Switching off devices automatically when leaving the house via alarm relay?
jurekszczurek 3291 3
  • #1 12233400
    jurekszczurek
    As there is a lot of talk about taking devices off the mains(standby TV, chargers), an idea came to me of cutting off power to certain circuits via the alarm. E.g. I switch on the alarm when leaving the house and, apart from powering the alarm, fridge, gate, pond pump, etc., there would be no power in the other sockets. Additionally, a device accidentally left on would not draw power.
    Is it possible to use electronic relays for this purpose ? I think a normal contactor would draw more current than an electronic one and it would be easier to control an electronic one e.g. voltage 3-32 v.
    Can it be controlled directly from the alarm or do you need to make some kind of separator ?
  • #2 12233425
    azibik
    Level 32  
    Help: 82
    Rate: 324
    The electronic relay has an isolated input from the switched circuit
  • #3 12259572
    JohnySpZOO
    Electric installations specialist
    Help: 186
    Rate: 330
    When using relays, it is important to bear in mind their rated current carrying capacity and resistance to short-circuit currents.
  • #4 13894843
    jurekszczurek
    Thanks everyone - relays bought but no time to set up- maybe in autumn there will be some time....
    topic closed
