AEG Mini Home Theater 4606 amplifier – how to power on standalone?
1kaczucha 7734 4
  • #1 12308736
    1kaczucha
    Rate: 40
    I came in possession of the AEG amplifier, most likely from set 4606 (judging by the photos found on the web). I would like to use it as an independent amplifier. After connecting, nothing happens (there is no switch) and here I have a question; do you need to somehow excite equipment using the "power control in" located on the back panel (small socket about 3mm with a pin in the middle)? For example, shorting? Do you need a specific signal from the processor?
  • #2 12309006
    dzimi
    Help: 822
    Rate: 1285
    It's hard for a schematic of this device. I suggest opening and checking how the power-on function is implemented. It is possible that there is a relay that only receives a signal to operate. If you can insert a photo of the interior.
  • #3 12309430
    1kaczucha
    Rate: 40
    I think so too - just what signal ..... Below the photo; 1st: general overview with connections marked; 2ga and 3cia: separate amplifier and power board. AEG Mini Home Theater 4606 amplifier – how to power on standalone?
    AEG Mini Home Theater 4606 amplifier – how to power on standalone? AEG Mini Home Theater 4606 amplifier – how to power on standalone?
  • #4 12309751
    dzimi
    Help: 822
    Rate: 1285
    Check the relay power supply. Enter and run.
  • #5 13580312
    1kaczucha
    Rate: 40
    12V. And everything works. Thank you, I'm closing the topic.
