Zipato/Zipabox with DSC alarm: PC5400, line blocking, fixed IP on Neostrada?
metromen 2889 1
  • #1 12318829
    metromen
    Hello everyone,
    my client has a DSC alarm system and would like to have a smart home system compatible with this system, so that he can control the alarm and the home automation via a smartphone (preferably Android). Only radio solutions are already in play. I've found a Zipato system which is supposedly compatible, but is it possible (apart from arming/disarming of course) to block the line and is a fixed IP address at home required (the customer has Neostrada). And will the DSC PC 5400 module be suitable for integration with the Zipabox controller?
    Greetings,
    Jarek
  • #2 12319038
    chaberino
    You are combining well with Android - it works (also with iOS) but the PC5400 module is not suitable for this. You need another module for this integration - DSC IT-100 and Zipabox + backup module. IP variables -ok. line blocking -ok.
