300L Double Coil Boiler: Enamelled vs Stainless Steel - Lifespan and Corrosion Concerns
MIRAS-S 67581 35
Should I choose an enamelled or stainless steel 300 L double-coil boiler, and what lifespan and corrosion risk should I expect from stainless steel?
Choose stainless steel only if it is a well-made tank with the right alloy and weld quality; otherwise a cheaper stainless tank can still fail at the welds or in aggressive water, while enamel is cheaper but typically less durable and needs anode replacement [#12457950][#12570734][#12081189] Several users point out that “stainless” is not one uniform material: look for acid-resistant steel such as INOX 316L/316L-equivalent, properly pickled welds, and ideally an inspection opening so sediment can be cleaned out [#12457950][#13647391] Generic stainless tanks are often sold with 8–10 year warranties, but some manufacturers offer 10 years or even a lifetime warranty on better designs; one user cites Viessmann as a good reference, and another notes ACV as a manufacturer that treats welded joints properly [#118?]. Limescale and sludge are mainly a water-quality issue, so a water treatment plant/softener is more effective than cartridge filters, and an inspection hole makes maintenance easier [#12103883][#12101482] For enamelled tanks, one user estimates about 15 years max with anode changes, while another warns that if the enamel fails, corrosion can progress quickly [#12081189][#12086096] Overall, the thread leans toward stainless as the safer long-term choice, but only when the tank is truly good quality and suited to your water conditions [#15941462][#12457950]
  • #1 12081086
    MIRAS-S
    Level 19  
    Help: 21
    Rate: 91
    I plan to buy a new 300 liter double coil boiler, but unfortunately I have a dilemma. Enamelled or stainless steel.
    Price:
    enameled PLN 2,500
    stainless steel 4000 thousand
    The real difference is PLN 1500
    How much stainless steel can have a real-time use guarantee and whether it can actually corrode or become overgrown with deposits that will reduce its thermal conductivity coefficient.
    From stainless steel, I would expect at least 50 years.
    Steel enamelled, I assume that a well-made one can last up to 20 years.
    Searching for answers on the Internet, I did not find a ready-made recipe.
    Ask your colleagues for honest opinions.
  • #2 12081189
  • #3 12081324
    mstasiek
    Help: 5
    Rate: 20
    Hello. Stainless (stainless steel) would be practically speaking with normal
    indestructible in use. Of course, the coil should also be made of this steel.
  • #4 12081811
    robert45
    Help: 44
    Rate: 89
    There is a domestic manufacturer of T...ca (I don't know if I can give the name of the company), which in the case of a 300l tank made of stainless steel, and coils also made of stainless steel, gives an 8-year warranty.
  • #5 12081913
    mstasiek
    Help: 5
    Rate: 20
    Hello. It is known that no one will give a lifetime guarantee, it would be pointless.
    If it gives you 8 years, it's still good (a company with prospects for the future) :D
  • #6 12082715
    berga
    Help: 12
    Rate: 73
    MIRAS-S wrote:
    From stainless steel, I would expect at least 50 years...
    And what are you basing that on?
    Stainless (stainless steel) would be practically speaking at normal
    There are no indestructible things. Why do some manufacturers of stainless steel tanks equip their products with magnesium anodes and give a 3-year warranty? Or why they only give 8 years, and almost everyone gives 10 years for solar collectors?
    Tanks are made of sheet metal by welding, those made of stainless steel are much lighter. Welding thin and brittle sheet metal well is a real challenge, and it can be done better or worse.
  • #7 12085957
    MIRAS-S
    Level 19  
    Help: 21
    Rate: 91
    Hello dear group.
    Of course, I know that in order to make a good stainless steel tank, you need to have a lot of knowledge and skills to weld from this fragile sheet, as a colleague mentioned.
    Companies that do not give a 5-8 year guarantee for tanks because this is their guarantee, but how would the actual durability of such a tank be for corrosion if it arises, or for example for scale deposition on the walls or water deposits.
    I think that the best test of such tanks is the food industry.
    If you have met with companies that you think can be recommended that make good enamelled or stainless tanks, please write to the PM. in order not to make surreptitious advertising.
  • #8 12086079
  • #9 12086096
    pablowp1
    Help: 46
    Rate: 144
    Today, there is no good enamel tank anymore. A sensible choice is a stainless steel tank, even a used one. If it gets stoned, there are ways to flush it out. However, when the enamel falls, only the steelworks is waiting for it. A few weeks ago, called for a breakdown, I found: a 300l tank, enamelled, 2x coil from a well-known Polish company ko .....l fell after a year of operation. A hole in the weld. Such examples can be multiplied. The tendency is this: it has to be cheap and it has to break down because what will the factories do when their goods will be eternal.
