Acer Aspire 5100: Mouse Cursor Disappears in Windows 8 After Logging In and Out
KubaKK. 37476 8
  • #1 16544960
    KubaKK.
    Rate: 26
    I have a very big problem. When I opened a program in the laptop, the mouse cursor hung. He was visible. After logging out and logging in, the cursor disappeared for good. The laptop is an Acer Aspire 5100.
    I checked in the device manager, everything is there. The cursor just disappeared and I can not use it.
    Please help.
  • #2 16544993
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Did you try to restart the system?
  • #3 16545109
    KubaKK.
    Rate: 26
    A few times, to no avail.
  • #5 16545904
    KubaKK.
    Rate: 26
    Thanks, I'll check these three ways right away. I tried emergency mode via settings, but unfortunately I do not have a Windows tile.
    That's how it controls right now ;)
    Added after 8 [minutes]:
    Unfortunately, there is also no cursor in safe mode :(
  • #6 16545992
    RADU23
    Help: 2428
    Rate: 1732
    Two more things:
    - connect an external USB mouse
    - run the bootable Linux LiveCD system
  • #7 16546259
    KubaKK.
    Rate: 26
    Thanks, I'll check how I'll be at home :)
    If the cursor appears after attaching the USB mouse, then the touchpad has broken, and if not, is the system failing?
  • #8 16546305
    RADU23
    Help: 2428
    Rate: 1732
    Exactly, we're trying to find the reason.
  • #9 16546825
    KubaKK.
    Rate: 26
    I do not believe :D all you had to do was press the Fn + f7 key combination to show the cursor ... more than a week I was tired of Tab and arrows, and here is something like that :D
    Thanks for your willingness, and I apologize for turning my head away :D
    subject to be closed :)
The discussion revolves around an issue with the Acer Aspire 5100 laptop, where the mouse cursor disappears after logging in and out of Windows 8. The user initially experiences a hanging cursor and, after logging out, finds it completely missing. Various troubleshooting steps are suggested, including restarting the system, checking in safe mode, using keyboard navigation, connecting an external USB mouse, and running a bootable Linux LiveCD. Ultimately, the user discovers that pressing the Fn + F7 key combination resolves the issue by restoring the cursor visibility.
