MEDION AKOYA md 98360 Laptop - Startup Issues, Unresponsive Display & Ejecting Drive
baddave2010 3732 8
  • #1 12257293
    baddave2010
    Welcome cordially as above in the subject I found such a laptop.
    Generally, it fires every time but!
    As the battery is starting, the drive slides out, only later when the power is pressed, the same happens without the battery starts on the panel the ignition LED is on, the drive is ejected. I turned it on to the first part and nowhere to be seen burned. I would like to add that after the ignition, nothing can be heard, neither the windmill nor the matrix will be illuminated. I tried to connect to HDMI because it's the only output switching the key combination Fn + F3 also nothing, the disconnected matrix also nothing.
    Cold slap
    Anyone have any suggestions where to look for a failure?
  • #2 12257310
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    You need to perform the whole disc diagnostic procedure and measurements.
  • #3 12257328
    Simmi
    Help: 6
    If the processor is completely cold during operation, I would first try to replace the processor - if that does not help, the problem may lie in the CPU converter.
  • #4 12257421
    baddave2010
    Simmi, unfortunately, I do not have any such prock on i3. I will find a plate scheme somewhere?
    I would like to add that the inside comes as if hissing when the laptop is charging, and when the power supply is disconnected it is possible to short circuit? Without a battery and connected power supply, this is not the case
  • #5 12257963
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    baddave2010 wrote:
    I will find a disc diagram somewhere?
    Give it a sign.
  • #6 12258866
    baddave2010
    I give the designation of the motherboard exactly in this frame.
    M10H1 MB09936-1
  • #7 12259127
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    M10H1 MB09936-1
    No other signs?
    Provide a cast for the disc.
  • #8 12259265
    baddave2010
    I have marked here such a small scalout lacks one leg I do not know why. In general, you can see that the laptop near the touchpad buttons was flooded. I had isopropanol I cleaned these places and brushed clean capacitors etc.
    The symptom is that. After inserting the battery, the charging diode lights up. Sam starts the drive the disc in the drive spins. After pressing the power LED on the panel lights up, the drive no longer moves.
    Cold slap.
    Any suggestions ?
  • #9 12259500
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Paste a better quality photo.
The discussion revolves around startup issues with the MEDION AKOYA md 98360 laptop, characterized by an unresponsive display and an ejecting drive. The user reports that the laptop powers on but fails to show any signs of activity, such as fan operation or display illumination. Suggestions from other users include performing a full disk diagnostic, considering a processor replacement if it remains cold during operation, and checking the motherboard for damage, particularly near the touchpad area where liquid damage was noted. The user also mentions a hissing sound when charging and provides a photo indicating a missing leg on a component. Despite attempts to troubleshoot, the laptop remains unresponsive after pressing the power button.