  • #10 12086196
    MIRAS-S
    Level 19  
    Help: 21
    Rate: 91
    Thank you.
    Give as many opinions as possible about the tanks poor had better choices.
    I know that enamel must be well made and enamel is brittle as on the proverbial pots.
    Just a micro pore and the tank will corrode.
  • #11 12087855
    pablowp1
    Help: 46
    Rate: 144
    At balegro, you can easily find the used containers you want. I recommend you a guy from Jelenia Góra, he only has stainless steel, whatever you want. I used to buy a coat for a client from him, I picked it up personally to see what the guest represented. Recommendable. And the hula tank purchased from him is so nice. :D
  • #12 12099068
    MIRAS-S
    Level 19  
    Help: 21
    Rate: 91
    However, I will choose to buy stainless steel because I am not convinced about the electroplating of the steel and its good workmanship.
    The enamel tank is not cheap and the 5-year warranty does not convince me, and the cost with two coils is from PLN 2,500.
    In addition, the magnesium anode needs to be replaced, which is also the cost of maintaining the tank.
    When it comes to stainless steel, there is also a large selection and you can find it at a good price, starting at PLN 3,500.
    It should be noted that not all manufacturers include an electric heater and a safety valve, e.g. in Termica, a Polish manufacturer.
    Termica has an inspection opening.
    At the moment, the price of JOULE - CYCLONE, an Irish manufacturer, is very good.
    The boiler is standard equipped with a heater and a safety valve.
    JOULE - CYCLONE has no inspection hole.
  • #13 12101482
    Piotr77777
    Heating systems specialist
    Help: 58
    Rate: 266
    I would look with an inspection hole, our water is not wonderful unless you live in the mountains.
    Recently, I cleaned the 60L acid tank and pulled out half a bucket of 10 liter sludge from it after 5 years of operation.
  • #14 12103817
    MIRAS-S
    Level 19  
    Help: 21
    Rate: 91
    Of course, I will look for one with an inspection hole because it should be a standard because the tank is to be used for a very long time, cleaning should be every few years.
    I wonder if the filters in front of the boiler with replaceable cartridges are able to filter about 90% of impurities from the water.
    And one more suggestion.
    Are there limescale deposits on enamel and stainless steel tanks?
    I talked to the installer and he claimed that he met with scale on the walls of the enamel tank and even removing it with a high-pressure washer did not help.
  • #15 12103883
    Piotr77777
    Help: 58
    Rate: 266
    Don't count on it, the only solution to this is a water treatment plant. It is worth considering such a device because not only the tank will be protected, but also the rest of the devices.
    The cost of the station for 4 people is about PLN 2,000.
  • #16 12246191
    Maciek_Wyp
    I bought a stainless steel tank from the German company Bregus. I got a 10 year warranty and the normal price. I just have a tank with two coils for solar collectors.
  • Viessmann stainless tanks retain value on secondary market
    #17 12336633
    monteron
    Rate: 9
    [quote="Walker29"]Viessmann made very good stainless tanks. Check how many of them are still on the secondary market and they are worth a lot of money.
    Maybe on the secondary market anyway, because the prices of new ones are cosmic and much more expensive than termica, not to mention the Chelchowski and also stainless steel. If you buy a used one, I'm curious how much does it cost you? - a year, two three top !!!!
  • Stainless tank durability depends on welding and joint treatment
    #18 12337309
    szymonjasiu
    Help: 29
    Rate: 138
    indestructible to use.
    The only company that makes stainless steel tanks properly is ACV
    As one of the two companies in Europe producing stainless steel, it treats welded joints. Since recently, it has offered a lifetime guarantee.
  • #19 12397205
    marek37372
    PLN 6,000 for 300 l of capacity is probably an exaggeration, the seller is expensive for 300 l, a German tank with 2 coils PLN 2,998 + shipping, see:
    "boiler exchanger tank STAINLESS STEEL 300l 2W"
    JOULE CYCLONE parameters as above PLN 3575
  • #20 12397621
  • 316L tanks resist corrosion better than 304 steel
    #21 12457950
    orzech1984
    Don't confuse stainless with acid-proof. Acid-resistant is stainless, but not all stainless steel is acid-resistant. There are a lot of stainless steel alloys and their quality is not always high. That is why we often get anodes for such tanks. Only a few people wonder why? If something is supposed to be stainless, what the hell do they put on me with anode protection? Also, don't look at the price in the first place. Nobody will give anything for free and if something is cheaper, unfortunately, the manufacturer has saved somewhere.
