Samsung Galaxy Y: Fix Not Registered on Network Error - Automatic Network Detection Issues
153210 14
Why does my Samsung Galaxy Y show "not registered on the network" and fail to connect when automatic network detection is enabled after a factory reset?
The phone is most likely SIM-locked or blocked by the operator, so it cannot register on the network, and the factory reset is probably not the real cause. Try removing the SIM, rebooting the phone, then inserting the card again so the operator settings can arrive by SMS; if that does not work, get the settings from your operator’s website or enter them manually [#12114376] Check the lock status with *#7465625# and compare the IMEI with *#06# against the sticker on the phone [#12114573][#12114594] If the IMEI matches but the phone still cannot connect to any network, the thread points to a blocked/blacklisted handset from the pawnshop, and the practical fix was to return it [#12114487][#12149942]
  • #1 12114343
  • #2 12114376
    voitek1
    Help: 330
    Rate: 287
    If it's a new card, remove the card and turn on the phone again. After that, switch off, insert the card and turn on the phone again. You should get automatic settings on the phone via SMS. If not, you can set it by going to the operator's website and sending the settings to yourself, or by entering them yourself. If it still does not work, you either have a simlock or the card is not paid or you are in the roaming area where the operator has no signed contract.
    What operator?
    What specific model?
    You are in Poland?
  • #3 12114480
  • #4 12114487
    voitek1
    Help: 330
    Rate: 287
    Well, it's probably a theft lock ...
  • #5 12114488
  • #6 12114573
    grubas
    Level 40  
    Help: 647
    Rate: 553
    Do you have the correct imei? Do you have a new phone, or did you buy it from someone or at an auction?
  • #7 12114589
  • #8 12114594
    grubas
    Level 40  
    Help: 647
    Rate: 553
    It may be, as a colleague wrote above - stolen - and the operator blocked it.
    Imei check and compare with sticker * # 06 #
  • #9 12114600
  • #10 12117239
    plustek
    Help: 176
    Rate: 200
    When he calls 112, it must be stolen and blocked.
  • #11 12117491
  • #12 12117595
    voitek1
    Help: 330
    Rate: 287
    regut12 wrote:
    ... And besides, there shouldn't be stolen phones in the pawnshop ...
    You're right - it shouldn't be. ...
    But I suspect they are. Give it back as you can.
    ... And by the way, it's strange that you didn't check if it worked when you bought it :?:
  • #13 12117618
    grubas
    Level 40  
    Help: 647
    Rate: 553
    Did you buy it with a box or in bulk?
  • #14 12149942
  • #15 12715135
    Heihachi Mishima
    Help: 12
    Rate: 10
    in my opinion it is the same as in the case of samsung galaxy s3
    a colleague was playing with softami or the modem driver trying to improve the coverage in the phone.
    You can't go back too much of the software version, especially the modem driver, because later the new "Not registered in the network" problem occurs.
    In my case, in sgs3 it was enough to install a warped modem.
    (why did I get the message "Not registered in the network"? For the fact that I had a newer modem and I wanted to improve the range at the expense of the battery - I read the stupidity from the net that the DLID1 modem is great that it does not tear the net and hsdpa has so many dashes that no one is there He did not write that you should have an older modem in the phone than DLID1 and I had a newer one and I uploaded an older one and the problem that the phone became like a tablet without GSM. After uploading the stored modem, the problem disappeared as the hand went away ... sure to go on sites only move your head ...
    If someone found this post with the same problem with the galaxy S3 phone, he gives a link
    http://forum.android.com.pl/f28/problemy-podc...4-1-2-i-4-2-2-nie-zarearzenia-w-sieci-333406/ if you have andka 4.1.2 then install only from point 2.
    In galaxy Y I would be looking for a similar solution.
The discussion revolves around a Samsung Galaxy Y experiencing a "not registered on the network" error, particularly after a factory reset. Users suggest troubleshooting steps such as removing and reinserting the SIM card, checking for SIM lock issues, and verifying the IMEI number. The problem may stem from a theft lock or an incorrect modem driver, as indicated by a user who experienced similar issues with a Samsung Galaxy S3. The original poster, who purchased the phone from a pawnshop, ultimately returned the device after confirming the problem persisted.
