a capacity of 100-150L could be more optimal depending on water usage patterns. The conversation also highlights the significance of proper electrical installation, including the use of separate circuits and differential protection to enhance safety and reliability. Recommendations emphasize evaluating technical parameters over brand loyalty, with a focus on durability and insulation quality.
TL;DR: For 2–3 people, pick a well‑insulated 80–120 L storage heater; 1.5–2.5 kW elements handle it, and “The quality of insulation is crucial.” [Elektroda, gaz4, post #16677509]
Why it matters: This FAQ helps small‑apartment owners choose, wire, and run an efficient 80 L electric boiler without surprise costs.
What tank size fits 2–3 people in a small apartment?
Rule of thumb is about 50 L per person, with 100–150 L optimal for 2–3 users if space allows. When space is tight, an 80 L unit can work, but expect shorter back‑to‑back shower autonomy. [Elektroda, gaz4, post #16674303]
Is an 80 L boiler actually enough for daily showers?
Yes, for modest use. One user reports about 20 L per shower, and 80 L units are common where space is limited. Usage patterns and set temperature decide comfort between consecutive draws. [Elektroda, BUCKS, post #16674348]
Should I choose storage or instantaneous if I’m on a 24/7 tariff?
With a 24‑hour tariff, an instantaneous heater is suggested, but it needs over 18 kW available. If you go storage, pairing with a dual‑rate (G12/G12w) schedule can cut costs. [Elektroda, wnoto, post #16672857]
Do I need smart electronics, or is a mechanical thermostat fine?
For flat 24/7 pricing, extras add little. A simple mechanical thermostat is cost‑effective and reliable for storage heaters. “Goodies do not make sense” under that tariff model. [Elektroda, gaz4, post #16674303]
What element power should I pick—1.5 kW or 2 kW?
Both work for 80 L storage. Typical elements are 1.5–2 kW; at 2 kW run a separate circuit. Add a thermostatic mixing valve if you raise setpoint for more usable volume. [Elektroda, andrzej lukaszewicz, post #16675588]
How should I wire the boiler for uptime and safety?
Give the boiler a dedicated circuit with its own RCD and overcurrent breaker. This keeps hot water available if another circuit trips. How‑To: 1) Plan a dedicated line. 2) Install separate RCD+MCB. 3) Label the circuit clearly. [Elektroda, BUCKS, post #16673152]
Can tariff switching really lower bills with a storage heater?
Yes. Try G12 (day/night) or G12w (weekend) for a year and log kWh. Use a timer so the boiler heats during “cheap” periods, then compare to G11 costs line‑by‑line. [Elektroda, BUCKS, post #16673152]
Kitchen is far from the bathroom—what’s the fix for long waits?
Place the main 80 L tank in the bathroom and add a small (≈10 L) under‑sink heater for the kitchen. This cuts delays without DHW circulation. [Elektroda, BUCKS, post #16673152]
How much do standby losses matter on my bill?
A lot. Insulation quality drives operating cost; manufacturers list daily heat loss in manuals. Better insulation can yield substantial yearly savings. “Insulation can save several hundred annually.” [Elektroda, gaz4, post #16674303]
What temperature setpoint balances safety, scale, and comfort?
Around 50 °C limits limescale and burn risk while keeping comfort. Larger tanks let you hold lower temperatures and reduce losses. “The quality of insulation is crucial.” [Elektroda, gaz4, post #16677509]
Which brands are best for longevity?
Don’t buy on brand alone. Focus on technical parameters, especially insulation specs in manuals. Choose models meeting your requirements; brands vary by series and year. [Elektroda, gaz4, post #16683169]
What actually determines tank durability?
Water quality and pressure matter most. Safety valves often open at 6 bar; full heat cycles can stress enamel and cause micro‑cracks. Favor heavier tanks and thick insulation, plus easy access to heater and anode. [Elektroda, andrzej lukaszewicz, post #16677126]
Do I need a thermostatic mixing valve (3D)?
It’s recommended if you run higher tank temperatures. A 3‑way thermostatic valve delivers constant 40–45 °C at taps and prevents scalds during mixing. [Elektroda, andrzej lukaszewicz, post #16675588]
Can my existing wiring support an 18 kW instantaneous heater?
Only if adapted properly. Such power requires a three‑phase supply; confirm service capacity before considering instantaneous systems. [Elektroda, Zbigniew Rusek, post #16678731]
Is 80 L workable for occasional use by three people?
Yes, with “wise” use. Raise the tank temperature and mix down to extend usable hot water across back‑to‑back draws. Add a mixing valve for safety. [Elektroda, andrzej lukaszewicz, post #16675588]