    If you are looking for an acid-resistant tank (INOX 316L) with coils that are also acid-resistant, then in Poland you will only find LAPESA. ACV does only on INOX 304, i.e. stainless steel. Unfortunately, hardly anyone checks such facts and the slogan "stainless steel" is constantly circulating without checking what kind of steel alloy it is. You can't stick a magnet to a real sourdough, which shows that this type of steel really won't stick to the walls. Stainless isn't like that anymore.
    In LAPESA you also have an inspection gangway so you can clean any sediment physically without the need for rinsing. The walls of such an undulating tank work when the water temperature changes, so that if a stone appears there, it will be rejected
    Of course, such tanks can also be destroyed. First of all, you need to pay attention to:
    1. "blading currents". So that they do not destroy the acid-resistant and stainless steel, the installation should be separated from the tank with a material that does not conduct electricity (e.g. a piece of PP or brass).
    2. Chlorine. INOX 316 has twice as much protection against these compounds as INOX 304, so watch out for lifetime warranties, because when reading the small print, there are values of chemicals that may be in the water cycle. Then you think you have a guarantee and you find out you don't.
    GREETINGS
  • #22 12467989
    marek37372
    this exchanger is German, steel 1.4301, or if you prefer 304 (American standard)
    available in Poland, so if you want, you can make 500 liters out of 300 l, good welder with tig and flowers...
  • #23 12468034
    orzech1984
    welcome back
    It's just that INOX 304 L is the symbol of 1.4307
    You gave ordinary INOX 304 steel. Besides, I don't suggest giving it to an ordinary welder. Improper welds will cause the tank to rot in these places.
  • Clarifying 304 steel, weld corrosion, and argon shielding
    #24 12468297
    marek37372
    I wasn't talking about 304L stainless steel, only about 304 steel
    I found an INVESTA catalog with equivalents online
    the second thing, in this topic, when it comes to corrosion at the contacts of steel, it is electrolytic corrosion, as someone welds a different type of sheet metal with a different wire,
    it was about refining, it was probably about pickling welds with preparations containing hydrofluoric acid, another issue when welding is to provide an argon shield on the other side of the welded sheets, the welder with whom I worked for many years knows his stuff and ate bread from many ovens
    and here is a link to the grades of stainless steel
    http://www.investa.pl/oferta/stal_nierdzewna_poradnik_tabela_gatunkow.html
  • #25 12470806
    saskia
    Help: 174
    Rate: 1086
    As you've probably all noticed, the stainless steel itself doesn't make any effect. maybe an advertising effect. :-)
    Proper manufacturing, + correct finishing, + correct operation, = lifetime warranty.
    There's nothing for free :-(
  • #26 12473203
    orzech1984
    I do not know why such texts descending on some political issues, since we are talking about tanks. I meant only to state the fact which was also noticed by "Walker29" - steel is uneven.
  • #27 12474266
    saskia
    Help: 174
    Rate: 1086
    OKAY. I corrected. :-)
  • #28 12488452
    saskia
    Help: 174
    Rate: 1086
    Slightly off topic, but might be useful in this thread.
    Well, I'm getting ready to make and install a water dechlorination device.
    I have a house 200m from the treatment plant and sometimes I have the impression that more chlorine (hypochlorite) comes out of the tap than water. :-(
    I thought about inserting into the circuit already after the meter, a tank similar to an automatic air vent, only with a capacity of about 10l.
    It would mainly collect the air pumped to the water supply at the water treatment plant, but the chlorine contained in the water should also be released along with the air.
    The problem may be that the vent will be leaking air all the time, so there won't be much surface area for more chlorine to escape from the water.
    Does anyone of you know a ready-made and easily accessible device (tank) that would act as an "overgrown" vent and have a structure ensuring continuous flow in the fish, a sufficiently large surface to degas the chlorine from the water. It's mainly about the continuous maintenance (despite venting) of the air cushion that provides the water level in the tank.
    I already have a water pressure reducer.
  • #29 12496858
    orzech1984
    I suggest doing a simple water test first. Then you will know if the chlorine control is actually exceeded.
