Mouse cursor not visible after minimizing game window and switching to desktop
Pumbinio 33420 10
How can I make the mouse cursor visible again after minimizing a game and switching back to the desktop?
Try updating or reinstalling the graphics drivers first, and then restore the game with Alt+Enter if the cursor still disappears [#12233932] [#12234147] If that does not help, check the graphics/desktop settings, including Aero, because one user reported that changing graphics settings together with driver updates fixed it [#12234102] On older systems, enabling mouse pointer trails and setting their intensity to the minimum can also prevent the cursor from vanishing [#12234142]
  • #1 12233859
    Pumbinio
    Hello, I have a problem with the mouse cursor. I will try to explain it as simply as possible, i.e. I turn on the game and minimize it to turn on the music and suddenly there is no mouse cursor. Then I have to grope, i.e. at random, if I hit the "play" button, I will hit it and if not, then I won't :)
  • #2 12233932
    pawel-jwe
    Level 30  
    Help: 123
    Rate: 273
    Reinstall graphics drivers (try updating to newer or older ones).
  • #3 12234096
    Svik
    Help: 17
    If the method provided by Paweł does not help, try to scan the system with MBAM Adwcleaner and finally CCleaner.
  • #4 12234102
    MrDoimer
    Help: 271
    Rate: 125
    Svik wrote:
    system with Mbam Adwcleaner and finally CCleaner.
    It's not an infection...
    I've never felt like an author myself.
    Playing around with graphics settings, updating graphics card drivers, and cleaning the registry helped.
    I don't remember what exactly I did in the settings, but give it a connection with the desktop graphics (e.g. Aero).
    What system is this?
  • #5 12234114
    Svik
    Help: 17
    I just had the same as Author and it turned out that the culprits are viruses.
    Let him first reinstall the drivers as it was suggested, if nothing works then you can try my idea.
  • #6 12234142
    Maciej Raniś
    Help: 15
    Rate: 37
    If the methods suggested above do not help, it is worth trying to enable the "show traces of the pointer" option in the mouse settings (this was the case in XP), and then set the intensity to the minimum so that it is not annoying. This was the only way to get the cursor to disappear on a vintage ATI Rage laptop I used a while ago.
  • #7 12234147
    JPE
    Rate: 18
    try pressing left alt+enter after you restore the game window
  • #8 12234178
    Pumbinio
    No responses helped. :(
  • #9 12234187
    MrDoimer
    Help: 271
    Rate: 125
    did you do it? :
    MrDoimer wrote:
    It helped to play with the graphics settings, update graphics card drivers, and clean the registry.
  • #10 12234195
    Pumbinio
    that's how I did everything and I still don't know what the hell is going on, I wonder how I would format
    Added after 5 [minutes]:
    before everything was normal, and now it's broken for a few days, I understand if I was messing with the options or something but I didn't touch anything
  • #11 21050498
    kubajel1993
    Hello!
    I have a problem that when I started the first stream of the Global City game, the cursor worked properly. However, now when I wanted to start a second stream from the same game, the cursor was not visible. It seems nothing has changed since the first stream. What went wrong?
The discussion revolves around a user experiencing a disappearing mouse cursor issue after launching a game. Various solutions are proposed, including reinstalling or updating graphics drivers, scanning for malware using tools like MBAM Adwcleaner and CCleaner, and adjusting graphics settings related to desktop graphics. Some users suggest enabling the "show traces of the pointer" option in mouse settings and using keyboard shortcuts like Alt+Enter to restore the game window. Despite trying these methods, the original poster reports ongoing issues, indicating that the problem persists even after previous successful gameplay.