  • #30 12570734
    jojo32
    Gentlemen, I think this stainless steel will withstand it, such a tank will serve for quite a few years. But the problem is in the welds. Nice, also nicely located only its sides, the trail hits I'm talking about the sides of the weld and its edges. with air and spraying with soapy water along the entire length of the weld, bubbles were released until a nice one, even with a small pressure, released on the seam. After some time, a friend called that his neighbor has a sour water boiler and he is leaking if I will weld him. It turned out to be the same leak on the side of the weld along its entire length. The Lord gave a lot of money to serve him for a long time, and here is five years and you have to buy a new one. He decided on enamel and we'll see how much it will serve him.
The discussion revolves around the choice between enamelled and stainless steel 300-liter double coil boilers, focusing on lifespan and corrosion concerns. Users express that enamelled tanks typically last around 15-20 years, while stainless steel tanks can last significantly longer, with some expecting a lifespan of 50 years or more. Concerns about corrosion and the need for magnesium anodes in stainless steel tanks are raised, with some manufacturers offering warranties ranging from 8 to 10 years. The quality of stainless steel varies, with recommendations for specific grades like INOX 316L for better corrosion resistance. Users also discuss the importance of proper welding techniques and the potential for scale deposits in both types of tanks. Brands like Viessmann, Termica, and ACV are mentioned, with some users advocating for stainless steel due to its durability and lower maintenance needs compared to enamelled tanks.
TL;DR: 300 L double-coil boilers: enamelled ~PLN 2,500, 15-year average life [Elektroda, 12081189]; stainless ~PLN 4,000, often 30 + years if welds hold. “Steel is not equal” [Elektroda, 12397621]
Why it matters: The right tank choice balances upfront cost, long-term durability, and maintenance.
• Purchase price: enamelled 300 L PLN 2,500–3,000; stainless PLN 3,000–4,500 [Elektroda, MIRAS-S, #12081086; Elektroda, marek37372, #12397205] • Warranty range: enamelled 5–7 years; stainless 8–10 years (ACV lifetime option) [Elektroda, robert45, #12081811; Elektroda, 12337309] • Lifespan: enamelled ≤15 years with anode swaps [Elektroda, Anonymous, post #12081189]; stainless 25–50 years when 316L or Duplex used [Elektroda, orzech1984, #12457950; Elektroda, 1977Tomek, #15941462] • Anode cost: change every 1–2 years, ~PLN 100 each time [Elektroda, MIRAS-S, post #12099068] • Water softener: 4-person unit ~PLN 2,000, reduces scale by >80 % [Elektroda, Piotr77777, post #12103883]
Is stainless steel worth the extra PLN 1,500?
Stainless costs about 40 % more yet often serves 25–30 years, twice the enamelled average [Elektroda, MIRAS-S, #12081086; Elektroda, 1977Tomek, #15941462]. Over two decades, lower maintenance and no anode fees offset most of the price gap.
Do stainless tanks need a magnesium anode?
High-grade 316L or Duplex tanks do not. Some 304 tanks include anodes because the lower alloy can pit [Elektroda, berga, post #12082715] ACV treats welds and therefore omits anodes, offering a lifetime warranty [Elektroda, 12337309].
How often should I clean or descale the cylinder?
Open the inspection port every 3–5 years. A 60 L stainless tank yielded half a 10 L bucket of sludge in five years [Elektroda, Piotr77777, post #12101482] Stainless walls shed scale more easily, but deposits still reduce heat exchange.
Can cartridge filters stop limescale build-up?
No. Forum experience shows disposable cartridges remove limited grit but leave hardness unchanged [Elektroda, Piotr77777, post #12103883] A softener or full treatment plant cuts scaling by over 80 % and protects all appliances.
How can I verify weld quality before purchase?
Ask for pickling certification and visual inspection. Smooth, silver welds without discoloration show argon shielding. If possible, pressure-test at 0.5 MPa and brush soapy water along seams; bubbles indicate leaks [Elektroda, jojo32, post #12570734]
Should I insist on an inspection hole?
Yes. It allows manual sludge removal and element replacement. Users cleaning through this port find maintenance easy and hygiene better [Elektroda, MIRAS-S, post #12103817] Models without ports need chemical flushing, raising cost.
Are used stainless tanks a safe deal?
Good brands like Viessmann still fetch high resale values due to long life [Elektroda, Anonymous, post #12086079] Inspect for weld corrosion and request prior water quality data. Replacing a failed coil can erase savings.
How do I replace a magnesium anode in an enamelled tank?
  1. Isolate and drain 10 % of tank water.
  2. Unscrew old anode, install new rod, torque to spec.
  3. Refill, purge air, check for leaks. Whole task takes 30 minutes and prevents hidden corrosion [Elektroda, MIRAS-S, post #12099068]
